Tech in GCC - 2005 BMW X5 3.0 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-27-2019, 07:33 PM   #1 (permalink)
Pavement Challenged
71PA_Highboy's Avatar
Member # 73465
Coworker needs fuel injectors according to the stealership... $1200
Never done BMWs, but have done FI before in 90's 5.0 Fords
Should I help or run away? What would I be getting into if I undertook this job?
No pics of coworker - he's not my type....
@Halogrinder
Got Ford?
68 & 69 Bronco, 70 Mustang, 94 Ranger, 71 F250 4x4, 94 Lincoln Mark VIII, MEP-803A - BF NC
This country is trying to childproof the world when they should be worldproofing their children.
71PA_Highboy is offline   Reply With Quote Quick reply to this message
Old 03-27-2019, 07:47 PM   #2 (permalink)
Member # 86724
it's not diesel right?
it should be cake on an m54.
Old 03-27-2019, 08:30 PM   #3 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
It doesn't need injectors.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 03-27-2019, 08:40 PM   #4 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
yup pretty common, do the valve cover gasket while in there.
More common that you thinks. But coming from the dealership I would be semi hesitant, however def a known issue.
Cheap after market, lots of BS work to do but nothing difficult, lots of info on the google box.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is online now   Reply With Quote Quick reply to this message
Old 03-27-2019, 08:48 PM   #5 (permalink)
yozsi's Avatar
Member # 91857
Not really, I've seen singles take a shit. Only reason I can think is that it has a po171/172 and they wanna shotgun a set of injectors in. Prolly just needs the cbpv/valve cover done.
Foreign Car Center
Vallejo, CA
Old 03-27-2019, 09:07 PM   #6 (permalink)
DozerDan's Avatar
Member # 9144
Def could be just a single one, but they are gonna upsell.
Dan Smith
Old 03-27-2019, 09:16 PM   #7 (permalink)
yozsi's Avatar
Member # 91857
Yep. Typical dealer bs eh?
Foreign Car Center
Vallejo, CA
Old 03-27-2019, 09:19 PM   #8 (permalink)
Pavement Challenged
Member # 73465
It runs like crap... I heard it when he drove in, and asked what was up... that is when I got the story... Unless cbpv can cause a significant change in how it runs....
And it is not diesel.
Got Ford?
Old 03-27-2019, 09:54 PM   #9 (permalink)
Member # 106178
Another vote for “it doesn’t need 6 injectors”.
They are probably easier to replace than on a 5.0 Ford.
takotruckin is offline   Reply With Quote Quick reply to this message
Old 03-27-2019, 10:09 PM   #10 (permalink)
yozsi's Avatar
Member # 91857
Yep, it can. When the pcv system takes a shit the fuel trims go all whacko
Foreign Car Center
Vallejo, CA
Old 03-31-2019, 08:31 PM   #11 (permalink)
Pavement Challenged
Member # 73465
The videos I watched indicated excessive smoke with a PCV issue.
Guy only has 1 vehicle, so trying to make sure I am right before I start in and leave him stranded.
Am I overthinking it?
Got Ford?
Old 03-31-2019, 09:48 PM   #12 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
I know nothing about those but aren't there any codes? I'd think it would tell you which are bad...
We had part of a slinky. But I straightened it.
Subybaja is online now   Reply With Quote Quick reply to this message
Old 03-31-2019, 10:15 PM   #13 (permalink)
Member # 86724
they're also known for leaks in the intake manifold.
check the rubber boot elbow thingy thoroughly, especially the y piece that comes up to the idle air valve, and where the disa plugs into the manifold.
nows the time to build a paint can smoke machine.
I would think that a dealer would have checked it, since they're known issues, but you never know.
Old 03-31-2019, 10:16 PM   #14 (permalink)
Member # 86724
and regarding codes.
tell dude to buy a $20 kcan adapter on amazon, and setup ista on a laptop.
tell you everything you need to know. The obd codes are pretty useless.
Old 04-01-2019, 02:26 PM   #15 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
ISTA is a pain in the ass for a n00b to set it up.
M54 doesn't need injectors. maybe 1, not 6.
probably needs a PCV system under the intake.
Throw a DISA valve in it too.
Replace the air boot to the throttle.
MAF would probably be good to clean at least if not replace.
Where are you located I'll see if I know an indy shop near you.
gun facts that will blow your mind:
Halogrinder is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 04:18 PM   #16 (permalink)
Member # 86724
It's not that hard.
it's the cheapest route.
if money is less important than time and effort, then buy the bimmergeeks shit and protool.
Old 04-02-2019, 09:05 AM   #17 (permalink)
Moderhater
Member # 16980
It's not that hard.
No, go find a competent indy and let him fix it is the correct answer.
Old 04-02-2019, 09:12 AM   #18 (permalink)
Member # 86724
well, yeah.
but what fun is that?
Old 04-03-2019, 02:26 PM   #19 (permalink)
Moderhater
Member # 16980
bump to see if they called the contact I gave him.
Similar Threads
GCC tech but not really tech thread. Again. posford General Chit-Chat 30 06-24-2017 05:50 AM
Tech in GCC Version 235666413 posford General Chit-Chat 41 03-16-2017 06:53 AM
Ford Ranger Tech 3.0 or 4.0 v6? FUK V2.0 General Chit-Chat 13 03-04-2017 08:46 PM
not too much tech in GCC bremen242 General Chit-Chat 0 10-16-2012 05:52 PM
tech in GCC: steering alignment Fredy_C General Chit-Chat 10 05-02-2012 09:10 PM
