Any XP gurus's on tonight? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2018, 10:04 PM   #1 (permalink)
Member # 9467
I have an old XP machine with two network adapters. Wired and wireless. On boot XP uses the wired connection and I need to force it to use the wireless connection first.
There is a registry list that specifies the order. It lists the available network adapters along with the assigned value.
The software I run is tied to the MAC address in the wireless PCMCIA card. If it's not first in the boot list the software isn't smart enough to look at the second. Or maybe it's too rigid to think any computer could have more than one network card.
For the life of me I can't remember the registry path. Can anyone point me in the right direction?
Thanks!
lt1yj is offline   Reply With Quote Quick reply to this message
Old 12-13-2018, 10:20 PM   #2 (permalink)
Member # 848
How to Optimize Network Connections in Windows XP
SNOWTREK.org
Nobody is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 12:23 AM   #3 (permalink)
Member # 9467
Originally Posted by Nobody View Post
I gave it a try and the wireless card is already 1st on that list.
If I run Ipconfig/all it still shows the wired card as first.
When I first set this up back in 2010 or so I recall editing the registry directly after trying a few other options. What you posted may have been one of them.
Do you have any more suggestions?
Old 12-14-2018, 12:49 AM   #4 (permalink)
Elwenil's Avatar
Member # 41063
I hope that's a private network. XP connected to the Internet is a seriously bad idea these days.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
I put on my robe and wizard hat. - Bloodninja
Elwenil is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 12:58 AM   #5 (permalink)
Member # 9467
It is private. Air gap to the internet.
Old 12-14-2018, 05:14 AM   #6 (permalink)
Member # 20728
That's what they all say, until it's found in a pen test.
Romogo is online now   Reply With Quote Quick reply to this message
Old 12-14-2018, 05:20 AM   #7 (permalink)
Member # 20728
In Control Panel, open the Network Connections.
Then click Advanced, Advanced Settings...
Here you would be able to set the connection priority. Move your WLAN connection to the top
I don't have an XP machine handy to verify this, but it works in 7 and server 2008R2.
Might have to press Alt to get the menus to show up.
Old 12-14-2018, 07:07 AM   #8 (permalink)
Member # 109953
the ethernet is probably coming up first because the drivers for the wireless card get loaded after it. Most wireless cards back in XP you had to load software/drivers for and if it had an ethernet port, that would be built into the OS by the vendor.
why do you have 2 networks on an XP machine is the first question!?
AZ Undertakers
ShmUDE is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 07:48 AM   #9 (permalink)
Member # 108006
In the first post, software is licensed to a MAC address (dumb I know, but it happens) so the OP can move the software to a new machine by just moving the wireless lan card and keep it activated without having to contact the probably defunct software company to get a new activation.
OP, you should be able to disable the onboard NIC in the BIOS settings of the computer and that should keep it from ever showing the onbard nic mac address to the software and then it should load up and run on the wireless lan card's mac address.
JunkCJ6 is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 07:57 AM   #10 (permalink)
Member # 108006
Also what Romogo said if you need both connections active. Instructions link below.
https://theregime.wordpress.com/2008...er-in-windows/
Old 12-14-2018, 08:00 AM   #11 (permalink)
Member # 48224
I would change the MAC address of the wired LAN interface, and see if the software accepts it. https://www.online-tech-tips.com/com...e-mac-address/
FoghornLeghorn is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 08:49 AM   #12 (permalink)
Member # 9467
You hit the nail on the head! This setup is a legacy configuration that was done by the software vendor originally.
I need the onboard NIC to connect to the LAN. No wireless on the local network. This computer serves licenses to the other 5 computers on the LAN.
I can disable the onboard NIC. Boot the computer and the software loads automatically reading the wireless card MAC. Then enable the onboard NIC and use the software. It works but isn't stable.
Old 12-14-2018, 09:10 AM   #13 (permalink)
Member # 9467
This is what was suggested in post 2. I have the wireless card in position #1 but when I run ipconfig/all the onboard NIC is in the first position. I know from past experience the wireless card has to be first in the ipconfig command or the software won't boot.
Old 12-14-2018, 09:54 AM   #14 (permalink)
Member # 108006
Maybe???? Talks bout where the binding is in regedit and what to change.
HELP!! Need to find reg key for network adapter!!!! - Windows XP
Old 12-14-2018, 10:23 AM   #15 (permalink)
Member # 848
+1
Even better, spin up a VM
SNOWTREK.org
Old 12-14-2018, 10:39 AM   #16 (permalink)
Member # 9467
Making progress. That helped me find a list of the network cards in the registry and shows me the order they get accessed.
HKLM/system/currentcontrolset/services/tcpip/paramaters/ then either adapters or interfaces shows the boot list. In either the wireless card is last.
This registry location isn't the one I was looking for. I think I'm in the right area, just need to keep digging.
Thanks!
Old 12-14-2018, 10:45 AM   #17 (permalink)
Member # 848
Disable automatic metric on the interface
https://support.microsoft.com/en-us/...or-ipv4-routes
You couldn't change the Wired MAC?
SNOWTREK.org
Old 12-14-2018, 10:59 AM   #18 (permalink)
Member # 9467
I tried to spoof the MAC address using the info posted above . My advanced tab only has four entries and locally administered address is not one of them. None of the four are related to networking.
Old 12-14-2018, 11:10 AM   #19 (permalink)
Member # 848
Might not be supported on that network adapter, or a driver issue. Maybe throw in a different NIC. Regardless, manually setting the adapter metric should do what you want. However I would migrate that system to a VM ASAP before it lets the smoke out.
SNOWTREK.org
Old 12-14-2018, 11:29 AM   #20 (permalink)
Member # 9467
That's where I'm heading. I took the machine to a local "expert" to clone the drive and build a mirror machine. The next step was to build a VM off the mirror.
The guy corrupted my original drive and only managed to pull the data from the drive, not the OS or configuration. I was trying to be proactive......
I can rebuild most of the server on the old license files but in order to do that I have to fix the order. I tried to disable the onboard NIC and load the software but no dice. I thought that worked in the past but I'm old and forgetful.
In the registry (from one of the suggestions above) I found the bind order and it has the wireless NIC in the first position but the other location has it 3rd or 5th. Ipconfig/all also shows it last.
Old 12-14-2018, 11:38 AM   #21 (permalink)
Member # 86724
this all worked on your original drive?
How was it corrupted?
short of a hardware failure there shouldn't be anything destructive done to clone a drive. I'd fix that one, then create a VM using it.
If that drive has suffered some sort of hardware failure, or some dumbfuck plugged the old windows xp drive into a new machine and let windows fuck itself all up, then I would disable the oboard NIC in the hardware. Reconfigure your software with only the wireless NIC in there, then use that to create a VM using the wireless nic MAC address as the VM adapter.
It's already fucked now, so if you're putting the work into reconfiguring it I would strongly urge you to virtualize it in order to make it hardware agnostic and never encounter this again.
Old 12-14-2018, 11:49 AM   #22 (permalink)
Member # 9467
Everything worked fine on the original drive.
I have no idea how they screwed up the drive. The guy claims it was working fine when it left his office. When I booted it it went straight to a check disk and identified nearly every sector of the drive as corrupt. No changes whatsoever to the machine. Just him cloning the drive.
My back is against the wall on getting this running so I've been trying to do what I thought would be quickest, and then work out the VM next.
Old 12-14-2018, 11:56 AM   #23 (permalink)
Member # 848
did you disable the automatic metric, and manually set?
SNOWTREK.org
Old 12-14-2018, 12:10 PM   #24 (permalink)
Member # 9467
Yes. I changed the onboard NIC to 50 and the wireless NIC to 5. Rebooted and no change to the boot order.
Old 12-14-2018, 12:16 PM   #25 (permalink)
Member # 848
Can you share the name of the software?
SNOWTREK.org
