Electrical outlet help. - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-09-2017, 12:43 AM   #26 (permalink)
savage
scottz's Avatar
Member # 1730
5252-W
Item Description
15 Amp, 125 Volt, NEMA 5-15R, 2P, 3W, Industrial Series Heavy Duty Specification Grade, Duplex Receptacle, Straight Blade, Self Grounding, Back & Side 8 Hole Feed-Thru Wired, Steel Strap, - WHITE
"they've lowered the speed limit to zero and banned reverse"
scottz is offline   Reply With Quote Quick reply to this message
Old 06-09-2017, 05:15 AM   #27 (permalink)
Member # 198851
Generally speaking, residential wiring is done to minimal standards done by so called electricians who have very little knowledge....
ADChevy4x4 is offline   Reply With Quote Quick reply to this message
Old 06-09-2017, 05:31 AM   #28 (permalink)
45acp's Avatar
Member # 13671
Originally Posted by 4xfiend View Post
They are allowed with 14g. 12g won't fit in them. Yes, they exist. It's just that nobody who knows what they're doing uses them.
12g will fit just fine if you drill out the holes. Carefully- so the bit doesnt hook the internals.
45acp is offline   Reply With Quote Quick reply to this message
Old 06-09-2017, 08:44 AM   #29 (permalink)
Member # 13489
Originally Posted by pepe View Post
Im not seeing it in the specs, but will that take 12ga wire?
Most receptacles will except 12 gauge. When you wire a kitchen you wire it up for two 20 small appliance branch circuits. Then you install 15 amp gfci's and regular receptacles.
Danny mora is online now   Reply With Quote Quick reply to this message
Old 06-09-2017, 08:58 AM   #30 (permalink)
Screwzer2's Avatar
Member # 38193
Which SUCKS ASS when you wire a grage that way and fire up something with a 16A motor.
Hard to find a 20A GFI
Yesterday is History
Tomorrow is a Mystery
and Today is a Gift
That's why they call it the Present
—Eleanor Rososevelt
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 06-09-2017, 09:42 AM   #31 (permalink)
Member # 13489
20 amp GFCI's are all over. Hell you can still even find them for Zinsco panels. Use article 430 and size your ocpd to the motor based off the service factor.
Old 06-13-2017, 05:39 PM   #32 (permalink)
FOF
pepe's Avatar
Member # 17870
Originally Posted by scottz View Post
Boom, thanks.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself
Friends Of Fordyce
pepe is offline   Reply With Quote Quick reply to this message
Old 06-13-2017, 06:02 PM   #33 (permalink)
Member # 29527
Definitely.
CrustyJeep is online now   Reply With Quote Quick reply to this message
Old 06-13-2017, 06:33 PM   #34 (permalink)
wheelerfreak's Avatar
Member # 4135
There's a reason push in aren't used any more.
What is the issue with them? Are they more likely to pull out and if so what can cause that?
I'm nearly done with a remodel of my house and was going to upgrade all the kitchen and bathroom outlets to GFI since the house was built before they became code. Most of the outlets I'm seeing online are push in. I'll check some stores when I get back in town for the other style.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfits—a false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is online now   Reply With Quote Quick reply to this message
Old 06-13-2017, 06:47 PM   #35 (permalink)
Member # 29527
"All" the outlets? Or just the first one in each chain, like a sane person?
I used back-wired GFI outlets. They're out there.
Old 06-13-2017, 08:42 PM   #36 (permalink)
4xfiend's Avatar
Member # 75385
They are known to come loose over time. Also, like I said earlier, stab in are only made any more for 14awg wire.
There are back wired, like posted earlier, that has the wire go through the back but has a screw on the side to tighten it. That's different than the stab in.
4xfiend is offline   Reply With Quote Quick reply to this message
Old 06-14-2017, 12:24 AM   #37 (permalink)
Member # 192237
Originally Posted by ParadiseAutoElectric View Post
That cord happens to have its ground removed and on the right is the hot.
put your shoes on
grab a paperclip and stick it in the hot
you don't feel nothing
now touch ground
little buzz
oh noes daynjer
[486] is online now   Reply With Quote Quick reply to this message
Old 06-14-2017, 01:07 AM   #38 (permalink)
Haole's Avatar
Member # 5859
Question
Originally Posted by CrustyJeep View Post
I'm shocked.
Indeed.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
- Darlington County Chapter
Haole is offline   Reply With Quote Quick reply to this message
Old 06-14-2017, 01:11 AM   #39 (permalink)
Haole's Avatar
Member # 5859
That's a pretty crappy picture for having to guess the ground was removed from the cord. Can you find something more obscure to feign your brilliance with?
kuleana.
Old 06-14-2017, 01:12 AM   #40 (permalink)
Haole's Avatar
Member # 5859
Originally Posted by Filthy McChevy View Post
By a yard sign light?
kuleana.
Old 06-14-2017, 01:14 AM   #41 (permalink)
Haole's Avatar
Member # 5859
Screwy likes to pretend he know electrical stuff.
kuleana.
Old 06-14-2017, 04:41 AM   #42 (permalink)
Screwzer2's Avatar
Member # 38193
Yeah, but the inspector wanted a Waterproof/Childproof model.
Might be available, but I couldn't find it with those feature. Yes, a plain old GFCI in 20A is common.
and Today is a Gift
—Eleanor Rososevelt
Old 06-14-2017, 04:42 AM   #43 (permalink)
Screwzer2's Avatar
Member # 38193
Enuf to be dangerous.
and Today is a Gift
—Eleanor Rososevelt
Old 06-14-2017, 05:54 AM   #44 (permalink)
Member # 104517
'Dat ain't right.
pigtail 'dat bitch.
Amatuer Electricians will be here in 5, 4....
P.S> Where's the fuggin' box?
This. Screwy hit the nail on the head Those brass tabs loosen up from fatigue and​ heat cycles. When electrical connections are loose they get hot. When they get hot things go poof.
Try an electrical supplier. I buy them all the time at Platt, Crescent, Border States, etc. It's a weather resistant, tamper proof.
Yeah, this would be correct
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Old 06-14-2017, 07:25 AM   #45 (permalink)
Screwzer2's Avatar
Member # 38193
Meh, in another week or two the house will be fired up and I won't have to dick with it no more. They're on a temp. power pole at the moment, and that's getting yanked.
and Today is a Gift
—Eleanor Rososevelt
Old 06-14-2017, 09:49 AM   #46 (permalink)
bigun's Avatar
Member # 29037
Really! Gee lets see AAS in Electronics and 27 years in the trade working all phases, and types of electrical construction. 20 years as a contractor mostly custom residential because, I happen to enjoy the interaction with the customers making sure that they get exactly what they want. Not sure where you are from, but every 3 years I have to have 16 hours of continuing ed to get my license renewed, 8 of which is the new code, 8 generally is first aid or some other aspect in the trade.
“Indeed the safest road to Hell is the gradual one..." C S Lewis
bigun is offline   Reply With Quote Quick reply to this message
Old 06-14-2017, 10:09 AM   #47 (permalink)
Member # 29527
Psst, he said "generally".
Old 06-14-2017, 10:28 AM   #48 (permalink)
Member # 198851
Yes, I said generally ,and it's not personal.. My experience was 35 years in commercial, industrial, institutional as a wireman and contractor. I have the usual master licenses and certificates from training and so on...
I stand by my statement...Residential wiring is is very basic and it still gets messed up..
Old 06-14-2017, 11:42 AM   #49 (permalink)
Member # 4135
I have no idea which is the first outlet in each chain and really don't want to tear up the walls to figure it out
