How to disable my airbag *gasp* - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Unread 05-17-2019, 07:18 PM   #1 (permalink)
Member # 358505
So my Mom drives a 2002 Ford Taurus that I believe has one of the Takata airbags that have been killing people. So far her car hasn't been recalled for the airbag, but I know this recall is being done piece meal as they can't do them all at once, and since the recall applies to the year right close to hers I suspect hers eventually will be recalled as well. Either way I don't want to take the chance, and here's why...
The explanation for why these things are going off is there's some defect in the manufacturing that when the air bag is exposed to humid conditions and lots of temp fluctuations, something in them weakens and there they go. Mom's Taurus has a windshield leak so, even though it's never smelled, there's always been a virtual puddle of water in driver's side floor board. So the inside of the car has always been humid, just like in the airbag explosion scenarios.
So, for the time being, until she gets into another car, I'd like to disconnect her airbag to be on the safe side. She is an amazingly vigilant driver, never even a speeding ticket, and the risk of her rear ending someone is virtually non-existent.
How would I go about disabling an airbag on a 2002 Ford Taurus?
Or, alternatively, how do I open the steering wheel column, or front of the steering wheel, which might be part of the disabling process itself, and identify if Mom's airbag is indeed one of the defective types?
bradleyheathhays is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 07:21 PM   #2 (permalink)
Weasel's Avatar
Member # 5639
Try a bridge abutment
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 07:24 PM   #3 (permalink)
Member # 860898
Go get the recall done you lazy cunt. Or let your mom out of the car and take weasel’s advice.
Jackie Treehorn is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 07:27 PM   #4 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
just remove the airbag, what's the big deal?
I just want to build cars, collect watches and get tattoos.
The largest tax modification in 30 years, check it out!
Provience is online now   Reply With Quote Quick reply to this message
Unread 05-17-2019, 07:28 PM   #5 (permalink)
Member # 226216
This^^^^. Film it if its option 2 or your going to get your sunroof shit in.
thefishguy77 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 07:30 PM   #6 (permalink)
DirtyComanche's Avatar
Member # 53453
Wow. Get something that's not a Ford Taurus.
DirtyComanche is online now   Reply With Quote Quick reply to this message
Unread 05-17-2019, 08:04 PM   #7 (permalink)
Member # 117207
Wouldn't you want to try a vaginal dam first? You know, stop all that moisture in the front seat right at it's source?
petro812 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 08:23 PM   #8 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Theres 2 fuses in a yellow cage, pull them out.
Theres at the most 4 screws on the back of the steering wheel holding the airbag pod to the wheel body.
Pull them and when the air bag is in your lap touch a 9v battery to the wire ends to disable it
Unread 05-17-2019, 08:26 PM   #9 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
First off, the airbag does NOT randomly go off, the high humidity capitalizes the dry chemical in the inflator, increasing the charge/expansion rate of the chemical, but it will has to be triggered.
Second, run her VIN through the NHTSA recall website, see if there's a recall. If not, and you want piece of mind, look at the inflator cartridge itself, and see if it is Tamara brand.
I'd call you a cunt but you don't have the depth or the warmth.
Fuck em' and feed them fish heads-
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 08:32 PM   #10 (permalink)
Member # 141094
Easy peasy....
Look under the steering column where all the wiring come out from up by the steering wheel. Its a good sized harness.
Among all those wires will be a 2 wire harness inside of a yellow conduit. This is the airbag harness.
Slice the yellow conduit open to expose 2 wires inside.
Strip the insulation off of those 2 wires carefully, without cutting the actual conductor in half.
Now attach 2 test leads to those wires you just stripped. It doesn’t have to be anything fancy. Just 2 lengths of wire about 3 ft long each, and twist them onto the airbag wires.
Now with the drivers seat in a comfortable position and you sitting in it, connect your test leads to a 9-volt battery.
If you’ve done everything correctly, all the lights should go out and problem solved. Good luck.
Speed costs money, how fast do you wanna go?!
crazydave is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 08:33 PM   #11 (permalink)
Member # 117207
How the fuck did you get the name HAPPYJOHN?
Unread 05-17-2019, 09:17 PM   #12 (permalink)
Member # 358505
Jackie Treehorn, try actually reading my post you stupid fuck. Second sentence clearly indicates the recall hasn't included the '02 taurus, yet.
Lots of you people are really stupid fucks here. Your social development took a seriously wrong turn way way back. Some are ok but for those that aren't, just taking the time to write me to give an insult shows you're just as a group amazingly negative people.
Trying to help my mom out here, that mean anything to you people?
Unread 05-17-2019, 09:22 PM   #13 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Cause hes a bucket of fucking cheer you jackass
Unread 05-17-2019, 09:24 PM   #14 (permalink)
Elwenil's Avatar
Member # 41063
Nope.
What the fuck makes you think that car even has the defective airbags?
And "virtual puddles" aren't real, you drugged up pile of shit.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
I put on my robe and wizard hat. - Bloodninja
Elwenil is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 09:25 PM   #15 (permalink)
Random Dude
Member # 467273
Pics of mom?
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig made his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 09:29 PM   #16 (permalink)
Member # 53453
He always smiles when the lot lizard gives him a knob gobbler with a side of sphincter tickling.
Unread 05-17-2019, 09:30 PM   #17 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Help her buy proving to us how fucking dumb you are?
Pull the fuses
Pull the bag.
30sec on google/youube and you would have been handled. Your mistake was thinking we gave a fuck about her, you doubled down by thinking we gave a fuck about your dumbass spoon sucking cunt ass.
You were helped, but instead of reading it, doing it, then taking to credit, you got but hurt and mouthy and attempted to mock others reading ability.
Bradly, youve been here long efuckingnough to have seen how this was going to pan out, particularly with your continued insistance of dumbass posts like this one. Now fuck off
Unread 05-17-2019, 09:31 PM   #18 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
nope, not really.
I see no reason why you should even bother keeping it. Sell it for $1000 and turn around and buy something pre-96 (ish?) so that you don't have to worry about airbags for the same price. odds are you will get a better car.
how about a lincoln town car? any early 90's buick is a great mom car.
Full size van is really the ideal solution anyways, but you should really look at other things before buying her one of those so that it feels like she chose it on her own.
Unread 05-17-2019, 10:03 PM   #19 (permalink)
Member # 79509
Originally Posted by ExWrench View Post
Pics of mom?
Black Sheep is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 10:22 PM   #20 (permalink)
Member # 40417
In for pics of yer moms airbags, sorry if that's been covered.
Better to be a racer for a moment, than a spectator for a lifetime. Looking for a clean LX Foxbody.
FlexyTJ is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 10:31 PM   #21 (permalink)
Member # 148982
Originally Posted by Black Sheep View Post
God dammit!
R.I.P. Clark :smokin:
"]["{[]}{[]}{]_
Pat McRotch is offline   Reply With Quote Quick reply to this message
Unread 05-17-2019, 10:39 PM   #22 (permalink)
Member # 860898
Then go seal up her windshield you lazy twat.
Unread 05-17-2019, 10:45 PM   #23 (permalink)
Member # 40417
Originally Posted by crazydave View Post
Easy peasy....
^^Best advice yet. This should do the trick. Hard to sort through all the insults for the good advice sometimes but here it is.
lol
Unread 05-18-2019, 05:32 AM   #24 (permalink)
_Stucky's Avatar
Member # 182743
I love pirate. It’s probably not a good idea to use your full, real name, on the internet. I get a little tickle of joy when I see this dumb dumb get flamed.
_Stucky is offline   Reply With Quote Quick reply to this message
Unread 05-18-2019, 05:43 AM   #25 (permalink)
DMG
Member # 8145
How did you survive here since 2013?
Pull the airbag fuses and stfu. Maybe post some pics of your mom. For dirtycomanche.
DMG is offline   Reply With Quote Quick reply to this message
Similar Threads
Service airbag light (tech in chit chat). Grumpy356 General Chit-Chat 11 01-01-2018 01:16 PM
I need help from suspension and Airbag guru's! joshua1086 Tow Rigs and Trailers 6 01-01-2015 06:38 PM
LJ airbag system reset POSBronc Jeep - Non Hardcore 0 07-23-2014 06:00 PM
Google safe search. Can't disable in US nahmus General Chit-Chat 38 12-23-2012 05:21 PM
