4th gen or 5th gen 4runners? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2018, 02:46 PM   #1 (permalink)
Yota Up's Avatar
Member # 57128
Grandma and Grandpa are looking to get a 4runner. Will pull his boat <3,000lbs. They have 10-15K to spend.
I've only ever owned 4runners up to 3rd gen so know nothing about the newer ones. Would it be smarter for the folks to stick to getting a 4th gen with low miles or try and find a 5th gen at higher mileage? Any input at all is appreciated. They're shopping around the Sacramento area, FWIW. Thanks.
Yota Up is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 03:17 PM   #2 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
I'd look for a 4th gen with a V8. A 3000lb boat should be OK as long as they're not going up to Tahoe.
I get adds for ghey cruises.....
Anyone else????
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 03:25 PM   #3 (permalink)
Corey Young's Avatar
Member # 21622
Toyota-4runner.org is a good forum. Do a bunch of reading.
Old 03-23-2018, 03:30 PM   #4 (permalink)
Member # 197531
I agree I just bought my son one to replace his Taco'ed Tacoma
12,500 they really hold there value here in AZ they were also hard to come by when i was shopping
1980 fullsize Jimmy, 14 bolt, 4 whl disc ,383 Edelbrock AL heads ,10 inch lift 38.5 ,crossover steer
Zmann is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 04:47 PM   #5 (permalink)
howyadoin's Avatar
Member # 84132
You're not even CLOSE to getting a 5th gen here for less than 20k unless it's a clapped out high mileage example. .02 Way more bang for the buck in 4th gen. .02
Debating economics with Screwloose is like asking a homeless dude for stock advice.
howyadoin is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 04:52 PM   #6 (permalink)
Member # 429
2004 V8 4Runner Limited here. It's decent, but my MIL's '03 Tahoe will flat blow it's doors off. The biggest issue with the 4th gens (not sure about the 5th) is the transfer case. I didn't know it was a problem, so I never thought to check it on the test drive. They are full-time t-cases with a dial on the dash to shift from hi to low range. Guess what? Toyota made the shift system so complicated, that if they aren't used regularly, they no longer shift into low range as the mechanism gets corroded. Stupid design.
Mine struggles to shift into low and there have been times where it flat refuses.
Granted, your GP's probably aren't using low range all that often, but something to be aware of.
The Lexus GX470 version gets a lever to shift into low range. Go figure on that...
If I had it to do over, I would buy the GX over the 4Runner as they seem to be better taken care of and cost roughly the same for more luxury.
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 08:32 PM   #7 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
Jack
You aren’t kidding, just did a quick Craigslist cruise, some screaming deals on GX470’s!
JeffsJeep04 is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 08:36 PM   #8 (permalink)
Yota Up's Avatar
Member # 57128
Oof. They do like to go to Tahoe with the boat. I think they usually take 88 more often than 49/50, though. Does it struggle going over the grade or what?
After checking a bunch CL ads it sure looks like 4th gen is the way to go. Only saw a single 5th and it was salvage title with high miles. I'll be sure to have them check the low range during any test drive for sure. Thanks for all the feedback.
Old 03-23-2018, 08:38 PM   #9 (permalink)
Member # 55560
Get a 100 series land cruiser. 98-99s are $5-6k and can tow 6500 lbs. 9.5" rear instead of the 8" on the 4Runner too.
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 08:42 PM   #10 (permalink)
Member # 377
Yep, wife had an '05 SR5 until recently. Good solid, reliable vehicle but those 4th gen engines were adequate at best. My '04 Tahoe smoked it in every way. Hence why we turned them both into a '13 Yukon Denali. Haven't driven a 5th gen 4runner so not sure if they're any better, but you're not touching one for $15k anyway.
east_beast is online now   Reply With Quote Quick reply to this message
Old 03-23-2018, 08:51 PM   #11 (permalink)
GRMhick's Avatar
Member # 87
Send a message via AIM to GRMhick
Get the v8. Nearly the same fuel economy as the v6 but way more power.
I can attest to towing 11k cross county with one. They flat out work.
. Diamonds. 35's.
. RestoMod.
GRMhick is offline   Reply With Quote Quick reply to this message
Old 03-23-2018, 09:06 PM   #12 (permalink)
Member # 377
I always questioned the numbers on those V8s. On paper, they have basically the same torque as a GM 5.3 and only about 25 fewer horses and the thing weighs about 1000 pounds less than a Tahoe, but damn if that 5.3 in the Tahoe doesn't feel considerably stouter.
Old 03-23-2018, 09:29 PM   #13 (permalink)
Member # 55560
That must have been miserable. I towed a 19' travel trailer from CA to Yellowstone to CO with my 100 and got a nice 7mpg. Ouray to Silverton was 1st gear over most passes. It did great, just slow and thirsty.
A bunch of old crap
Old 03-24-2018, 06:54 PM   #14 (permalink)
GRMhick's Avatar
Member # 87
The one I had was an 07. It was in 3rd gear and produced a whopping 7.8 mpg at 80 mph. Unloaded it got 19.5.
I was always surprised how it would pull at any speed I wanted up any grade. It was significantly more powerful towing than a 100.
In total, I put 40k of towing miles on the 4Runner and thought it was excellent.
. Diamonds. 35's.
. RestoMod.
Old 03-25-2018, 04:53 PM   #15 (permalink)
Member # 20237
We have a 2013, we don't have any complaints about it,
we use it to pull our 19ft boat around with no problems whatsoever.
jblack is offline   Reply With Quote Quick reply to this message
