Bending stainless - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2019, 06:42 PM   #1 (permalink)
Bo185's Avatar
Member # 48545
Bending stainless
How is the drain base bent to form a drain pan in attached photo? IE the process to make it.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 06:48 PM   #2 (permalink)
Member # 688970
What makes you think it's not pressed from a sheet?
santa V2.0 is online now   Reply With Quote Quick reply to this message
Old 04-24-2019, 06:49 PM   #3 (permalink)
popeye
yotee's Avatar
Member # 20027
this
Its a jeep, sand it with a brick- paint it with a broom
yotee is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 07:03 PM   #4 (permalink)
Wut?
Overbear's Avatar
Member # 20114
Pretty much this, form pressed.
“Christianity neither is, nor ever was a part of the common law.”-Thomas Jefferson, letter to Dr. Thomas Cooper, February 10, 1814,
When I'm the voice of reason, it's a pretty good indication that someone's doing it wrong.
Overbear is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 07:17 PM   #5 (permalink)
Bo185's Avatar
Member # 48545
Then how are the HVAC panels and vent a hoods which are bent in same way made? Press formed too?
Old 04-24-2019, 07:23 PM   #6 (permalink)
Bo185's Avatar
Member # 48545
The bent lip around the out side welded on, I know that as its was stated so. So I figured they bend the base then bent flange and rolled then welded it on.
Old 04-24-2019, 07:25 PM   #7 (permalink)
Antisocial
JMAN3203's Avatar
Member # 139337
Corner to corner in a brake.
Originally Posted by 45acp
I found out about him being an orphan Chinese immigrant. Dude worked the first half of his life in a dim overcrowded toy factory, scrubbing lead dust off of dolls. I can just see him over in the corner with his little asbestos brush and a bottle of formaldehyde cleaner...[...]
JMAN3203 is offline   Reply With Quote Quick reply to this message
Old 04-24-2019, 07:29 PM   #8 (permalink)
Member # 688970
Old 04-24-2019, 07:34 PM   #9 (permalink)
Member # 688970
Maybe, pics of underside would be helpful. I think that it could be pressed from a single sheet, the corner that looks welded may need to be in order to finish the piece.
Or it could be a couple pressings welded, but that would be time consuming and more expensive.
Old 04-24-2019, 07:50 PM   #10 (permalink)
Bo185's Avatar
Member # 48545
Caption on original photo.
“This isn’t a fold on four corners but a weld in some of the the seams.”
Similar Threads
Overland Metric: JIS Bolt Kits & Hardware | Stainless & Carbon Steel davework Miscellaneous 0 01-21-2017 05:33 PM
BK Stainless Tumblers and Koozies Only $20ea RockTacoAU Miscellaneous 2 05-16-2016 06:14 AM
Bending Edge - The new revolution in fabrication fabcam Tools and Supplies 0 06-12-2014 08:26 AM
Bending stainless or aluminum pipe another Lance Shop and Tools 5 10-16-2013 09:01 PM
Bending 1" stainless tubing with jd 2 foley Shop and Tools 5 03-29-2013 05:51 AM
