Raining, then pouring. 350 TBI tech on a Monday - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-01-2018, 05:33 PM   #1 (permalink)
Damn kids
plym49's Avatar
Member # 162771
I am down here in a sub-tropical paradise with two vehicles, basic tools and not much else save a tiny garage.
My '88 Chevy K1500 was sitting - outside in the sun - for two weeks. I have had this veehickel since new and it has sat for longer periods with nary a problem.
Anyway, I went to start it today. Cranks but no start, no fire. Batteries (two) are fresh with plenty of charge.
What would cause this to die from sitting this short period? (No diagnostic work yet performed.)
My first thought is fuel pump, which was replaced once back around the turn of the century. At the time I cut an access panel so the pump can be changed from the top - although it is still a PITA to get your hands in there.
My second thought is a stuck fuel pump relay from cooking in a humid area. Long shot, prolly, but easily checked.
I kind of doubt it is ignition. I can crank after spritzing fuel doen the throttle body to quickly rule that out.
My biggest issue is logistical. To get to the access panel in the bed I have to unload the bed and remove the bed liner, which sounds simple but I have no where to put the shit in the interim. I might have to ferry it all someplace else bit at a time.
If it is the pump, I can try smacking the tank from the bottom while cranking. Maybe that will free the pump so I can at least drive the truck to a better spot.
What about removing the batteries, jumping in series and hot wiring the pump with 24 volts? That might free it. Never tried that, though.
Money is tight. Is it risky to just replace the pump as opposed to the whole shit?
Thoughts and advice welcome.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 05:59 PM   #2 (permalink)
KDXSR5's Avatar
Member # 110516
Checking fuel pressure doesn't seem too hard, and you would eliminate the filter as an issue.
https://youtu.be/qHcOS7FY148
KDXSR5 is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:00 PM   #3 (permalink)
Mr.RatBastard's Avatar
Member # 9307
Will it run on starting fluid?
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:03 PM   #4 (permalink)
KDXSR5's Avatar
Member # 110516
This too. Then you know it isn't an air or spark issue.
Old 10-01-2018, 06:06 PM   #5 (permalink)
Damn kids
plym49's Avatar
Member # 162771
I actually have a pressure gauge mounted behind the throttle body.
This is an easy check.
I have not done any diagnostic work yet. No time. But the above two checks are easy and the first things to try.
Hoping against hope it is not the pump because that is going to be a bitch for the reasons cited.
Always tip.
Old 10-01-2018, 06:16 PM   #6 (permalink)
Member # 73540
Those were bad about the distributor taking a shit. Shaft gets worn and takes out the pickup.
rektec250r is online now   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:35 PM   #7 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Well, maybe.
I just ran out to the truck and enlisted someone to turn the key.
There is fuel pressure - rises to 12 psi (low-pressure TBI system) and falls as it should in response to the key.
I was concerned that I could not see any fuel squirting out of the injectors - so I dumped some gas right down the throttle body. No difference, not even a cough.
I checked for spark and there was none.
I initially suspect the coil, since it is the one that came on the truck when I took delivery in September of 1987.
Are there any diagnostics for the dizzy module (was replaced about 10 years ago) other than replacing it? I can easily check the shaft for wobble with the cap off.
Always tip.
Old 10-01-2018, 06:42 PM   #8 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
Down here thatís called a Mexican fuel pump replacement.
Turn the key on and smack the bottom of the tank with a hammer. You only have 2 seconds to do it, so itís best to get someone to turn on the key, while you smack it.
Odds are, this is it, but who knows.
'80 CJ7- soon to start project "always changing directions"
'84 CJ7- all stock farm rig, except a bunch of gun racks
'79 CJ5- not stock- way too much to list
Rttoys is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:43 PM   #9 (permalink)
RSWORDS's Avatar
Member # 49595
Do some basic ign troubleshooting. Plenty of information on the web
Where are you located? I probably have piles of spares
Thank you to the companies that have helped me out
RSWORDS is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:50 PM   #10 (permalink)
williamj's Avatar
Member # 35484
Before I pulled the distributor I’d check for spark at the coil as well as 12 volts to the coil. If I recall correctly from a previous thread you are slightly south of me so if you need some help or tools let me know.
williamj is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 06:55 PM   #11 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Originally Posted by williamj View Post
Before I pulled the distributor Iíd check for spark at the coil as well as 12 volts to the coil. If I recall correctly from a previous thread you are slightly south of me so if you need some help or tools let me know.
I am in south Florida, west of Lauderdale.
RSW, if you have some spares and feel like filling a small flat rate box, let me know. (Figuring a coil and a dizzy module.)
WJ, thank you and if I run into a bind I might take you up on that.
Always tip.
Old 10-01-2018, 07:25 PM   #12 (permalink)
Member # 133589
Check all grounds with a test light, moist air like that can corrode things quickly. Go from positive battery terminal to the body/frame/ engine block ect. Also do the paper clip trick on the diagnostic port, and see if there’s any codes.
lie and get by, or comply and die........
mvanhelden is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 07:44 PM   #13 (permalink)
Member # 159303
https://easyautodiagnostics.com/gm/4...ed-icm-tests-1
Fixed mine following this guide. Same thing as you, truck sat a while, then no spark. The pickup coil rotted out.
YZRider is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 07:45 PM   #14 (permalink)
lil,yota's Avatar
Member # 102395
My vote is the Module.
I have a truck in the shop right now, the customer changed the distributor and the new one was bad right out of the box.
Someone around you is gonna have a spare...use that for testing.
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 08:59 PM   #15 (permalink)
Member # 1792
Ignition module let go. This is common.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 10-01-2018, 09:00 PM   #16 (permalink)
Peow130's Avatar
Member # 123919
Yup.
Or the pickup coil in the dizzy. Fucking annoying too on those trucks.
Fuckin shitbox 2005 F150
53' CJV35-U, HO 5.0, 4 speed, etc.
Peow130 is online now   Reply With Quote Quick reply to this message
Old 10-02-2018, 05:43 AM   #17 (permalink)
RSWORDS's Avatar
Member # 49595
PM me an addy
Old 10-02-2018, 06:57 AM   #18 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Make sure and put some heatsink paste on the new EST when you change it out.
FYI those EST's will fire the coil without a signal from the ECU, the ECU signal is just a advance/retard degrees signal.
As long as you have +12 to the big pink wire on the coil, and its feeding +12 back to the EST it should get spark.
The injector fire signal comes from the pickup coil via the est module.
I've not seen a bad pickup coil, but the est's do go bad. I'd start by swapping the est, easy to do without pulling the dizzy.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 10-02-2018, 07:22 AM   #19 (permalink)
ev13wt's Avatar
Member # 52443
dry the distributor?
eVil.TwiT
"Always take more trash from nature than you bring."
ev13wt is offline   Reply With Quote Quick reply to this message
Old 10-02-2018, 08:03 AM   #20 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
I have never had great luck with the ignition module on these. I have mine routed to the inner fender now on a computer heat sink, and so far so good.
That or pickup coil as mentioned are my guesses, but grounds go to hell on these in humid climates all the time. Corrosion in the computer is also a possibility, but less likely if the truck has working AC and doesn't sit with the windows down all the time.
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 10-02-2018, 05:43 PM   #21 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Thanks to all that have replied. I might not be able to get back to the truck until the weekend, and RSW is graciously sending a CARE package.
The issue must be somewhere in the coil - module - pickup triad.
I did not know that the module will keep the injectors from firing if it is not happy. My injectors are not. Might be a vote for a bad module; not yet sure.
Always tip.
Old 10-02-2018, 06:18 PM   #22 (permalink)
RSWORDS's Avatar
Member # 49595
I'll send tu ou the random crap that I have stashes form random projects. No promise any of its better then what you got though. Lol
Old 10-02-2018, 07:41 PM   #23 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Whatever does not work in my truck will be used to make my YJ faster. Now that I'm a race winner I have to keep a step ahead.
Always tip.
Old 10-02-2018, 08:18 PM   #24 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Check the ground wires to the thermostat housing area.
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 10-02-2018, 08:50 PM   #25 (permalink)
Member # 104517
Oh yeah, I had that ring terminal break after a cam swap. Drive me nuts for days.
I also had a distributor that broke the pickup wire below the module. Swapped in my spare module and it fired right up, then died. Get pissed and grab a new dizzy, found the wire broken below the module. Messing with it would touch until it ran and vibrated loose.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
