Looking for a Suburban or Yukon... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2019, 06:28 PM   #1 (permalink)
Member # 226216
Ok been looking for a heavier rig for my wife to haul the kids around in. Currently she has a 3rd gen 4runner. She likes my 99 5.3 silverado so that generation and newer work fine. Been looking at them in the 2-5k range for that generation knowing I will have to do a trans sooner than later.
A 09 just popped up for 6k. Has 200,000 miles and an automatic.
What are the hickups for that generation
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 06:43 PM   #2 (permalink)
Member # 53453
Apparently it has already blown up because on the DOD and you shouldn't buy it. A Toyota for 10x the price would be great though.
DirtyComanche is online now   Reply With Quote Quick reply to this message
Old 04-08-2019, 06:44 PM   #3 (permalink)
Member # 3132
I am sure some forum reading clown that has no mechanical experience will come in and call it a GMT something or other, and post someone else's experience with the rig.
With that said,I would buy it. Good vehicle.
Old 04-08-2019, 06:44 PM   #4 (permalink)
DMG
Member # 8145
They were pretty crappy after the GMT800. I would pass.
DMG is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 06:46 PM   #5 (permalink)
DMG
Member # 8145
Or an ex GM master tech.
Old 04-08-2019, 07:03 PM   #6 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Lots of minor stuff goes after 200k so it's a crap shoot. How do the front doors hang? Usually by then the pins/bushings are shot.
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 07:12 PM   #7 (permalink)
Member # 55396
07-12 gm; assume it needs a motor or will in short order. unless there's a documented replacement motor or DOD delete.
The dash of that vintage will crack; just a matter of time.
Those wheels at that price look like trouble in my gut instinct. (eta- why isnt there door trim on the rear door? rear qtr collission? I love me crashed shit for cheap, but crashed shity halfassed repaired with rims = double trouble IMO)
The top of the line door panels in that era trim still look like work truck shit...
personally, I'd find the most cherry 00-06 you can and count on it to go ~300k reliably, maybe with a trans around 200k, and other misc small shit... Or if she wants fancy shit and the space works go shopping for a sequoia/ landcruiser. yes they're thirsty, but the cost of a replacement motor buys a lot of gas...
If you're dead set on a burb/yukon XL, go 09+ so you get the 6 speed trans and cooled seats in LTZ trim, and know the motors on borrowed time.
Collector of the LS powered Chebby soccer mom coach.
WTF? is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 07:22 PM   #8 (permalink)
Member # 130483
What WTF said
Find a 00-07
Keep $2k saved for a trans or 4L80 it
Pump rub fix
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 07:42 PM   #9 (permalink)
Member # 18282
Most of the hvac control stickers will be gone too. Good times just blindly punching buttons waiting for the air to come out of the right vents. Lol
I'm what you call your basic famous.
Stix is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 07:48 PM   #10 (permalink)
Member # 55396
Originally Posted by 92 s dime View Post
Find a 00-07
{nitpicking} It's 00-06 for the burb/tahoe/ yukon/xl
There were no 07 classics in the SUV's
Old 04-08-2019, 07:55 PM   #11 (permalink)
Twankie's Avatar
Member # 230823
My mom has an 07. Has needed a brake switch (causing cruise control to not work. Minor) broke timing chain tensioner and a tooth off cam gear around 120k. Shop said it needed a motor. I replaced chain, cam gear, pickup tube o ring, pan gasket, and put in a ls2 chain dampener for less than a few hundred bucks. Needed an oil pressure sender and trans lines but no other issues. Stock trans even going on 200k now. Need to tune out the dod before a lifter fails soon but it has been pretty solid.
Twankie is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 07:59 PM   #12 (permalink)
Member # 55396
is it using a quart of oil/ tank?
Old 04-08-2019, 08:01 PM   #13 (permalink)
Member # 226216
What WTF said
Find a 00-07
Pump rub fix
This is what I am going to do 99%.
I already have a 5.3 Silverado so its kinda the same. Want to 4L80 and cam and tune mine and same with a suburban if we get one. Looking at the newer interior, 02-03?
My first rig was a 83 2wd 6.2. (I was going to put a 12v and 60’s on it, parents did t think I needed a 4wd so I was going to make one. the gig was up when I brought home a front axleI and dad saw it sitting in the garage. I still got a few custom bent tools floating around somewhere from that rig.
Old 04-08-2019, 08:18 PM   #14 (permalink)
Member # 55396
... Looking at the newer interior, 02-03?
Redesigned interior was 03-06. They are less rock solid than the 02-down; a few minor issues like auto climate control gremlins, dashboards that need to be rebuilt by 150k & finicky seat heaters. but all well documented, & relatively cheap/ quick fixes.
07-08 you get the same trans & a DOD motor with a shittier IMO interior. 09+ you get the 6 speed trans but still a DOD motor that gets 2-3 mpg better on the hwy but i wouldnt trust one after 180k.
Old 04-08-2019, 08:35 PM   #15 (permalink)
Twankie's Avatar
Member # 230823
No
Old 04-08-2019, 08:38 PM   #16 (permalink)
Member # 55396
No
Your folks must have got one of the good ones; but a 200k 07-08 that doesnt guzzle oil is certainly a rarity.
Old 04-08-2019, 08:58 PM   #17 (permalink)
Member # 52361
99-06 are great 07+ are shit for all the reasons listed.
Buy the lowest mileage older one, buy an OEM fuel pump and install it on your schedule. Stick 2k away for a factory re man 4l60e, and just do the pump rub kit and fresh oil.
At 200k these need head gaskets, not blown out, just steady consumption. I drove mine 200 miles from home in the summer, knowing I'd need a half gallon of water when I got there
Mine was great, but needed enough little things that I bought a sequoia, with the same mileage
PROJECTJUNKIE is online now   Reply With Quote Quick reply to this message
Old 04-08-2019, 09:03 PM   #18 (permalink)
Member # 113619
Send a message via Yahoo to stjames151
There’s no suburbs in the Yukon from what I’ve seen
[QUOTE=Roc Doc;11597106]This is so weak it makes Richard Simmons look like he's UFC ready.[/QUOTE]
[QUOTE=ironpig70;13786791]But it renforces the point to kids guns are toys.[/QUOTE]
stjames151 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 02:09 AM   #19 (permalink)
Member # 54455
This is the main reason I never bought one. Every single used one looks like shit inside with the buttons rubbed off.
Boats n Does
Deuce 40s is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 04:38 AM   #20 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
For $10 on Amazon you can buy vinyl stickers for the HVAC buttons. Looks brand new. Our 08 is great. Definitely some GM quality things that piss me off, but it’s solid, comfy, and parts are hilariously cheap for it. Go look on rock auto, the whole front end kit (control arms with ball joints and all the rod ends) is like $350 for the quality stuff. I threw a range tech dongle onto the OBD port and DOD is disabled. Doesn’t burn a drop of oil. With that one being an 09, you get the beefier 6 speed. If no red flags, that’s a steal. If the DOD has fucked the lifters and coked up the rings, you are looking at about $1500 to get all that shit straightened back out, so make your judgement call on that.
JeffsJeep04 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 04:50 AM   #21 (permalink)
Rooney77's Avatar
Member # 82435
I recently bought a 2012 ltz suburban with 117k miles. So far the only lasting issues are some carpet stains and a cracked dash. My single biggest complaint is the lack of Bluetooth streaming ability but that's 1st world problems. The dash I fixed with some epoxy and the carpet will get shampooing.
I can't speak to the dod since my cluster shows it always being in v8 mode but I could be wrong in assuming that it'll show if it lowers the displacement. This is my first chevy so I'm not really up to speed on them.
flatfender FOR SALE
51 Ford
81 Cherokee
Rooney77 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 09:52 PM   #22 (permalink)
DR. SMASHER's Avatar
Member # 95939
I'd buy that and swap in a Duramax and Alison.
"Don't you have a plan B? .. Yes my plan B was reinforcing plan A."
As the slaughter of WW2 fades, the young gear up for something they will wish they had not wished for.
I hope the little stickie out leg on the R gives you a rectal tear as you shove it up your ass.
DR. SMASHER is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 10:03 PM   #23 (permalink)
Member # 95939
This ^
Old 04-09-2019, 10:10 PM   #24 (permalink)
Member # 79509
I deal with these vehicles on a weekly basis, both wrenching and buying/selling.
900s are giant pieces of shit. No reason to own one.
800s are also giant pieces of shit. But the cost of maintenance is very low. Hence their popularity. You already own a 99, its all the same issues... any fix is $25. Ive gotten real good with adhesive, paint brush, and a spatula to fix the headliners.
I just picked up a 1 owner 2005 Tahoe Z71 with every option available, the sticker was $48,445. With 49,500 miles i paid $10k. Paying $6000 for a 200k mile vehicle is full retard.
Personal preference but a loy of these come with 3.42s and the torque comverter is constantly jacking off. I had the pleasure of owning one with 4.10s. EXACT same fuel mileage (15mpg) and a blast to drive.
If I was buying a burban, it would he a 2500.
Buy a sequoia instead.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 03:28 AM   #25 (permalink)
Member # 84917
I have owned a 2004 Denali for 3 years, and have put 100k on it this far. Currently the milage is 215kish.put a trans in it around 150k and a water pump around 140k, other than that just a tune up and brakes. It's our family traveling vehicle, and I absolutely love driving it.
If you live near Chattanooga TN, DON'T buy a car from Tim Short Mazda. Piss poor customer service!!!
Yesterday is History
Tomorrow is a Mystery
and Today is a Gift
That's why they call it the Present
blugreenformula is offline   Reply With Quote Quick reply to this message
Similar Threads
It's sale time! Gears, Lockers, Install kits!! CCOR Axles/Tires/Wheels 4576 06-21-2019 05:08 AM
CHEAP!!! Yukon Gear Axles, Lockers, Ring and Pinions and Spartan Lockers CHEAP!!! Baseline 4x4 Axles/Tires/Wheels 104 06-24-2015 06:26 AM
YUKON Zip & Grizzly Locker, SuperJoints, Axles, Ring & Pinions, Spin Kit,SALE PRICING Baseline 4x4 Axles/Tires/Wheels 83 11-29-2014 07:52 PM
Yukon Grizzly Locker CCOR Axles/Tires/Wheels 152 06-12-2013 06:22 AM
YUKON Zip Locker, Grizzly Locker, SuperJoints, Flanges, Ring & Pinions, SALE PRICING Baseline 4x4 Axles/Tires/Wheels 55 09-12-2012 01:37 PM
