Any Toyota gurus? Steering Q - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2017, 05:43 PM   #1 (permalink)
Member # 80349
Got lots of slop in the rack of my 99 4runner limited. The shafts move up and down a good bit. I attempted to replace the rack guide but it's not cooperating. We are supposed to torque the "nut" to 18 ft lbs and then back off 19 degrees. Problem is I hit 18 ft lbs before the nut is barely threaded in and there still a ton of slop. I have to tighten it till only 2 or 3 threads are showing before the slop is gone and that is way past 18 ft lbs.
I must be doing something wrong or my rack is fubar.
muddeprived is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 06:15 PM   #2 (permalink)
Member # 3132
Your part identifications suck. What shafts move up and down? What rack guides?
You have the rack and pinion. Rack and pinion bushings, inner tie rod ends, outer tie rod ends. They are know for provlems with inner tie rod ends and rack and pinion bushing issues.
Old 03-09-2017, 07:18 PM   #3 (permalink)
Member # 80349
Toyota Part numbers:
End sub-assembly, steering rack no. 2/ Guide sub/assembly
45504-35031-
Spring(for steering rack guide)/Spring, compression
90501-26074-
cap, Steering rack guide spring/ Cap, rack guide spring
45524-37010-
Nut(for steering rack guide spring cap/ nut
90179-48003-
The steering arm or ram that the inner tie rod attaches to is what's moving up and down causing a whole lot of funky steering behavior. The parts I ordered are for the steering rack guide, which for my year is a roller type bearing that is worn out (roller has too much play in it).
Old 03-09-2017, 07:33 PM   #4 (permalink)
Member # 156657
Sounds like the whole rack has seen its day. Has it leaked fluid out the ends by inner tre?
cryptic toy is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 07:36 PM   #5 (permalink)
daddytall's Avatar
Member # 74936
Try the Chevy section, some of those guys know all about Toyota's
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 07:48 PM   #6 (permalink)
Member # 80349
There was a little bit in the boot and reservoir level is normal.
Hard to believe it's shot cuz I got this from old folks who babied it from day one. It only saw highway and local pavement it's entire life.
My luck sucks though......
Old 03-09-2017, 08:19 PM   #7 (permalink)
Member # 3132
45504-35031-
90501-26074-
45524-37010-
90179-48003-
You should replace the whole rack then unless you are in the business of rack and pinion rebuilding. I would have turned it in as a core the minute i saw fluid at the inner tie rod boot.
Old 03-09-2017, 08:48 PM   #8 (permalink)
BossBuilt's Avatar
Member # 1760
BossBuilt is online now   Reply With Quote Quick reply to this message
Old 03-09-2017, 10:54 PM   #9 (permalink)
Extended Member
Member # 69765
Replace the rack. You can't fix it. Remanded ones aren't too expensive. I did this on my 96 4Runner like 10 years ago. Then sold it because it was a 4runer....
~ Kyle
2003 Montero
2006 Montero
Follow my adventures on Instagram:
Kyle_T is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 10:57 PM   #10 (permalink)
ADD
Member # 22080
And looks to have bought not one but 2 monteros.......yeah good choice
Got custom cab?
ADD is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 11:49 PM   #11 (permalink)
Member # 88698
Are you using the roller guide or the solid guid?
LBHSBZ is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 02:04 AM   #12 (permalink)
Extended Member
Member # 69765
Yep. And I don't regret dumping my 4Runner or rovers....
Sent from AutoGuide.com Free App
~ Kyle
2003 Montero
2006 Montero
Old 03-10-2017, 05:00 AM   #13 (permalink)
DMG
Member # 8145
Replace the rack. They aren't that expensive. You got eurothane rack bushings, too, right?
Also, don't be a tard like this guy and buy a Mitsubishi.
DMG is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 06:04 AM   #14 (permalink)
Member # 80349
My original roller guide had a bit of up and down play in it so I'm using a solid guide since that was what is recommended to replace it with.
The cheapest Toyota rack I could find was $650 on Egay. Dealers want $800+.
I don't trust remans.
I was hoping this would fix it for now so I could spend my cash on other goodies but looks like I'm gonna have to get a rack.
Old 03-10-2017, 06:48 AM   #15 (permalink)
Member # 3007
You don't trust reman, but you are trying to reman it yourself......and failing
Bones is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 07:02 AM   #16 (permalink)
Member # 80349
Doesn't hurt to try the simple fix. It either works or it doesn't and I'm not losing any $$ on it.
Old 03-10-2017, 07:07 AM   #17 (permalink)
Member # 3007
Yeah you are, your money in parts that are not working and your time. You have shitty luck because you make shitty decisions.
Looks like $220-430 would get you a complete rack assembly, bolt in and go. 1999 TOYOTA 4RUNNER 3.4L V6 Rack and Pinion Complete Unit | RockAuto
Old 03-10-2017, 07:07 AM   #18 (permalink)
Member # 729641
I've never been impressed with vatozone and similar junk. A dealer rack is hard to swallow but you'll only cry once.
Babied lol probably never went past half its stroke, then you come along and actually use all or most , I'm not talking about yanking on the wheel holding it to lock as the belt is squealing. Pull the egr and check it for build up pcv is probably gross also.
Cn'tafordit is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 07:25 AM   #19 (permalink)
Member # 80349
I fail to see the shitty decision.
I don't think I'm the only one who tries to fix something before tossing it out.
The parts were free. I have some credit at NC dealership from an overcharge and it took abt 20 minutes to install. This is a pretty common fix for a loose rack (besides a tighter bra) from what I've read on the yota forums.
Thanks for the link but I saw that earlier. I don't want to deal with tearing it out a 2nd time when the reman craps out like they usually do. I'm gonna go with a new Toyota rack. Just found one for $502.
My tax $$ came and went in record time this year....
Old 03-10-2017, 07:28 AM   #20 (permalink)
Member # 3007
So you are a broke ass, tried to fix it, failed and now have a tax return "windfall" and are going to get a new rack.
Old 03-10-2017, 07:33 AM   #21 (permalink)
Member # 80349
Well I do have a shitty ass bouncy road and f-ed up driveway.....
Old 03-10-2017, 07:35 AM   #22 (permalink)
Member # 80349
Broke? Not exactly. I refrain from spending massive amounts of paper as much as possible to avoid the woman giving me that lecture.
My tax $$ is my toy/play money so it can be spent freely. I was just hoping to get a winch and some sliders.
Old 03-10-2017, 08:26 AM   #23 (permalink)
Member # 729641
Cut the Feds from your free year long loan, I'm sure you can figure out how to invest it better.
Old 03-10-2017, 08:57 AM   #24 (permalink)
Extended Member
Member # 69765
So much hate or jealousy. This isn't some Dsm pos
~ Kyle
2003 Montero
2006 Montero
Old 03-10-2017, 08:59 AM   #25 (permalink)
Member # 226216
This^^^^. And pay a bit in the end. But use your money and or just put it in the bank and make a few bucks interest on it.
thefishguy77 is offline   Reply With Quote Quick reply to this message
