Painting questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2018, 10:42 AM   #1 (permalink)
Member # 212988
Painting questions
So I am finally putting the jeep together and it starts with the paint. I have sanded everything and now have 90% of it in Omni epoxy primer. Please tell me that it get easier from here Sanding all these parts absolutely sucks and has to be the worst part of this entire project. Next i am applying feather fill G2 and then wet sanding with 400 and top-coating after that, seems like I am a long ways away.
HankScorpi0 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 10:55 AM   #2 (permalink)
Member # 322034
what are you sanding with ?
montrose818 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 11:03 AM   #3 (permalink)
Member # 212988
Just to lay the epoxy down I sanded with 180 on a board and DA. Some shit I did by hand like the grill.
Old 06-18-2018, 11:14 AM   #4 (permalink)
Member # 73540
Epoxy should only be used as a sealer for adhesion. Sands like shit. I do one coat of epoxy then 2k on top of that. You're gonna hate life sanding ff with 400.
rektec250r is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 11:17 AM   #5 (permalink)
Member # 212988
OK good so its not just in my head that it sucks lol. I have been reading the FF G2 clogs up the paper real fast, I have yet to spray any. If its within the recoat window can I just spray FF over the epoxy with only scuffing using red scotch brite? I was going to start with 220 and work my way up to 400 wet on the FF.
Old 06-18-2018, 11:31 AM   #6 (permalink)
Member # 322034
What throw is the D/A?
Old 06-18-2018, 12:01 PM   #7 (permalink)
Member # 212988
No idea some Eastwood 6"
Old 06-18-2018, 04:38 PM   #8 (permalink)
Member # 73540
G2 won't be bad knocking it down w 220 first. Just make sure you guide coat after the 220 so you can see the scratches. Red scuff pad is fine to prep the epoxy. I've had featherfil sand really easy and like a brick, I think it depends on humidity and the hardener ratio.
Old 06-18-2018, 04:40 PM   #9 (permalink)
rugby's Avatar
Member # 49997
Fix your pictures.
Here is what I did.
80 grit to bare metal
Epoxy primer
High build primer
Sand high build with 180 then 400
Epoxy sealer. Just epoxy thinned 10%
3 coats of base
4coats of clear.
1k wet sand
1,500 wet sand
2k wet sand
3k wet sand
Buff
It sucks and is a lot of work. I had to re spray my roof 5 times before it came out right.
rugby is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 05:21 PM   #10 (permalink)
Member # 40450
When I painted my truck, I quickly came to the realization that there is a reason body and paint work is expensive. Sanding sucks, waiting for primer/paint to dry sucks, cleaning the gun every time you use it sucks, etc.
It quickly went from "How hard can it be?" to "What have I gotten myself into??"
That being said, it is a very rewarding process, especially when you tell people you did it yourself.
MDMIKE is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 05:23 PM   #11 (permalink)
Member # 82607
It's a Jeep for crying out loud, get some Rustoleum and Acetone and go to town
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 06:27 PM   #12 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
Walmart sells flat black paint, $0.99/can. that is the only thing I would paint a jeep with- and I like jeeps.
Get yourself a spray handle that fits the can and go to town. If you want they sell clear coat spray cans too.
Its a jeep, sand it with a brick- paint it with a broom
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 06:38 PM   #13 (permalink)
Screwzer2's Avatar
Member # 38193
This, fucking this.
Save some money, buy a gallon, and use a brush.
Fuck you Earl Shieb.
Yesterday is History
Tomorrow is a Mystery
and Today is a Gift
That's why they call it the Present
—Eleanor Rososevelt
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 06:57 PM   #14 (permalink)
Member # 322034
For sanding off paint, I've read many swear by this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
along with this
Old 06-18-2018, 06:59 PM   #15 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Why so exotic?
Plain old water-based or solvent based exterior latex.
Pour some right on flat surfaces, spread with a brush and finish with a foam roller.
Do it in the shade.
Let it cure in the sun. Try not to get it rained on during that time.
In a week it is hammer-tough.
Any rust showing, spot treat with Rustoleum red primer.
Here is a formula for Behr OD green. I don't remember if the color is CARC or 24087.
Behr Ultra exterior semi gloss
Base 5853
Colorant _oz_ 384th
CL 0 20
DL 0 78
KXL 0 208
LL 11 84
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 07:07 PM   #16 (permalink)
Member # 102467
Yup.
400 sandpaper?
Put some 36 on a DA and go to town.
The party told you to reject the evidence of your eyes and ears. It was their final, most essential command.
I much prefer the sharpest criticism of a single intelligent man to the thoughtless approval of the masses - Johannes Kepler
LigBoozer is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 07:38 PM   #17 (permalink)
gregj50's Avatar
Member # 151818
Rustoleum!!
Scratched Many times!!
Touch up is easy!!!
gregj50 is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 02:52 AM   #18 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 04:35 AM   #19 (permalink)
ev13wt's Avatar
Member # 52443
Actual spray painting is 5% of painting a car / truck.
Welcome to epoxy hell. No machines. Or very low RPMs
Save time: sand a bit, spray same color, buff, done.
eVil.TwiT
"Always take more trash from nature than you bring."
ev13wt is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 04:59 AM   #20 (permalink)
Member # 212988
To all of you saying go ahead and rattle can it. I have been working on this project for a long time so keeping it rust free is important to me. The problem is once you get started it's very easy to get bogged down with the little things. A scratch or dent your going to repair real quick ends up happening on every panel you touch. It's going to get used so I don't need show quality I just need it good enough to look well put together.
Old 06-19-2018, 05:41 AM   #21 (permalink)
today
fredycruger's Avatar
Member # 225557
i like those 99c wallmart spray cans i buy them by the case
comes flat black and shiny black
12$ paintjob
fredycruger is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 12:23 PM   #22 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
^ these are not the same. Tractors are kept rust-free without 7 coats of clear and 3000 grit sanding.
Old 06-19-2018, 01:33 PM   #23 (permalink)
popeye
yotee's Avatar
Member # 20027
Originally Posted by Subybaja View Post
yotee is offline   Reply With Quote Quick reply to this message
Old 07-17-2018, 04:45 AM   #24 (permalink)
Member # 212988
got her done over the weekend. Not a great job but not terrible either
Old 07-17-2018, 05:32 AM   #25 (permalink)
today
Member # 225557
looks good
