$100 boat trailer- comes with boat... - Page 9 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-13-2019, 08:06 AM   #201 (permalink)
Member # 9994
i had this problem with a remanned distributor one time, it just would not go in the engine.
long story short, when they bead blasted the housing, it "knurled" enough to be too large of a diameter to fit. two minutes with a file, and it dropped right in.
Might check the diameters of the new to the old with a caliper or mic to make sure they are the same
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 03:45 PM   #202 (permalink)
DozerDan's Avatar
Member # 9144
Send a message via AIM to DozerDan
Originally Posted by DWT View Post
Sounds like the oil pump shaft isn't seated in the pump anymore.
It is, I tried pulling up on it and it does not come up, it is down and seems to move like it should when I rotate it with a screw driver
Originally Posted by lil,yota View Post
When you are pushing down the dist is turning the oil pump drive. Its probably all gunked up from sitting for so long.
Does not seem to be gunked up.
Originally Posted by jr4x View Post
Dan, try to put the old distributor back in. I know it doesn't work but if it will go in & seat all the way and the new one will not then you have half an answer as to WTF is going on.
Tried, same issue.
Originally Posted by greenlion View Post
Is the oil pump slot lined up? Get a long flat screwdriver and a light. Turn the oil pump drive until the slot is oriented the same as the drive on the bottom of the distributor gear. Drop it in. May take a few tries as you still have to eyeball the orientation. FWIW I always put the dizzy in 180 out and have to do it twice
Yup, that is what I have been doing
Originally Posted by ky scrambled View Post
You could always finance a new one.
No no I can not.
I used a caliper and everything is on size.
After thinking on it today I think the issue is the adapter stem from the oil pump up to the dist. It can float- front-back / left-right. It wants to sit back, hence why I tried to get some grease down there to hold it straight up and down.
Talking to some guys at work and they agreed that they have seen this before. I am going to tried to fit a small o-ring over the stem and get it to stay vertically upright, instead of leaned back. It is all I can come up with at this point. I think I can set it over my long needle nose and get down to it, if I can get it over I can just work it down to the top of the oil pump and hopefully get it to act as a support.
If the rain holds off I am going to go give it a shot.
The proper dist for the 'marine' engine should be here tonight as well. So I will have another one to double compare with.
I really think it is that the pump shaft is not sitting perfectly upright though.
Dan Smith
'physically strong, mentally awake, and morally straight'
Fear is not an option!
DozerDan is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 03:56 PM   #203 (permalink)
DWT
DWT's Avatar
Member # 19850
Stock shafts are centered on the pump with a plastic sleeve. Good aftermarket shafts have a steel sleeve pinned to the shaft so the shaft won't come out the top, it has to go out the bottom with the pump.
The shaft should be centered enough but an o ring or a piece of tubing will hold it centered.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 04:02 PM   #204 (permalink)
DozerDan's Avatar
Member # 9144
If I had to guess, this is stock, and that sleeve is either worn out or gone.
Dan Smith
Old 08-13-2019, 04:09 PM   #205 (permalink)
DWT
DWT's Avatar
Member # 19850
These sleeves get brittle with age and end up in the pan in pieces.
https://www.ebay.com/p/Engine-Oil-Pu...UaArvHEALw_wcB
This is the good shaft that you might have, being a marine application it very well could be stock.
https://www.summitracing.com/parts/m...8aAlmxEALw_wcB
Old 08-13-2019, 04:12 PM   #206 (permalink)
DozerDan's Avatar
Member # 9144
Yup, I just hopped on e-gay and searched some. Seems hit or miss if they have the plastic sleeve, and those that do it looks rough.
I may go with that, I am sure I have some hose/plastic around that will fit, give it a bit more rigidity.
Thanks
Dan Smith
Old 08-13-2019, 09:17 PM   #207 (permalink)
lil,yota's Avatar
Member # 102395
Its apparent you don't really want to boat this summer...
Feel free to ship ot to me and I will be boating within an hour of arrival...
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 04:07 PM   #208 (permalink)
DozerDan's Avatar
Member # 9144
Ok, but BUT if you don't have it on the water 'boating' in an hour, its going to be $2,500 plus towing fees...
I have been boating a few times this summer; just not on this boat ha.
Anyhow. I am still at a loss. I cut and slipped a 1/2" ID hose over the oil pump shaft, it def centered it up. But this thing still wont seat. It was dark and raining so I did not try all that much before I called it. but something seems not right.
I feel I have at least a low to moderate handle on things mechanical. Not sure what I am missing. The Boat vs of the dist is here, but I was hoping to not install it until I confirmed it will fire - part of why I bought the cheap 'car' version.
I may go fuck with it some more. Something stupid has to be going down here.
Dan Smith
Old 08-14-2019, 06:30 PM   #209 (permalink)
Mr.RatBastard's Avatar
Member # 9307
Gear upside down?
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 06:41 PM   #210 (permalink)
DozerDan's Avatar
Member # 9144
I feel I can trust you guys here.... really I do....
So I found the problem... the source of the problem is up for debate, non the less it is resolved.
Turns out I done fucked up.
I jumped the gun when it would not go in the first time, and started fucking with shit. I swapped the drive gears from the original to the new, some how I flipped it. I am normally OCD about stuff like that but it happened.
After that it was a down hill battle against myself.
Tonight I decided fuck it, I am going to put the new 'boat' one in and see what happens. But the drive tang has no lead ins, so I pull the gear and grind some lead ins on (still thinking that I can not locate on the oil pump shaft)
Go to put the gear back on and noticed that how I laid it out is not how the other ones are... whoops...
Fucked up part is I am an asshole when it comes to laying parts out as they came off- esp at work. And I done gone fucked myself up on it.
Ironically it dropped RIGHT in after the gear was on right, and the oil pump shaft was upright and aligned.
Now back to your regularly scheduled fuckery.
Dan Smith
Old 08-14-2019, 06:42 PM   #211 (permalink)
DozerDan's Avatar
Member # 9144
Originally Posted by Mr.RatBastard View Post
Gear upside down?
Winner winner--- where was that the other day...
Of all people to chime in about an hour too late....
Dan Smith
Old 08-14-2019, 07:06 PM   #212 (permalink)
Member # 9307
Woohoo! Glad you got it. I was close...ha!
Old 08-14-2019, 07:24 PM   #213 (permalink)
Member # 688970
So did it fire?
santa V2.0 is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 07:29 PM   #214 (permalink)
DozerDan's Avatar
Member # 9144
No you were spot on, just a little late to the party!
Originally Posted by santa V2.0 View Post
So did it fire?
Yes, well on ether. Carb is not on, and new fuel pump not installed.
But I have spark, and a shot of ether made her fire for a split second. Good enough for me, for the night. I REALLY want to keep going but should stop.... we will see.
Dan Smith
Old 08-14-2019, 07:38 PM   #215 (permalink)
Member # 192237
haha every telephone diagnosis session ever
"well does anything look retarded? Know what, I'll just come over there and look at it."
Old 08-14-2019, 07:46 PM   #216 (permalink)
DozerDan's Avatar
Member # 9144
I knew it was something stupid that I was missing. I just did not realize how stupid...
I am a mix of kicking myself for doing that, and fully ecstatic that it will fire. I mean still not out of the woods yet, but I can at least see the first clearing.
Only problem with that is I know myself... now the check book is a blank check--- well not quite yet--- but soon.
Moral of the story- always check yourself. I got complacent and rushed through something, and it bit me in the ass. I bite I hope not to forget anytime soon!
Dan Smith
Old 08-14-2019, 07:55 PM   #217 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
that sounds about right
sometimes it just takes stepping away from it
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 08:19 PM   #218 (permalink)
Member # 193950
Been there, done that. Amazing what I can miss when tired/frustrated/banging my head against the wall that sticks out like a sore thumb even to an untrained eye.
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 04:16 PM   #219 (permalink)
DozerDan's Avatar
Member # 9144
Aaron Z
Yup. It was one of those- Red Forman 'Dumbass' moments. So much so I just started to laugh.
Shit happens, but still I mean of all the simple things that made me think I was loosing my mind.
Dan Smith
Old 08-15-2019, 06:02 PM   #220 (permalink)
DozerDan's Avatar
Member # 9144
Fuel pump installed and primed, about to drop the carb on... things are going to go well or I am going to stop for the night...
Dan Smith
Old 08-15-2019, 06:25 PM   #221 (permalink)
Member # 86724
good luck.
Old 08-15-2019, 06:29 PM   #222 (permalink)
Member # 55560
Originally Posted by 87manche View Post
good luck.
We're all counting on you
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 06:41 PM   #223 (permalink)
DozerDan's Avatar
Member # 9144
And I I think I am 180 out. And honestly with all the fucking around I did I don't recall if I actually reset TDC when I got the dist to seat.
Cranks good, but is popping out the carb, tells me timing is not right.
Dan Smith
Old 08-15-2019, 07:23 PM   #224 (permalink)
Member # 192237
I get everything 180 out at least 80 percent of the time. Injection pumps especially.
you could always just swap the wires across the cap to make it right
Old 08-15-2019, 07:34 PM   #225 (permalink)
DozerDan's Avatar
Member # 9144
Looks like 180 and a tooth. Just gonna re set it.
This is why I hate having to start/stop on projects. You walk away and forget where you left off.
All good. I think I got her now. About to reset and re wire- normally I would not rewire mid trying something, but I am feeling crazy
Dan Smith
