D44 / 8.8 regear tools - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-11-2019, 07:12 AM   #1 (permalink)
Member # 372697
I was wondering if there was anyone out there in the South East VA area who would be interested in doing a tool - share type thing.
I will be regearing a D44 and 8.8 in my TJ.
Mainly I was hoping someone had some setup bearings and case spreader they'd be willing to loan.
If not, but someone out there wants to use mine if I end up buying some we can try and get something going.
Gordon-B is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 07:36 AM   #2 (permalink)
Member # 177092
I am sure a case spreader would be nice, but I have gotten on just fine with a dead blow and pry bars.
Just take a Dremel with a sanding drum to your old bearings. On the 8.8, the shims go on the outside, so you don't need carrier setup bearings. If you can't get the old bearings off the Dana 44 in one piece, just get the cheapest Chinese specials you can find on eBay or Amazon and take the Dremel to them.
'84 Bronco II is online now   Reply With Quote Quick reply to this message
Old 05-11-2019, 08:18 AM   #3 (permalink)
Member # 372697
Cool, I'll try that method.
I read the bellavista tech article and it said basically just enough preload that you can't get it in without a deadblow hammer.
Will I probably be fine with a HF dial indicator and mag base or will I be better off with something nicer
Old 05-11-2019, 12:10 PM   #4 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 05-11-2019, 12:48 PM   #5 (permalink)
Member # 82607
I've used the cheap mag base and indicator with good success, in a pinch I had to use a cheap digital calliper
The thing you have to be careful is with the crush sleeve on the 8.8, order a couple cuz if you go too far you are fawked!
I have been known to put the ring gear in the grill to warm it up so it drops right on
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 03:01 PM   #6 (permalink)
Member # 177092
I have the Harbor Freight dial indicator an magnetic base and it works just fine. I definitely wouldn't bother getting a more expensive one.
As for the carrier preload, you want it really tight to minimize carrier deflection under load, unfortunately there is no way to really measure carrier preload, but I have never heard of anyone getting too much preload without a case spreader. My 8.8 has so much preload you really have to beat the snot out of it to get the carrier in. No issues in tens of thousands of miles.
Old 05-11-2019, 03:01 PM   #7 (permalink)
Member # 86724
would do sleeve eliminator and shims.
fuck those crush sleeves.
https://www.summitracing.com/parts/yga-55040/overview/
87manche is online now   Reply With Quote Quick reply to this message
Old 05-11-2019, 05:56 PM   #8 (permalink)
Member # 50525
I couldn’t get the carrier out of my GM 10 bolt with prybars. Finally ran a ratchet strap around the carrier and hooked it to the hitch, worked great.
gatorgrizz27 is offline   Reply With Quote Quick reply to this message
Similar Threads
*WANTED* TJ rear axle. D44, 8.8, or Super 35, with 3:73 gearing. Artandid Axles/Tires/Wheels For Sale 3 01-28-2014 04:48 AM
IROKs, Beadlocks, Built D44, Ford 8.8, etc... jeepbrew Axles/Tires/Wheels For Sale 15 03-25-2012 04:51 PM
