Anybody know about Dry Ice blasting to clean - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2019, 11:27 AM   #1 (permalink)
angryblack's Avatar
Member # 142394
Im looking into this for surface cleaning. https://en.wikipedia.org/wiki/Dry-ice_blasting
Anybody have any real world insight?
angryblack is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:37 AM   #2 (permalink)
Member # 54386
Send a message via Yahoo to wolfe_man
Used to use it here for cleaning molds and machines used for making foam products (cleaned off the release wax and cured foam). Worked well and didnt destroy the molds/equipment, issue was slow (machine we have has a maybe 1.5" round cleaning blast) and pain to get dry ice when we needed it. We went back to using a cleaning solution.
If an idle mind is the Devil's playground, then mine's Disneyland!
wolfe_man is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:37 AM   #3 (permalink)
Member # 101407
It's loud and does a nice job of cleaning what your pointing it at. Everything around said object gets covered in what ever got blasted of it.
We use it on our Weld fixtures, Mills etc here at work. 30 feet away looks like it's covered in Fly shit.
Elvis38 is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:40 AM   #4 (permalink)
Member # 182717
What are you trying to clean?
We subcontract out bit of this work for industrial cleaning (Commercial Heat Treat shop). It's my preferred method of getting nasty stuff cleaned up. No water to mess up electronics, and can be as forceful or gentle as needed and in the end, you just have a pile of stuff to sweep up. Everything from cleaning old paintings to blasting 1" of oil crap built up on heavy equipment.
We use these folks where I work at:
https://starrco2.com/
If you are looking at units, Cold Jet is supposedly one of the better brands to rent/use/buy.
https://www.coldjet.com/en/index.php
Hope that helps.
Edit to Add: You shouldn't have crap blown everywhere if you have a good operator. It's just like any other type of blasting where if you don't pay attention to what you're doing, you can spray stuff everywhere. The nice thing about the Dry Ice is that the media disappears whereas other media (Sand, walnut, etc) just gets blown everywhere in the shop.
All our randomness and build threads can be found at www.MidwestNomads.com
Kage. is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:42 AM   #5 (permalink)
Corey Young's Avatar
Member # 21622
We had a company come in a few months ago and clean our rafters. There are open gears nearby so we didnt want anything pressure washed. They did a good job.
Old 01-23-2019, 11:49 AM   #6 (permalink)
Weasel's Avatar
Member # 5639
Can't you reuse sand/walnut for other blasting jobs? Dry Ice wouldn't be reusable. Interested in this as well and other alternatives to sand blasting.
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:53 AM   #7 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I've seen it used for that. Worked really well.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 11:55 AM   #8 (permalink)
Member # 13655
used dry ice to remove seam sealer in race cars prior to cage install and seam welding.
seen it used to media blast race cars too, not as abrasive as sand, probably more like walnut shell. You still have the removed material to clean up, but at least no media to clean up. Thought it required a special machine or at least adapter to work properly.
89 XJ, 8" lift, 38's, locked F&R
98 LR Discovery - street poser
99 F350 PSD 4x4 Jeep Tow Truck
2003 Mini Cooper S - street go-kart
2004 Subaru WRX STi - Vette eater
2005 Mini Cooper S - street go-kart on LSD
Pile of tube, 383 SBC, and some buggy plans
XtremeJ is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 12:08 PM   #9 (permalink)
angryblack's Avatar
Member # 142394
I will be using it in a food production facility. On a weekly basis. Contractual obligation prohibits me from saying more than that.
Preventing water damage is a huge plus.
Old 01-23-2019, 12:59 PM   #10 (permalink)
Member # 430242
Location: 4010′23″N 8458′39″W give or take a second or two
My dad does machine repair for a large-ish peoduction machine shop,they had a company that specialized in dry ice blasting come in to clean up a few used broaching machines before they set them up for production.
He said it did an excellent job knocking off the grease, dirt, and oils without damaging the equipment and he also said that the cleanup from the blasting was WAY easier to do than pressure washing or dry/wet media blasting.
projectdad is offline   Reply With Quote Quick reply to this message
Old 01-23-2019, 08:37 PM   #11 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
Yup, unless you have a steady demand/order the dry ice can be a pain to get. If you do not get the right size/type it will not work right. But it is not abrasive and does clean.
Stupid loud, and messy, but as stated if you point at it; it gets clean. but just that spot. got to be very meticulous on the cleaning pattern.
Clearly he did not have to clean it up.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is online now   Reply With Quote Quick reply to this message
Old 01-23-2019, 10:59 PM   #12 (permalink)
billdacat's Avatar
Member # 72617
Must be a top secret Cheetos factory???
Сделайте Америку отличной снова
billdacat is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 04:08 AM   #13 (permalink)
redsand723's Avatar
Member # 222933
Location: southern illinois (no where near that shit hole chicago)
I use to dry ice blast, its loud but works really good. Make sure you can ground it well, because the static buildup will knock your dick off
Sent from my SM-N950U using Tapatalk
Sent via smoke signal
redsand723 is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 04:24 AM   #14 (permalink)
Mopar Moe's Avatar
Member # 653210
I've tried to re-claim this stuff before, the success rate is depending on the type of material your blasting ,its very hard to get the contamination out of the media...I'm talking of a total loss blast , not in a cabinet..( it needs to be a spec size to get through the gun ) We have a huge steel shot booth (20" wide x 30" deep ) it has conveyers and with a separator to recycle but any garnet or glass bead is just sweeped up and tossed out (different booth).
Causing spontaneous disassembly in various motorsports for over 45 years
Mopar Moe is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 04:41 AM   #15 (permalink)
45acp's Avatar
Member # 13671
We had/have these for cleaning tire molds without removing them from the press. They work great. Earplugs AND muffs- no joke. Loud is an understatement.
45acp is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 04:49 AM   #16 (permalink)
comeonstart's Avatar
Member # 49939
So why is it more messy? I would have assumed it would be quite cleaner.
comeonstart is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 10:00 AM   #17 (permalink)
Member # 430242
Well considering he's 3rd in seniority right behind the top 2 execs I'm going to venture a guess that Dad hasn't been behind the controls of a shovel or broom in a couple of weeks at least
As for the easier cleanup from the way it was described to me, it was more of a statement about overall amount of material that needed cleaned up.
Although I am working with second hand information here so my accuracy may be off a bit.
Old 01-24-2019, 10:12 AM   #18 (permalink)
Member # 63333
We do too.
I am not sure where they get the dry ice, it comes in small pellets.
Morton IL, 93 YJ
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 10:16 AM   #19 (permalink)
78bronco460's Avatar
Member # 9152
I’ve had them come in and start that shit when I’m working on industrial coffee roasters that are down. The flying debris and noise is ridiculous.
78bronco460 is offline   Reply With Quote Quick reply to this message
Old 01-24-2019, 10:20 AM   #20 (permalink)
welndmn's Avatar
Member # 398
I have worked in 2 places where we used dry ice in rice form for cleaning.
One was for washing food grade processing equipment, the other washing nasty undersides of rail cars.
It works great in an industrial setting.
Bonus, the little dry ice rice chips are great in your cooler for quickly chilling your beer.
Mark
Old 01-24-2019, 10:22 AM   #21 (permalink)
45acp's Avatar
Member # 13671
Originally Posted by TSEJEEPERS View Post
We do too.
Ours uses the 50lb blocks, grinds it like a shaved ice machine. I'll say this... the 20oz dasani water bottle holds the most pressure before letting go compared to all other vending machine drink containers. So if you're looking to get a supervisor to shit his pants... go with dasani.
Old 01-24-2019, 11:12 AM   #22 (permalink)
Member # 182717
As Mr. Moe mentioned, it is application specific. Generally it doesn't seem to be worth while to try to reclaim the media for use later on.
Old 01-24-2019, 12:41 PM   #23 (permalink)
Member # 63333
Try wrapping the bottle in duct tape first.
The plant manager put a stop to those when he told us he would call the law if it happen again.
Ours will use the blocks too but they found the pellets worked better. I do not remember why.
I am not one of the ones that use the machine, I work in production in curing.
Morton IL, 93 YJ
