What gay little thing took you out of the race at KOH? - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2019, 06:49 AM   #51 (permalink)
arse_sidewards's Avatar
Member # 256962
Originally Posted by GiS View Post
I am torn on the dead head issue being the problem .. perhaps that's better than running hot fuel back into the tank itself?
I assume you're running a rear radiator.
Are your radiator fans heating your fuel cell? The lack of airflow over the engine isn't helping anything.
If your fuel is starting off at 100deg+ it's not gonna need to sit very long in the fuel rail to turn it into vapor especially if the engine is just sitting in all the heat coming off the exhaust.
What fuel rail pressure are you running? You could down-size the injectors and up the pressure.
Old 02-12-2019, 07:09 AM   #52 (permalink)
Member # 212988
The team I was with lost PS pump then after being down for so long the batteries started draining causing lighting issues resulting in a crash that took the lights out completely.
HankScorpi0 is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 07:15 AM   #53 (permalink)
Danger Ranger's Avatar
Member # 1234
Originally Posted by CDA 455 View Post
College fund???
Retirement fund???
What are these things you speak of?!!
Oof
Best way to make a small fortune in racing... is to start with a large one
It's the perfect time of year, Somewhere far away from here.
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 07:19 AM   #54 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Originally Posted by sceep View Post
This, and at my age (66) the body won't take the pounding anymore. I still wheel, but KOH is a whole other level of pounding.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 08:29 AM   #55 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
Dual in tank pumps, Aeromotive regulator at the tank with a single line going to a dead-headed FAST Intake/Rail set-up. The FAST set-up was new for this year but the plumbing, including the dead head did not change from previous years set-up.
At one point the drivers side fuel rail (entry) was warm to the touch while the pass hot was uncomfortably hot to place your hand on. Let it cool for 10 mins, dumped a bottle of water on it and the son of a bitch came roaring back to full power .. for 1/2 mile hah!
sounds like a heat sink issue
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 10:18 AM   #56 (permalink)
Member # 7903
My experiences:
2012 - copilot in 4400 car, broke on outer limits trying to push another car up ledge. Lower control arm failed. Ended up putting on spare, but car broke and had to be recovered from Outer Limits.
2014 - 1st year with 4500 car. Radiator fan died on lap 1, limped back to camp. Passed by Currie finishing race while we overheated trying to finish lap 1. Swapped fan at main pit. Timed out working through traffic after finishing Outer Limits.
2015 - 4500 car. Track bar bushing failed allowing excessive chassis movement. This caused oversteering of the steering box. We broke 2 steering boxes on lap 2. Tapped out after Sledgehammer. Spare bushing on bench in Michigan. We were 11th after lap 1 and feeling like we could push for a good finish.
2016 - 4500 car finished
2017 - sold car, haven't been back
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 10:46 AM   #57 (permalink)
GiS
GiS's Avatar
Member # 31285
Yes, is it a rear mounted radiator, which sits above my fuel cell. This is the same design and mounting configuration that I've been running for a few seasons now.
The hood has a few louvers and should theoretically be moving air .. especially on some of the higher speed sections. Oddly enough I started having issues towards the end of lap one, before having to slow it down for any of the more major rock trails.
The fuel pressure runs at a steady 58 PSI, thought I am measuring it back at the tank after the regulator.
What's odd is that this was never an issue before .. then again, I suppose most of my local races are shorter duration.
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 11:07 AM   #58 (permalink)
BRD
Member # 74465
So what year(s) did you race KOH?Just curious.
________________________________
"Crippled but free
I was blind all the time I was learning to see"
BRD is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 12:02 PM   #59 (permalink)
Member # 143737
'33, '34, and '35
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 03:07 PM   #60 (permalink)
Member # 133009
Originally Posted by posford View Post
'33, '34, and '35
18 or 19?
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
