Ever wanted to test your halls for effect? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2017, 10:19 AM   #1 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
Well, apparently now you can. Test away.
Snap-on Hall Effect Test Set
https://stlouis.craigslist.org/tls/6132601663.html
What the fawk is this used for anyway auto tech guys?
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:22 AM   #2 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
Originally Posted by google
"A Hall effect sensor is a transducer that varies its output voltage in response to a magnetic field. Hall effect sensors are used for proximity switching, positioning, speed detection, and current sensing applications. In its simplest form, the sensor operates as an analog transducer, directly returning a voltage."
To check the sensor output, turn the DVOM to AC Volts. Rotate the wheel or whatever speed you are measuring. Place the meter leads across the sensor and measure the AC voltage output. Typically, if the shaft is rotated at about one turn every 2 seconds the output should be around .7 to 1.0 Volts.
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:22 AM   #3 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
next phone you get needs google
https://en.wikipedia.org/wiki/Hall_effect_sensor
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is online now   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:24 AM   #4 (permalink)
52202's Avatar
Member # 52202
When you ask a silly question...
52202 is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:33 AM   #5 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
Then just call it a crank position sensor tester.
Oh and y'all too
Peg Leg Fab Lab
Old 05-17-2017, 10:51 AM   #6 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
Oh and y'all too
why would you call it a crank position sensor tester, when you also use it to test Cam position sensors, wheel speed sensors, output shaft speed sensors, etc.
John Foottit 70 Bronco Buggy
Contact me about Custom Cabinetry www.beniciacabinetry.com
CrazyHorse is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:55 AM   #7 (permalink)
Member # 52710
Yes, there is such a thing as a dumb question.
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:57 AM   #8 (permalink)
Member # 3132
I install on occasion Hall effect systems on ambulances. Great for measuring accurate amps without large bricks bolted in near the batteries and also senses and displays voltage. Hall effect parts are easy to install and weigh a lot less, and attach to existing battery cables. Inpower llc makes the system I usually install.
Old 05-17-2017, 11:11 AM   #9 (permalink)
Member # 9423
Location: Newcastle, CA. But don't ask me where the Old Castle is
Send a message via Yahoo to evenBIGGERrock
As with many things in physics, it's name comes from the guy that discovered it:
It was discovered by Edwin Hall in 1879
Mantra: The more you learn, the more you realize how little you really know.
Translation: If you think you know it all.....you don't know jack.
evenBIGGERrock is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 11:27 AM   #10 (permalink)
Oh Jesus Tits....
Member # 17554
Waiting for the spinoff thread, "Ever wanted to test your balls for effect?"
1977 Ford F150 4x4 Shorty 351M/NP435
2007 Ram 2500 Quad Cab 4x4 5.9 Cummins
D-RAT is offline   Reply With Quote Quick reply to this message
