Zero turn mowers do's &don'ts - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2017, 12:06 PM   #51 (permalink)
Member # 3935
Originally Posted by crghill View Post
I just bought a Kubota ZG327. 60" deck with 27 hp gas engine. Thing is a beast. Hydraulic deck lift, drive shaft to deck instead of belt, wet clutch to engage pto. It mows my five acres of Florida swamp pretty good.
I was at the local Kubota dealer picking up parts for my CTL and I asked about the mowers. They have a turbo diesel 60" zero turn for $17k! I'd love to have one, but that ain't happening.
southernfriedcj8 is offline   Reply With Quote Quick reply to this message
Old 08-20-2017, 12:33 PM   #52 (permalink)
Member # 62472
My mower has all the bells and whistles but is gas. I had a 60" Diesel Toro but the mower only lasted 3,000 hours while I believe the engine will probably last 10K. It was a Kubota Diesel.
I went with gas on the Kubota because I got a comparable mower with lots of power for 10K instead of 15k. My price was $10,100 and I took the zero for 48 months financing. I sold my old Toro for $4,500 so I had a nice fat down payment.
crghill is offline   Reply With Quote Quick reply to this message
Old 08-26-2017, 11:08 AM   #53 (permalink)
Rusted.
Tin Roof's Avatar
Member # 132785
I ended up buying some atv tires and had the shop put fluid in them when they mounted them. Each tire held 5 1/2 gallons of fluid, so somewhere between 40-50 lbs per tire. I haven't mowed with it yet, but did drive around some. It rides like a lumber wagon now, but gets around a hell of a lot better.
Tin Roof is offline   Reply With Quote Quick reply to this message
Old 08-26-2017, 11:21 AM   #54 (permalink)
Member # 74407
So you added 100lbs of rotational mass (is that the correct term) to it? I just don't see that boding well for the hyd motors. Do you notice more of a strain to take off from a stop?
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 08-26-2017, 11:24 AM   #55 (permalink)
Rusted.
Tin Roof's Avatar
Member # 132785
I didn't notice any difference in take off or when going up a hill.
Old 06-18-2019, 11:00 AM   #56 (permalink)
Member # 111524
Necro post.
I've had a Kubota zt 42" for a couple years. Not thrilled with the cut on it. Seems I have to re-cut a lot of places. Yes, new blades etc, doesn't matter. Installed a mulch kit, removed it, still didn't cut well. Also feels a little underpowered.
I've found a SCAG liberty Z locally with a mulch kit and Kohler 7000 series engine with around 100 hours. Want to buy it and sell the Kubota. Any thoughts on the SCAG?
shhhh.....
Texas97 is online now   Reply With Quote Quick reply to this message
Old 06-18-2019, 11:07 AM   #57 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
Are you noticing a lot of "mowhawking" while cutting? My 42" Toro Timecutter ss5000 does that too. Mainly when going at normal speed through heavier grass. I also noticed if I dont tie a string to the deflector and raise it up a little bit, it tends to clog and bog.
The mowhawking thing also can be from an improperly leveled deck. I think you are supposed to have the front raised like a half inch or so over the rear? Maybe I have that backwards...but it is definitely something to consider.
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 11:21 AM   #58 (permalink)
Member # 111524
i dont think with this one i can adjust the deck height independently from the rear. but maybe. so which is it? higher in the front or rear?
i dont think id call it mohawking, as much as its knocking some stuff down and not having the tip speed and suction to pull it up and cut it all.
Everything ive heard is that SCAG decks and blades cut really well, so im hoping to get a better cut all around. also, the extra width may help with the edges as the wheels get in the way of my current 42". would be nice to do away with that discharge chute.
shhhh.....
Old 06-18-2019, 11:40 AM   #59 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Back on the topic of dunking your zero in the pond. I have a nice little pond with a steep embankment. The trick I found with the zero turn is to back down the slope, then drive back up it. Scooting over each pass.
-Guy Who Has Never Put It In The Pond.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 12:10 PM   #60 (permalink)
Member # 193950
Back higher than the front, that way you only cut it once. If the back is lower, it has to cut twice.
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 12:10 PM   #61 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
The rear has to be higher by an inch. Apparently it produces suction. Might help your issue. Typically there is a central turnbuckle or adjustment at the front of the deck off of the mower frame (right between your feet)
MOLON LABE
Old 06-18-2019, 03:28 PM   #62 (permalink)
wahlstrom1's Avatar
Member # 94308
Attachment 2684809
Any updates on sidehill traction with this setup? Contemplating doing the same to my RZT 50.
wahlstrom1 is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 05:35 PM   #63 (permalink)
Juztyn00's Avatar
Member # 52569
Send a message via MSN to Juztyn00
Better tires help a lot for control on hills, will take a divot out of the turf if you try to spin with a tire stopped, gotta keep them rolling.
Juztyn00 is online now   Reply With Quote Quick reply to this message
Old 06-18-2019, 05:45 PM   #64 (permalink)
3Cs
Member # 45122
1/2" higher in the rear is the norm, 1" seems way to much for blades that are only 18" to 20"long.
3Cs is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 06:02 PM   #65 (permalink)
wahlstrom1's Avatar
Member # 94308
I end up dragging one now just to keep it half ass on track and pointed where I wanted when heading down hills now. Climbs alright, but doesn’t sidehill or down hill track worth a shit.
Old 06-18-2019, 07:05 PM   #66 (permalink)
giles45shop's Avatar
Member # 197896
Necro post.
I have a 52 Freedom Z and really like it. Going on 12 years of mowing 5 acres with no major issues. Previous to this we had one of the Scag 61" 3 wheel commercial mowers that went about 15+ years. They are built well and seem to last.
giles45shop is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 06:51 AM   #67 (permalink)
Rusted.
Tin Roof's Avatar
Member # 132785
Sidehill traction was good, but it tore the shit out of the yard when turning. I ended up selling the Hustler and going back to a lawn tractor. If/when I move to a place with a flat yard I'll definitely go back to a zero turn.
Old 06-19-2019, 07:02 AM   #68 (permalink)
Member # 111524
Doing more research into the SCAgs, going to hold out for something with the velocity deck on it.
shhhh.....
