Home AV people -- Blu-ray Mystery - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2018, 10:46 AM   #1 (permalink)
Diesel Smoke's Avatar
Member # 27575
My Dad has a continuous issue with his TV. About 4 months ago while watching a Blu-Ray or DVD or web content via the Blu-ray he would get about 60 minutes of good play back and then his audio would turn to crap. He replaced the Blu-Ray (Samsung), HDMI cable, moved the cables away from the power cable and tried multiple HDMI ports on the TV (Toshiba), but the issue persists. He close to buying a new TV, but wondered if anyone has suggestions?
Sent from my SM-N920V using Tapatalk
Wheeling?!?!? WTF is that? :confused:
Diesel Smoke is offline   Reply With Quote Quick reply to this message
Old 02-05-2018, 12:26 PM   #2 (permalink)
Valley Rock's Avatar
Member # 208306
If I had to guess (and i am) I would say bad ground, every time I see static build up it seems like bad ground, possibly from the elec outlet of the house itself or ?
Just my .02
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 02-05-2018, 09:12 PM   #3 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
Just my .02
I have never seen a ground wire on a TV power cord
Every day is better than the next.
Benny is offline   Reply With Quote Quick reply to this message
Old 02-05-2018, 09:56 PM   #4 (permalink)
Member # 40375
Common problem on Toshiba lcdís made around 2010. Toshiba released a firmware update. Go to the Toshiba website with the model number and see if you can download or call Toshiba to see if they will send it.
wizard_Drd is offline   Reply With Quote Quick reply to this message
Old 02-05-2018, 09:57 PM   #5 (permalink)
Member # 27575
Awesome timeline fits for his TV. Thanks, we'll check it out.
Old 02-05-2018, 10:04 PM   #6 (permalink)
Member # 40375
Hopefully you can find it. If firmware update work, then itís going to be a board and not worth fixing.
Old 02-06-2018, 07:29 AM   #7 (permalink)
Take a Knee
Mudinyeri's Avatar
Member # 44531
I was going to guess heat buildup or faulty board components that fail due to usage (time) or heat buildup (TV being on for a period of time and components generating heat).
Is the TV over a fireplace?
Medium Speed, Some Drag
Mudinyeri is offline   Reply With Quote Quick reply to this message
Old 02-06-2018, 09:44 AM   #8 (permalink)
Member # 40375
Here is some background on the Toshiba Regza audio problems from around that time period. https://howtomendit.com/answers.php?id=267571
I did a firmware update long ago on two that worked. Looks like some others needed to replace a board.
OP: you can always get a soundbar with HDMI in/out or use the Blu-ray optical out if it has one.
Edit: and another thread
https://forums.att.com/t5/U-verse-TV...r/td-p/2736685 .
I can't find the docs on Toshiba's website anymore, so probably not supported anymore.
Old 02-06-2018, 01:08 PM   #9 (permalink)
Member # 27575
No and not used or left on for extended periods.
Old 02-06-2018, 02:09 PM   #10 (permalink)
Take a Knee
Mudinyeri's Avatar
Member # 44531
Heat buildup doesn't require "extended" periods of use.
Old 02-06-2018, 06:45 PM   #11 (permalink)
Member # 80349
Been having a similar problem with mine and started around the beginning of winter. Anything being watched via the HDMI inputs was affected. It was interference with my pellet stove (not heat related). I moved my TV to other side of room and the issue is gone.
Are there any heating devices or electronics around the tv?
muddeprived is offline   Reply With Quote Quick reply to this message
