Tractor project opinions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2019, 05:44 AM   #1 (permalink)
Mr.RatBastard's Avatar
Member # 9307
This popped up this morning and looks interesting https://mobile.craigslist.org/hvo/d/...845484565.html
What kind of disaster might I be getting into?
Suggestions of what to look for if I go check it out?
Potential good deal if I do all the work?
Run away or go get it?
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 05:53 AM   #2 (permalink)
Member # 17378
That thing is beat for 400 hours.
Lucas trucks are usually dead simple to figure out, there aren't many things to go wrong with them.
Mercedesrover is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 05:55 AM   #3 (permalink)
ckupq's Avatar
Member # 121718
For that cheap assume that there is a rod hanging out the block that no one noticed.
ckupq is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 05:59 AM   #4 (permalink)
Member # 9307
It looks like it had a rough life for sure.
Old 03-20-2019, 06:01 AM   #5 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Poor thing has had a rough 400 hour long life.
I'd want to know why the "freeze plugs" are partially out. If the coolant froze and busted them I'd want to know that the rest of the engine holds water. If the engine is fine and just needs plugs put back in it it would be a pretty good deal. If it needs the block welded or replaced, it's an okay deal for someone needing that tractor.
4wd adds value. I'm not sure if the loader scv was standard on that tractor, most of the time it wasn't and is expensive to add so having that is nice so you can add a loader later. I'm suspicious that it had a loader on it at one time, might be worth asking if it could be added.
If it fires up, pull the dipstick and check for blowby. As long as nobody has cracked a piston with ether (btdt), those yanmars are pretty well bullet proof and 400hrs is nothing. It will still be running strong at 4000.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:04 AM   #6 (permalink)
Member # 157355
I am very skeptical of the hours.
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:18 AM   #7 (permalink)
Member # 118035
I bet it was rolled and started back up immediately after with starter fluid.
I haven't looked into the dog laws....except for the one about fucking them.
IEATRKS84 is online now   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:22 AM   #8 (permalink)
Johann's Avatar
Member # 4251
I'd check to see if the hour meter is unplugged. It was on my JD lawn tractor when I bought it. The paint wear below the pedals make me think the hours are a bit off...
Looks like whom ever owned it couldn't drive for shit.
Factor in that JD parts are more expensive than vehicle parts. The radiator on mine cost more than one for my Dakota!
Need reloading dies, brass and such for .351 WSL- PM me with what you have.
Johann is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:26 AM   #9 (permalink)
Total Asshat
Mopar Moe's Avatar
Member # 653210
If it was near me Id be hard pressed not to pull the trigger, that's a nice size tractor.
like the yuper said .., check for blow by and load it up on your trailer.
Causing spontaneous disassembly in various motorsports for over 45 years
Mopar Moe is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:32 AM   #10 (permalink)
Member # 42551
Must've had an exceptionally hard 409 hrs . Not saying it not true but it looks more like 4409 hrs to me .i would check the price of a complete engine before i got too excited . Just in case its damaged beyond repair .
HILL1HM is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 06:33 AM   #11 (permalink)
Member # 9307
I just talked to him on the phone. He said a guy is coming to look at it and in 30 minutes and he will let me know if he buys it.
He said he hasn't owned it long and doesn't know much details. He did say there is some water in the oil so I guess that means a cracked block or head? Probably a deal killer.
Old 03-20-2019, 06:40 AM   #12 (permalink)
Member # 9307
Crazy they have a long block on Alibaba for $1600 with $1000 shipping
https://www.alibaba.com/product-deta...166a14cbG37eIl
No luck on a used engine yet I just thought that was pretty weird.
Old 03-20-2019, 07:19 AM   #13 (permalink)
Member # 7412
he knows more than he is letting on. but that is still cheap. that is the standard for i am not responsible for any of this shit line.
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 07:19 AM   #14 (permalink)
Member # 118035
itll be gone. its how it always works
Old 03-20-2019, 07:35 AM   #15 (permalink)
Member # 90667
I've had 2 JD tractors so far that the hour gage did not work. My current JD 950 stopped at just 609 hrs. BUT I also found the wiring to all be fubar'd. So possibly expect wiring issues although these things are pretty simple to rewire. So easy that there's no aftermarket harnesses to be had. Usually 6-8 wires if you don't swap to a 1 wire alt while you are at it and drop that down to like 5 or 6.
There's a couple tractor forums with individuals that have access to all the manuals and they don't hesitate to pass out free pdf's of the entire manual. I've never had issues getting one for every piece of equipment I own.
And I will add the damage to this machine is minimal compared to 90% of the working tractors in my area when I was looking. The sheet metal is very thin on these and can dent by just sitting your beer down.
Freeze plugs is 99.9% insurance to the block. I would never hesitate buying a vehicle (or tractor) with one out. It's when they stay in is when damage occurs. There's usually an underlying cause usually a leak somewhere and the owner only filled with water. Most likely the radiator needs servicing. Simply knock all of them in and pull back out with channel locks and replace. Then fix the leak.
I'd be all over this personally if I had the time. Especially if it still cranks and runs. I bought a truck once like 5 miles away without a freeze plug and drove it home by hooking up a temp gage and shutting it down when it reached 200+/-. Think I only had to shut it down once and wait a while to drive it on home. That was back when I was parting trucks and buying anything without worries for the right price.
Gittinwidit is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 07:56 AM   #16 (permalink)
Member # 9307
What about the water in the oil? The first guy is thinking about it.
Old 03-20-2019, 08:02 AM   #17 (permalink)
Member # 86724
this.
that thing looks more like a 2400 hour machine.
it's a good deal if ALL that is wrong with it is the casting plug, but I'm gonna bet it turns into a money pit, otherwise the current owner would spend the $500 to have someone replace all the plugs.
Old 03-20-2019, 08:03 AM   #18 (permalink)
rockbuggy84's Avatar
Member # 45202
Blocks likely cracked. Swapping an engine in a tractor isnít exactly cheap or easy. Iím gonna bet that youíll easily be into this tractor 8-10k by the time you get it running reliably. Thatís not counting the hours youíll spend working on it.
"Whiskey is cheap, Talk cost money"
rockbuggy84 is online now   Reply With Quote Quick reply to this message
Old 03-20-2019, 08:52 AM   #19 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
My bet is also fubar'ed or unplugged hour meter.
That thing's been whored out.
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 09:04 AM   #20 (permalink)
Member # 70148
I'm suspicious of that alibaba link, especially since they list a dozen different engines. Would be a good deal if it was.
I rebuilt the 3tne84 in my 4300 for around $1500, but the block wasn't cracked. Splitting the tractor to pull the engine wasn't fun, but doable in a home shop with an engine hoist and a floor jack and jack stands. Pulling the cab was a major part. The JD manuals are critical to have, but not always accurate as far as procedures go. I.E. the manual for my 4300 didn't say the fuel tank had to be pulled (1+ hour job on a 4x00 plus pulling the cab) to get the head off because they forgot about the bolts in the back of the head that go to the tank bracket.
Old 03-20-2019, 09:12 AM   #21 (permalink)
Member # 48233
This is more like it when it comes to lower hour tractors
https://washingtondc.craigslist.org/...832589886.html
[quote=texasblake;11194923]
they may be waving like mccain for the rest of their life, but you taught them an important life lesson and they had fun doing it.[/quote]
[QUOTE=xyjbeaker;9759686]"mexican food reminds you of my face?"[/QUOTE]
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 09:42 AM   #22 (permalink)
Member # 2710
If it's fixable, that tractor is worth about $10k or better, assuming the hours are correct. It does appear to have been a rough 400 hrs, likely not operated by the guy that paid for it. I have the orange variety, same size, a year newer with 400 hrs. Mine looks new, but it's kept inside and I don't beat it up.
1986 Toyota PU 4x4
2008 Toyota Crew Max PU 4x4
ToyFord is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 09:52 AM   #23 (permalink)
Member # 34865
No way in hell that has only 400 hrs on it. Wear below the pedals says that. 400 hours and oil caked on the engine? No way. Might want to visit Danís rebuild a deer 410b thread. Buy it and start a rebuild from front to rear thread.
Lindon, Utah
rockdog57 is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 09:58 AM   #24 (permalink)
Member # 86724
that's standard alibaba shit.
they list the price low and then cover the rest of it with shipping so their results can be first.
Old 03-20-2019, 10:00 AM   #25 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
for that price i'd be picking it up. i've made really good money in the past rehabbing compact tractors.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Similar Threads
opinions wanted: initial d44 gear mesh pattern critique - tia jon84cj Newbie General 4x4 Discussion 4 06-26-2017 08:31 AM
front locker opinions needed luked Jeep - Non Hardcore 29 06-19-2015 01:04 AM
OPINIONS PLEASE Late Model SFS Swap Kits AmericanMade717 General 4x4 Discussion 8 01-16-2014 09:02 PM
Opinions on a work side by side wanted RustyNailJustin Side by Sides 19 09-28-2013 07:33 AM
