Poly "hockey puck" bushings in DD - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-03-2019, 10:42 AM   #1 (permalink)
[Memphis]'s Avatar
Member # 49281
I need to replace the bushings in my Corolla. 2015; nobody makes an aftermarket bushing... the rest of the arm is fine. I measured a control arm bushing from 2013 and it SHOULD fit as the diameter is the same unless the OE sleeve is welded in.
If that's the case poly bushings should fit the later arms but I'm slightly worried about tweaking the tinfoil mounts... anyone have any insight? Otherwise I can toss mevotech arms in it and replace them yearly
Toyota OE arms w/o BJ $251 CAD each and the left is on back order... AKA they are having problems
Mevotech $50ea
Driving a 5.3L 4x4 el camino wrapped in tupperware :homer:
[Memphis] is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 11:12 AM   #2 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
how many miles are you doing a year?
i've had good luck with the Mevotech stuff. For the price difference I'd give it a try
76 Scout, 85 Toy. 94 Cherokee ALL SOLD
Resident Web-Wheeler
budget76 is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 11:33 AM   #3 (permalink)
[Memphis]'s Avatar
Member # 49281
16k miles a year
I sell Mevotech but I've seen premature failures. Had one today, same application (albeit it was a cabbie) 3 months and it's got play in it. If I could get TTX Mevotech for my application I would run it
Old 04-03-2019, 12:41 PM   #4 (permalink)
Member # 112738
Originally Posted by [Memphis] View Post
16k miles a year
I've seen a bunch of negative publicity aimed at mevotech on the 1st gen Tundra FB page. Lots of reported failures. I made the mistake of installing a mevotech lower ball joint in my truck, but it hasn't had any issues in the 6 months since I installed it.
zlathim is online now   Reply With Quote Quick reply to this message
Old 04-03-2019, 01:19 PM   #5 (permalink)
94toytruck's Avatar
Member # 18614
Mevotech is hit or miss like the rest. I put a arm in a Cube and the customer came right back saying it was making noise. The rear bushing came right out the arm, it didn't even fit tight. I could tap it right through easily. I see a ton of these things getting swapped in general and most aftermarket parts suck.
If It was mine I'd just knock the new bushings in. Back in the day before everyone got lazy we used to do bushings all the time not sling control arms in. I still do Subaru bushings often cause for some reason the arms are really pricy and bushings are cheap. Just knock em out with a air hammer and press new ones in.
Eric
94toytruck is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 03:15 PM   #6 (permalink)
[Memphis]'s Avatar
Member # 49281
The +2014 arms do not have service-able bushings according to the dealer.
Older model bushing looks like it would fit. Maybe I should press a Johnny joint in there
Old 04-03-2019, 04:07 PM   #7 (permalink)
Member # 128362
The TTX stuff holds up half decent on our SD fleet trucks but I flat out refuse to run mevotech tie rod ends.. they’ve chewed a few knuckles to shit on us.
Had some mevotech douchebags show up for a demo at our shop last summer and all I kept thinking was it’s junk and then they showed the ttx stuff so we gave some of that a try and so far so good..
01 Cummins QC 4x4 - Tow Rig/DD/trails wheeler
97 TJ - Gerbil - Being rebuilt
Macneil is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 07:17 PM   #8 (permalink)
94toytruck's Avatar
Member # 18614
I'll look tomorrow at one, we typically see a shit load of those. I have a friend that works for Toyota if worst comes to worst.
Eric
Old 04-04-2019, 02:12 PM   #9 (permalink)
Member # 91648
If you find bushings, it is servicable. Dealerships seem to call every control arm bushing non-servicable anymore.
GMGuy is offline   Reply With Quote Quick reply to this message
Similar Threads
Bushed Sleeves & Poly Bushings! Gravel Maker Suspension 130 01-02-2019 01:41 PM
Source for big poly or rubber bushings? How well do they hold up on radius arms? 78stepsideUAK10 General 4x4 Discussion 19 02-04-2017 10:03 AM
Panhard bar. Heims or poly bushings? dirtdonthurt General 4x4 Discussion 19 02-23-2012 12:49 PM
