Tech in GCC, need quick help with 4runner issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-14-2018, 01:05 PM   #1 (permalink)
Member # 80349
I am in need of quick help with this truck because I gotta get it fixed by Friday to go to work. I am stumped.
99 4runner v-6 Auto 4wd
Issues:
Constant surging on acceleration
Cannot exceed 2000 rpms
Lacking power
Whirring noise that follows the surging
Rough start
I just replaced the pump today and no change.
muddeprived is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:09 PM   #2 (permalink)
Member # 852560
Any codes being set?
1968RallySport is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:15 PM   #3 (permalink)
Member # 80349
No
Old 11-14-2018, 01:16 PM   #4 (permalink)
Member # 85670
Send a message via AIM to Southern_Pride Send a message via Yahoo to Southern_Pride
Take an upstream o2 sensor out and drive it. May be a plugged cat.
Southern_Pride is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:32 PM   #5 (permalink)
Member # 80349
Wouldn't a plugged cat fail emissions? I just passed last week.
Old 11-14-2018, 01:47 PM   #6 (permalink)
Member # 74407
Saying you replaced "the pump" is kind of vague. Was it the water pump? Fuel pump? Windshield washer pump? Unicorn fart injection pump?
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:48 PM   #7 (permalink)
DWT
DWT's Avatar
Member # 19850
Find the vacuum leak.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:48 PM   #8 (permalink)
Member # 81812
Check the coil packs. I'd had a similar issue with mine. The spark was running down a line of carbon on the outside of the plug/s. Never threw a code but had some drivability issues.
jim
stock 87 is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:54 PM   #9 (permalink)
Yota Up's Avatar
Member # 57128
Get a propane torch, let it hiss(don't light it obviously), and pass it over all the hoses and listen for a spike to idle to see if you got an intake leak.
Yota Up is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 01:55 PM   #10 (permalink)
Member # 80349
Unicorn fart injection pumps never fail.
I replaced the fuel pump with a new Denso pump.
I will leaf blow it tmw.
Coil packs are brand new. I will swap the old ones back in just to see if anything changes.
Old 11-14-2018, 01:58 PM   #11 (permalink)
Member # 711946
2nd vote for plugged CAT
andy29847 is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 02:29 PM   #12 (permalink)
Member # 103154
How many miles on it?
You clean the maf or do a tune up lately?
Wrong plugs can cause problems.
whatafkwasat is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 02:41 PM   #13 (permalink)
Member # 82607
My WAG is a clogged up fuel filter or sock on the pump, starving for fuel or a bad injector.
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 02:48 PM   #14 (permalink)
Juztyn00's Avatar
Member # 52569
Send a message via MSN to Juztyn00
Hole in flex tube going to air cleaner but after the MAF or a loose clamp or a vacuum hose off or failed... My guesses anyways...
Juztyn00 is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 03:07 PM   #15 (permalink)
Member # 107967
No oil in it and the rod bearings are seizing.
Hey, don't lob factual statements at me as if they're insults.
Pukemaggots is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 03:13 PM   #16 (permalink)
Member # 86724
check the fuel trims?
Old 11-14-2018, 03:13 PM   #17 (permalink)
Member # 80349
172k.
Cleaned maf two weeks ago.
Tune up last year.
Fuel filter was replaced last month.
Pump and sock brand new.
Injectors unknown. Still factory as far as i know.
My TPS signal wire is reading 3.6 volts at WOT. Seems low but i hear some models peak at 3.5. Is this pos supposed to read 5 volts wot?
A little backstory that might help.....I been having rough starts that last between 5 to 20 seconds.It would idle like a tractor then smooth out. I also get a bit of white smoke on startups that fade once it is warmed up. My mileage has been sucking as welI. I replaced the Engine Temp Sensor, fuel filter, PCV valve, coil packs, cleaned MAF and all TB components. Plugs and wires looked fine.
Then sometime about a month ago it started jerking and cutting out under load on the highway or when hauling heavy shit. I thought pump was going and then this shit started two days ago which prompted the pump replacement.
Old 11-14-2018, 04:29 PM   #18 (permalink)
Member # 80349
Well this stinks. Intake tube and plenum coated with oil. White foam shit in pcv tube.
Old 11-14-2018, 04:34 PM   #19 (permalink)
Member # 86724
a toyota v6 with bad head gaskets?
unpossible, toyota's never break.
Old 11-14-2018, 05:01 PM   #20 (permalink)
Member # 95763
That could just be condensation mixing with the oil and that is where it decided to collect.
Clean out PCV valve, make sure the system is working.
KarlVP is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 05:24 PM   #21 (permalink)
DMG
Member # 8145
Issues:
Lacking power
Rough start
Get it towed to my shop and I will figure it out, Chris.
DMG is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 06:00 PM   #22 (permalink)
Yota Up's Avatar
Member # 57128
Open the radiator cap and smell for gasoline odor.
Go to the store and buy a knockdown(Hydrocarbon) test, about $30-$40 and confirm if you have a bad head gasket.
Old 11-14-2018, 06:21 PM   #23 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
Random, but my 99 taco the CPS went bad, but went bad slowly. hard starts, rough idle ect. I swapped it and all that went away.
I would also check the injectors. I had 2 dead ones prior to that. replaced them and cleaned the others made a huge difference in drive-ability.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 06:28 PM   #24 (permalink)
Member # 80349
Did this twice in the past two weeks with the block tester I have. Fluid stays blue.
Can anyone confirm the TPS 3.6 volts at wot is within specs for a 4runner? My google search is coming up empty.
Old 11-14-2018, 06:31 PM   #25 (permalink)
Member # 80349
Issues:
Lacking power
Rough start
Thanks. I will see what i can do. This is my only vehicle so I gotta figure something out.
