Ice on Steep Gravel Driveway - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2017, 01:40 PM   #51 (permalink)
rockbuggy84's Avatar
Member # 45202
Originally Posted by criscfer View Post
You do understand, that they are not heating them to 70 degrees. Either way, you'll need to fix the drainage.
I figured 35-36degrees would be sufficient, but that's just a guess.
rockbuggy84 is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 01:50 PM   #52 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Originally Posted by Mr Stubs View Post
7 Add a anchor post at the top of the driveway and use your winch.
8 Buy a D11 and outfit it with the controller from a Roomba.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:00 PM   #53 (permalink)
Member # 96278
Originally Posted by posford View Post
Buck up honey it ain't that bad!
fawk awph. maybe by the coast it ain't
Lower part of my driveway must by 5" thick, smooth glare ice. Upper part's only 3". Even in the woods... you should see my poor dog trying to find a place to shit. Well, she is neurotic, but still.
Drink to the dead all you still alive
We shall join them in good time
cj5.5 is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:12 PM   #54 (permalink)
Damn kids
plym49's Avatar
Member # 162771
I wonder how feasible it might be to use geothermal heat.
Dig a pit like you would to sink a cesspool. Go down say 15 feet.
Lay a long coil of pex/pvc/whatever in there. Use 1 1/2 to twice as much as will be under the driveway. Fill the pipe with something that won't freeze and a circ pump to keep it in motion.
The ground should be at 60 degrees that far down and if the water in the pipe gets up to 40 that might be all you need.
plym49 is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:18 PM   #55 (permalink)
Member # 74407
9. Learn to drive
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:20 PM   #56 (permalink)
Member # 74407
Thats a pretty good idea, but I doubt the liquid will stay as warm as you think. I dont know a lot about geothermal though.
Old 01-16-2017, 02:38 PM   #57 (permalink)
Member # 178120
Originally Posted by ManNamedJed View Post
Park at the bottom of the hill in winter?
Thats what I have been doing, its getting old!
Originally Posted by cj5.5 View Post
You're not fucking kidding. The whole state is covered in ice right now.
I havent seen a base layer of ice like this in years.
Not a bad idea
Shenanigans
plaidraid is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:40 PM   #58 (permalink)
Damn kids
plym49's Avatar
Member # 162771
I used to know all the thermodynamic equations but I don't any more. Someone can probably chime in who is current. SHould not be hard to compute.
Since you only need the driveway tubing to be warm enough to prevent freezing it should be a simpler system to size than if you wanted to heat your home.
Old 01-16-2017, 02:44 PM   #59 (permalink)
F2504x4's Avatar
Member # 85205
Costs - Design - SnowMelt - Radiant Heat Specialists
Some examples are given below so that you can approximate your square footage. Lets say you only want to do tire tracks to get you up or down an incline on your driveway.
100 foot tracks = 400 square feet - 100 foot long x 2 foot wide = 200 square feet x 2 tracks = 400
200 foot tracks = 800 square feet - 200 foot long x 2 foot wide = 400 square feet x 2 tracks = 800
300 foot tracks = 1200 square feet - 300 foot long x 2 foot wide = 600 square feet x 2 tracks =1200
400 foot tracks = 1600 square feet - 400 foor long x 2 foot wide = 800 square feet x 2 tracks =1600
500 foot tracks = 2000 square feet - 500 foot long x 2 foot wide = 1000 square feet x 2 tracks 2000
Pad in front of single car garage = 9 foot wide x 30 for turn around / backup area = 270 square feet
Pad in front of double car garage = 18 foot wide x 30 for turn around / backup area = 540 square feet
Pad in front of triple car garage = 27 foot wide x 30 for turn around / backup area = 810 square feet
On average a two car garage pad area (540 square feet) and a 100 foot long set of tracks (400 square feet) equals 940 square feet of snow/ice free driveway. includes total kW cost, 34.8 kW's.and would cost you approximately $23.49. *plus any taxes, etc that utilites charge. Just think, thats almost 1000 square feet of Snow and Ice free driveway for under *$25.00. Not to mention the additional benefit that the system will automatically start and shut whether its 2 o'clock in the morning or 2 o'clock in the afternoon, whether you're at home on the weekend or at work. You can't beat that!
[QUOTE=Administrator;15106961]And exactly why its better I work in the backround and not meddle what makes pirate pirate. [/QUOTE]
F2504x4 is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 02:49 PM   #60 (permalink)
F2504x4's Avatar
Member # 85205
From the link I posted above, it also has calculator to figure the cost
Old 01-16-2017, 03:14 PM   #61 (permalink)
Member # 4387
Salt for water softener is $4 40lb bag, crushed 3/4" gravel it when it's slick. It's no rocket science. I have over 1/3 mile of steep driveway in MT.
Norm is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 03:22 PM   #62 (permalink)
Member # 200906
My driveway is 380' long and raises 75' in elevation. The only thing I have found that works is just sand and lots of it. Too much salt just and the ice just re-forms. We have had a lot of ice this year and I have put down close to a 1000 lbs of sand. I also use all the ashes from my wood stove. I would also recommend not using too much salt on a gravel driveway. It can turn you drive way to mud and makes it hard to plow or snow blow.
Daveinvt is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 03:42 PM   #63 (permalink)
Member # 36733
I just use pea gravel, found that when I used salt it nuked the trees on either side of the drive and contaminated the creek near the road...
Same type price for the gravel in 40# bags at Lowes.
The grade of my drive is roughly 6% at one end and about 8% on the other end (Horse shoe drive design).
Because of how its designed I blow off plowing the 8% portion, marginally 1 vehicle width and nasty drop on the downhill side. By doing that the grandkids have a "fun" sledding hill...
[I]Vegetarian is an old Native American word for bad hunter[/I]
DavidVanVorous is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 04:03 PM   #64 (permalink)
Member # 81613
Plow it before driving on it
Don't trailer in bad weather
Drive like you stole it to get up.
That's how I handle mine
I did have an issue with the neighbors running their gutters across my driveway, rerouted them a few years ago and it's 100% better
Sent from my SM-T560NU using Tapatalk
ransil is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 04:47 PM   #65 (permalink)
Member # 31362
Send a message via AIM to deke
gona need to build a small culvert uphill by the side of the road. you might get away with an open french drain setup. Take it under the road and on the downhill side every so often so in case one section plugs up the whole thing isn't lost.
I'm a Chris Retard.
deke is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 05:01 PM   #66 (permalink)
Member # 3132
Whatever you do, do not concrete it. For some reason this site turns people into something weird. You will pour 10 yards of concrete, and you will find a crack then shit will hit the fan.
Old 01-16-2017, 05:03 PM   #67 (permalink)
Member # 110248
I live not so far from the OP and grew up plowing commercially and @cj5.5 is right, moar sand until you can fix whatever the root problem is in the summer. It's New England, that'll happen. once the ground is frozen gravel is easier to plow anyway, pavement gets slippery awfully quick on inclines even without that much ice.
Heated driveways would be stupid expensive not only to install (granite state) but would cost a fortune to run even if it was antifreezed. Just sand the fucking thing like everyone else.
djljeep is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 05:06 PM   #68 (permalink)
F2504x4's Avatar
Member # 85205
Originally Posted by djljeep View Post
I live not so far from the OP and grew up plowing commercially and CJ5.5 is right, moar sand until you can fix whatever the root problem is in the summer. It's New England, that'll happen. once the ground is frozen gravel is easier to plow anyway, pavement gets slippery awfully quick on inclines even without that much ice.
You have permanent brain freeze don't you ?
Old 01-16-2017, 05:07 PM   #69 (permalink)
Member # 3132
Seems to be going around this time of year.
Old 01-16-2017, 05:10 PM   #70 (permalink)
Member # 110248
I didn't read the whole thread, seemed like a pretty obvious answer.
Old 01-16-2017, 05:21 PM   #71 (permalink)
Member # 53453
I would do this if I could. My driveway is downhill to my place, and the road is too busy to dare pulling cable across.
For the 3 times a year I actually get stuck it would be a fine solution... Just no way I can do it safely pulling cable across the road.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 07:48 PM   #72 (permalink)
Member # 3132
You need a gravity reverser. I have one for sale.
Old 01-16-2017, 07:59 PM   #73 (permalink)
Member # 102813
Haven't you ever seen the movie "Eye of the Tiger"?
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 08:11 PM   #74 (permalink)
White Shark's Avatar
Member # 39791
Pisten Bully Winch Cat. Let it snow. No problems here. Grind it up on the way up or down. You're going to need a solid winch point though...
__
/_/
White Shark is offline   Reply With Quote Quick reply to this message
Old 01-16-2017, 08:23 PM   #75 (permalink)
imafighterjet
krawlr's Avatar
Member # 13619
Send a message via Yahoo to krawlr
Solarfreakinroadway.
Этот пост был взломан русскими
krawlr is offline   Reply With Quote Quick reply to this message
