What mid size 4x4? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-30-2019, 06:39 AM   #1 (permalink)
Member # 11196
What mid size 4x4?
I'm currently in the market for a replacement vehicle and have the following criteria. It must be mid sized, have a transfer case, solid rear axle, be able to tow 4k lbs, and be reliable. This will be my daily driver and will also be used for vacations which can be 5k+ miles and in remote locations. Offroad use will be restricted to moderate trails, I have the juggy when I wan't to tear something up. I also have a Dodge diesel for heavy towing and work.
My first option is a new/used late model vehicle. I have test driven the Tacoma, 4runner, Ranger, Frontier, Colorado, and JL. Unfortunately I am too tall for the Tacoma, and I can't see myself doing long trips in the wrangler plus it's tow rating is low. My top picks were the Colorado and 4runner.
Option 2 would be to go back a few years and get something like the 4th gen 4runner with the V8, Xterra, or FJ Cruiser. I would then go through it with a fine tooth comb and replace any suspect and prone to failure parts.
Option 3 would be to go old school and upgrade/swap everything to newer parts including a LS engine. I have a rust free Scout that's been sitting on the back burner that I could use. The big downside I see is the lack of safety equipment and all it would take is someone to run a red light and ruin a lot of hard work and money spent.
Any suggestions?
YJ linked on 42's
Whiplash is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 06:44 AM   #2 (permalink)
Member # 85771
yes
Make Forums Great Again!
Old 04-30-2019, 06:53 AM   #3 (permalink)
Member # 148982
Absolutely!
R.I.P. Clark :smokin:
"]["{[]}{[]}{]_
Pat McRotch is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 06:54 AM   #4 (permalink)
Member # 96278
I dunno. I'm going with not really.
Drink to the dead all you still alive
We shall join them in good time
cj5.5 is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 06:54 AM   #5 (permalink)
Member # 860898
I own both a frontier and an LS powered scout and both are good rigs. The scout is much tougher and gets around easier. The frontier is more civilized and comfortable. Id drive either across the country without hesitation. That being said Id probably go for a late model 4Runner.
Jackie Treehorn is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 07:00 AM   #6 (permalink)
Member # 120626
definitely need a Prius
mechanicalmongoose20 is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 08:24 AM   #7 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
Well, it's got a solid rear axle, so that's one thing checked off
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 08:28 AM   #8 (permalink)
ADD
Member # 22080
4 door tacoma...even if your 6'6" you should be able to slide back for enough to fit nicely.
If still no...then definitely 4runner.
Got custom cab?
ADD is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 08:53 AM   #9 (permalink)
CJF
Member # 41971
Why?
Especially since you said you'd like a V8.
CJF is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 09:27 AM   #10 (permalink)
BIG-O's Avatar
Member # 109702
Does the scout have A/C? That would be a definite go/no go for me.
Why did god invent whiskey? So the Irish wouldn't rule the world!
BIG-O is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 09:35 AM   #11 (permalink)
Member # 55560
100 series land cruiser. 98s and 99s are really cheap right now and have an electronic rear diff lock.
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 10:25 AM   #12 (permalink)
Member # 133009
1st gen sequoia wouldnt be bad either
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 10:38 AM   #13 (permalink)
CJF
Member # 41971
Sorry; no.
Has to be midsize (for some reason...).
Old 04-30-2019, 10:59 AM   #14 (permalink)
Member # 55560
Sequoia isn't bad but has a smaller rear diff than the 100 series. The 100 is way overbuilt and I would consider it a midsize. It's definitely not as large as an expedition or a tahoe.
A bunch of old crap
Old 04-30-2019, 11:36 AM   #15 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
Just modify your body to fit into a Tacoma better.
JeffsJeep04 is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 11:36 AM   #16 (permalink)
Member # 11196
The steering wheel on the Tacoma won't tilt up far enough to clear my knees.
It has AC, I wouldn't consider it otherwise in Texas.
Originally Posted by CJF View Post
Sorry; no.
Full size sucks when parking, on the trails, and wouldn't fit on some of our ranch roads.
YJ linked on 42's
Old 04-30-2019, 12:49 PM   #17 (permalink)
Member # 122255
100-series is midsize. The current 4runner is pretty much the same size
'75 Hilux, '93 X-cab, '02 100-series
HighOnPottery is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 01:07 PM   #18 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Can-Am
& Blaine
:tank:
Old 04-30-2019, 01:13 PM   #19 (permalink)
Member # 79509
Learn how to drive. Some south texas pin striping wont kill you.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 04-30-2019, 01:14 PM   #20 (permalink)
Bo185's Avatar
Member # 48545
ZR2 has lockers front/rear also has 2.8L diesel option for better mpg will tow plenty safely. I am 6’6 and fit in a colorado just fine plenty of room. Reliable and comfortable daily driver. Also mpg of the 2.8L is great if hwy driving alot. Even the gas V6 version I get 25mpg avg on hwy trips and 20 avg in mixed driving.
'73 IH Scout II Vortec 6.0L 4L65e np241
'73 IH 1210 Travelette SV392 V8, T34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 01:19 PM   #21 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Ranger
& Blaine
:tank:
Old 04-30-2019, 02:10 PM   #22 (permalink)
Member # 774777
What size/kind of ranch do you have in TX that a full size suv wont fit on the roads? Hell my buddies family ranch will fit semis down the ranch roads and we take fullsize hunt rigs down all the two track.
Stuckntx is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 03:21 PM   #23 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Originally Posted by Beat95YJ View Post
Ranger
I really love my 1st gen ranger. I can't fault this advice at all.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 04:56 PM   #24 (permalink)
DT75FLH's Avatar
Member # 101209
this...
i bought a used 07 v8 toyota 4 runner and the mileage sucked and the power felt meh, the seats sucked on a 4hr trip (it was limited also )...not a big upgrade from my 98 4runnner with the 3.4. i was very disappointed.
i have a diesel zr2 now. great size for midsize for parking in town, and fitting in parking garages and tows my rzr and traier.
it also tows my off road trailer (about 2k) at hwy speeds and gets 18 mpg...towing with it in utah last weekend on secondary roads netted 20.5 mpg. I also had to use both lockers crossing a snow covered section of road.
[COLOR="DarkRed"]Difficulty is the excuse history never accepts.
A Nation of sheep will beget a Government of wolves.[/COLOR]
Edward Murrow
DT75FLH is offline   Reply With Quote Quick reply to this message
Old 04-30-2019, 05:49 PM   #25 (permalink)
Member # 104517
Build the scout. But you'll need the scout motor for the duty cycles.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Similar Threads
What Full size 4x4 to buy for off roading? BigMikeyStylez Newbie General 4x4 Discussion 19 06-11-2014 12:14 PM
96 ford bronco xlt full size 4x4 illwil Vehicles and Trailers For Sale 2 12-26-2013 01:44 PM
FORD BRONCO 1990 - full size 351w 4X4 - PARTING OUT - san jose,ca foxbody Misc. Stuff For Sale 0 10-08-2012 12:46 PM
