Anybody refinish vintage aluminum wheels around here? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-21-2019, 11:18 AM   #1 (permalink)
Member # 96278
So these followed me home this weekend.
They are -obviously- old school Cragar G/Ts. I love the white walls, but alas it is not the look I'm going for. I want to clean the wheels up and throw them on the front of my Galaxie for shits and grins. So after fighting the fucking tires off, I threw them in the media cabinet for 20 minutes or so and came up with this:
Decent, but not quite. I'm shooting for a fairly uniform mag finish- nothing shiny. What's the next step to getting out more of the pits and discolorations? I tried scotch brite but it started polishing over the spots, not removing them. Maybe a courser grit?
Drink to the dead all you still alive
We shall join them in good time
cj5.5 is online now   Reply With Quote Quick reply to this message
Old 05-21-2019, 11:35 AM   #2 (permalink)
ISDTBower's Avatar
Member # 94026
To get rid of the pits, you have to sand the wheels down to the bottom of the pit. That would take hours and probably not leave a "straight" part.
Bead blasting just made it more difficult...but easier to see the imperfections.
MAybe SAND BLAST the part which will minimize the look of the pits, and then clear coat with a flat or semi flat paint or maybe powder coat if they can make it stick. Another option might be paints in a similar color but not.. Like titanium. That would allow a good base and then reasonable color control.
But basically you are screwed for raw alum, if you want it close to perfect.
I make a lot of billet parts and know the process. Even if you want to get to "scotch brite" buff. You almost have to get it to a low polish first.
Usually the outer rim can be polished easily..and then the spokes painted a different satin finish. A reasonable compromise sometimes. The outer rim can be sanded and polished by attaching the wheel to anything rotating. Including your rear axle. Then a flap wheel to quicken the process.
Good luck. Going to consume some hours. Many wheel polishers will do the outer rim..as "easy." and machinable. But I think those are too far gone actually.
ISDTBower is online now   Reply With Quote Quick reply to this message
Old 05-21-2019, 11:38 AM   #3 (permalink)
Member # 143737
Fawk that, head down to route 1 in northern MA, forget the city, I can find out, and there's a shop full of Hispanics that do hands down the best wheel refinishing around, for decent money
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 12:19 PM   #4 (permalink)
Member # 96278
Good stuff there, thanks. So the goal is uniform at 5-10 feet, not anything close to perfect, nor do I want shiny. This is a quick low buck deal to mix it up a bit. I won't run these but a couple times probably.
So a coarser sand might be worth a try? Not opposed to just a quick spray of flat gray either, as opposed to hours and hours better spent elsewhere.
Appreciate that, I'll keep that in mind should I have wheels worth the hassle.
I try to avoid MA whenever possible. Heck, anything south of Tilton for that matter
Old 05-21-2019, 12:28 PM   #5 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Yeah those are pretty gnarly. I'd consider getting them powdercoated.
The one, the only, the Dane.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 12:43 PM   #6 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
plastidip!
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 12:57 PM   #7 (permalink)
paragon's Avatar
Member # 40266
how would those new-fangled laser machines work on something such as that?
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 12:57 PM   #8 (permalink)
oneofakind97's Avatar
Member # 127719
Though not as gnarly as these, I just freshened up some Alcoa wheels on a semi tractor that have been living off-road for the last 6 years. I bought a box of little Velcro sanding discs and a bit for a cordless drill that they attach to. Started with a coarse grit and ended fine and then used a polishing wheel on the same drill. Not perfect, but they look a hell of a lot better than before and they have a decent shine.
85 F250 on locked tons and 44's. Teetering on BGTL territory
Tow Pig: 86 F350 Turbo 6.9/ZF5 4x4 converted dually
old Chevy vs new Chevy ? nobody gives a fuck
please kick yourself in the cunt,
oneofakind97 is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 01:20 PM   #9 (permalink)
Member # 53453
If those pits are deep I would recommend just getting them powder coated. Gun metal, silver, whatever. If you want a mirror polish it will require a ton of material removal.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 01:28 PM   #10 (permalink)
Member # 17632
I did a set of slot mags with red scotch-brite and WD-40, they came out just as you describe. However, I think getting there on the spoke portion will be a miserable bitch to accomplish. I would try, as suggested, to get the lip looking how you want and tehn paint the spoke portion a coarse metallic to mimic an American Torq Thrust.
Travis..
18 Ram 2500 4x4 Big C and a 6 speed
73 Dodge W100, 400 4spd, stepside project
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 01:41 PM   #11 (permalink)
paragon's Avatar
Member # 40266
reading comprehension much?
[COLOR="Black"].
[/COLOR]
Old 05-21-2019, 01:43 PM   #12 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
We had part of a slinky. But I straightened it.
Subybaja is online now   Reply With Quote Quick reply to this message
Old 05-21-2019, 01:51 PM   #13 (permalink)
Random Dude
Member # 467273
They'd go "gzaaaakggggrrrraaaaak pew-pew-pew grazzzzzk"
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is online now   Reply With Quote Quick reply to this message
Old 05-21-2019, 02:28 PM   #14 (permalink)
Member # 53453
Choke to death on a dick.
And no, you can't use a laser to remove pitting.
Old 05-21-2019, 02:47 PM   #15 (permalink)
Green bastard
cslimfu's Avatar
Member # 123458
OEM wheel sparkle silver 51082
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 02:59 PM   #16 (permalink)
paragon's Avatar
Member # 40266
why not? other people do
[COLOR="Black"].
[/COLOR]
Old 05-21-2019, 03:01 PM   #17 (permalink)
paragon's Avatar
Member # 40266
[COLOR="Black"].
[/COLOR]
Old 05-21-2019, 03:13 PM   #18 (permalink)
Random Dude
Member # 467273
Dunno if serious but unless you're talking about laser welding (and adding filler material), a laser could only remove pitting by removing material down to the bottom of the pits.
As for this:
We have a 25W marking laser to remove paint, anodizing and base metal as needed by the part's marking requirements. It works great on flat surfaces and slight angles, but I'm guessing the Flash Gordon gun would not do much on surfaces that are angled or out of optimum range (betty, betty close).
Old 05-21-2019, 03:16 PM   #19 (permalink)
ISDTBower's Avatar
Member # 94026
Like the powdercoat idea as they will sand blast as part of the process.
Careful with the lug nuts. The powdercoat is slippery and they can loosen easily. Many in the know use a tapered cutter to remove the coating under the lugs.
Old 05-21-2019, 03:24 PM   #20 (permalink)
paragon's Avatar
Member # 40266
As for this:
10-15 years ago there was some science article, popular science or the like, about lasers refacing aluminum. it melts the surface and something or the other or the other.
kinda figure there is something moresy nowadays
[COLOR="Black"].
[/COLOR]
Old 05-21-2019, 04:22 PM   #21 (permalink)
Green bastard
cslimfu's Avatar
Member # 123458
Odd, never heard of anyone doing that. I also have never had any of my 16 out of 18 of my wheels that are powdered come loose. Must be a lightweight and only a few lugnut sand thing?
Old 05-21-2019, 10:44 PM   #22 (permalink)
Member # 181882
powder coat them darkish grey and pretend they're magnesium ?
paint or powder coat the spokes grey or black and lathe turn / polish the rim ?
oldcars is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 11:19 PM   #23 (permalink)
ISDTBower's Avatar
Member # 94026
Would you intentionally put a Nylon or PE washer under your lug nuts? Probably not.
Typical is heavy pick-up trucks ...and not re-tightening after a few miles.
I had a set of trailer wheels that took 5 re-tightenings before finally set. The powder just kept "flowing."
Happens. Ask any wheel mfg. after a few brews.
If they cut them, no one would buy them. Just FYI. Cheers.
Old 05-22-2019, 06:01 AM   #24 (permalink)
jps4jeep's Avatar
Member # 66852
RT1 south in Peabody MA, right after the Cabaret.
My Father in law used them for some early 2000's infinity SUV aluminum wheels, looked good for about a year then went to all shit and looked worse than when he initially brought them in. Could be the wheel, could be the process.
I used to jog, but the ice cubes kept falling out of my drink.
jps4jeep is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 07:55 AM   #25 (permalink)
Member # 143737
DING DING DING WINNAR!
Been a long time since I been down that way, thanks!
Similar Threads
Axletech 4000 Combat Wheels, Aluminum & Steel swirvin21 Axles/Tires/Wheels For Sale 3 10-07-2015 03:12 PM
KMC Aluminum Bead Lock Wheels ON SALE NOW! zachv Axles/Tires/Wheels 154 12-12-2013 07:26 PM
Raceline Wheels Monster $5,000 Bounty at 2013 King of the Hammers RACELINE WHEELS Axles/Tires/Wheels 3 12-14-2012 10:25 AM
