GMT-800 Blend Door issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-24-2019, 07:27 AM   #1 (permalink)
Damn kids
plym49's Avatar
Member # 162771
GMT-800 (2004 Suburban) blend door issues.
Initially, would not direct the air to the floor, but that was the only problem.
Now, while that issue persists, only cold air is available from the dash vents or defroster.
The rear seat system gets heat.
Heading to Vermont so wondering if there is a way to address without ripping the dash out. All I really care about is heat for defrost, I can live without the rest of it for now.
Have seen conflicting information on line - blend doer motors easily accessible behind the radio or glove compartment, or rip the shit completely out.
Thanks in advance.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 07:43 AM   #2 (permalink)
Member # 3132
Rip it all out.
I just did a blend door motor heat/cold on an 02 Silverado. It was at the bottom middle with 2 7/32" head screws.
Make sure the actuator is centered, do not plug in to do this, or plug in the check operation. Out of the box centered is the best, but if it needs to be manually done, take the cover off the actuator, slide the motor out, and adjust the geared assembly.
Old 03-24-2019, 07:50 AM   #3 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Originally Posted by NOODLES View Post
Rip it all out.
Great. Is there a way to poke in from somewhere with a hook to pull the flap over?
Always tip.
Old 03-24-2019, 08:17 AM   #4 (permalink)
Member # 106178
If it is single zone HVAC the temp motor is stupid easy on them. 10 minutes and it is done.
takotruckin is online now   Reply With Quote Quick reply to this message
Old 03-24-2019, 09:14 AM   #5 (permalink)
Damn kids
plym49's Avatar
Member # 162771
It is a single zone. Where is this motor of which you speak?
Always tip.
Old 03-24-2019, 09:26 AM   #6 (permalink)
Member # 200906
I wouldn't worry about heat. Temps have been in the 30s to 40 with 50s coming in next week.I have been working outside today in just a tee shirt. You won't need your heat.
When Canada takes over the world, everyone will be sorry.
Daveinvt is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 09:33 AM   #7 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Does one motor control the direction of the air and a different motor control the temp of the air?
Always tip.
Old 03-24-2019, 10:25 AM   #8 (permalink)
Member # 106178
Yes. Temp motor is bolted to the bottom of the case just to the passenger side of the dash. The mode motor is bolted to the drivers side of the case above the accelerator pedal.
Old 03-24-2019, 11:45 AM   #9 (permalink)
Damn kids
plym49's Avatar
Member # 162771
So then both are accessible without ripping out all the shit? I don't see how I can fit my hands up in that tiny space above the gas pedal.
Always tip.
Old 03-24-2019, 11:52 AM   #10 (permalink)
Member # 79509
No, you start by removing the passenger rear tire. Its an odd process.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 11:56 AM   #11 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Hey, it's not a Land Rover.
Always tip.
Old 03-24-2019, 12:15 PM   #12 (permalink)
Member # 18369
I have to replace my actuators also. Froggy is a little slow but this should help you
Wazzobie is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 12:19 PM   #13 (permalink)
Member # 3132
The knob that the actuator slides over can be moved by hand. At least the temperature blend door can.
It is easier if the fan is not running when you try and do this.
Old 03-24-2019, 12:25 PM   #14 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Some 800's have a cover that runs from pass to drivers side toe kick area you have to pull off first. 7/32" head screws iirc. Once that's off it should be easy.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 02:23 PM   #15 (permalink)
Member # 199544
Originally Posted by Daveinvt View Post
I wouldn't worry about heat... Blah... Blah.... Blah....You won't need your heat.
Hey n00b !! We need it to rid of the morning dew/fogged up moisture-
det107 is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 02:57 PM   #16 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Best news yet.
Always tip.
Old 03-24-2019, 03:10 PM   #17 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Originally Posted by Wazzobie View Post
I have to replace my actuators also. Froggy is a little slow but this should help you https://www.youtube.com/watch?v=pgadjXyqjbA
Holy crap, slow is not the word. Plus, referring to himself in the third person. What a maroon. Thanks for posting, though, if my 2004 is the same I should be able to swap out both blend and mode actuators.
Always tip.
Old 03-24-2019, 04:02 PM   #18 (permalink)
Member # 200906
Sorry, I forgot you new yucker don't have the common sense to open a window to clear the fog from all that hot air you blow.
Similar Threads
Figuring out the tipping point of when to sell off your older truck for a newer one Otto Man General Chit-Chat 84 12-27-2017 09:44 PM
RZR 800 A-Arm Brackets yotabuggy85 Side by Sides 3 03-15-2017 10:28 PM
Replacement hot/cold blend door '99 Silverado ToughBowtieTruck Chevy 3 07-10-2014 05:14 AM
Scout 800 parts for sale (Fremont ca) REDSKY1085 Engines/Trannys/T-Cases For Sale 1 05-09-2013 07:31 PM
RZR 800 vs RZR 800 S? DMG Side by Sides 18 10-15-2012 03:02 PM
