Eyeballing This - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-08-2019, 01:04 AM   #1 (permalink)
Member # 685122
Eyeballing This
https://www.czdenver.com/details/use...berty/46440290
Good deal? Sorry, not a boat.
TheCopperCowboy2 is online now   Reply With Quote Quick reply to this message
Old 06-08-2019, 01:28 AM   #2 (permalink)
Random Dude
Member # 467273
Looks like it's actually ready to wheel - never seen a Liberty like that
Cheroquito
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 01:46 AM   #3 (permalink)
Member # 685122
Not liking how the tire is blocking the left rear taillight and license plate. Maybe put the spare in the boot and keep the COG low.
Old 06-08-2019, 01:49 AM   #4 (permalink)
Member # 685122
Has a rebuilt title, don't care, I'll more than likely trash it anyway.
Old 06-08-2019, 02:02 AM   #5 (permalink)
Random Dude
Member # 467273
Offer tree-fitty?
Old 06-08-2019, 02:25 AM   #6 (permalink)
2big bronco's Avatar
Member # 66684
What rear axle is that?
Old 06-08-2019, 02:37 AM   #7 (permalink)
Member # 685122
Dual 44's.
Old 06-08-2019, 03:31 AM   #8 (permalink)
Member # 54455
Looks like a cross between a Currie high pinion rockjock and a Model T.
Boats n Does
Deuce 40s is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 04:00 AM   #9 (permalink)
Member # 66684
Originally Posted by TheCopperCowboy2 View Post
Dual 44's.
Unless dual 44s is a model... that is not a dana 44. Almost looks like a Winters quick change sprint car rear axle which I cant imagine would last 1000s of miles on the street
Old 06-08-2019, 04:16 AM   #10 (permalink)
Member # 18369
That motor is a complete problematic! From what I have read up on in the past, when my buddy step daughter had problems that I helped him look into just sayin.
91 - Spark Plug(s)
61 - Engine Carbon Cleaning Procedure
58 - Rocker Arm(s)
57 - Ignition Coil(s)
34 - Engine Valve(s)
29 - Fuel Injector(s)
25 - Valve Job
23 - Engine Valve Spring(s)
21 - Engine
20 - Cylinder Head Gasket(s)
18 - Cylinder Head(s)
11 - Ignition Coil(s) and Spark Plug(s)
11 - Rocker Arm(s) and Valve Lifter(s)
9 - Engine Carbon Cleaning Procedure and Rocker Arm(s)
8 - Engine Carbon
7 - Powertrain Control Module (PCM)
7 - #4 Exhaust Valve Spring
7 - #1 Intake Valve Spring
6 - Engine Carbon Cleaning Procedure and Spark Plug(s)
6 - Valve Lifter(s)
5 - #2 Intake Valve
4 - Catalytic Converter(s)
3 - Oxygen (O2) Sensor(s)
3 - Spark Plug Wire(s) and Spark Plug(s)
2 - Spark Plug Wire(s)
2 - Coil On Plug(s) (COP)
2 - Upstream Oxygen (O2) Sensor
2 - Spark Plug Boot(s) and Spark Plug(s)
2 - Engine Valve Seat(s) and Valve Job
2 - Engine Carbon and Spark Plug(s)
2 - Engine Carbon Cleaning Procedure and Fuel Injector(s)
2 - Rocker Arm(s) and Spark Plug(s)
2 - Camshaft Follower(s)
2 - Engine Valve(s) and Rocker Arm(s)
1 - Spark Plug Boot(s) and Spark Plug Wire(s) and Spark Plug(s)
1 - Exhaust Valve Guide
1 - Ignition Coil(s) and Spark Plug Boot(s)
1 - Engine Oil and Engine Oil Filter and Rocker Arm(s)
1 - Engine Carbon Cleaning Procedure and Ignition Coil(s) and Spark Plug(s)
1 - Engine Valve Spring(s) and Rocker Arm(s)
1 - Engine Carbon Cleaning Procedure and Engine Valve Spring(s)
1 - Spark Plug Tubes and Spark Plug(s)
1 - Timing Chain(s)
1 - Ignition Coil Boot(s) and Spark Plug(s)
1 - Engine Carbon and Fuel Injector(s)
1 - Engine Valve(s) and Valve Job
1 - Camshaft Follower(s) and Valve Lash Adjuster(s)
1 - Engine Valve(s) and Valve Job and Valve Lifter(s)
1 - Engine Valve Seat(s) and Rocker Arm(s) and Valve Job
1 - #1 Intake Valve Spring and Engine Carbon Cleaning Procedure and Rocker Arm(s) and Valve Lifter(s)
1 - Engine Carbon Cleaning Procedure and Valve Lifter(s)
1 - Ignition Coil(s) and Rocker Arm(s)
1 - Engine Carbon Cleaning Procedure and Fuel Injector(s) and Rocker Arm(s) and Valve Lifter(s)
1 - Engine Oil and Engine Valve(s) and Valve Lash Adjuster(s)
1 - Engine Ground Strap and Ignition Coil(s) and Spark Plug(s)
1 - Engine Air Filter and Ignition Coil Boot(s) and Spark Plug Wire(s) and Spark Plug(s)
1 - #4 Exhaust Valve Spring and Valve Lifter(s)
1 - Camshaft Follower(s) and Engine Valve(s) and Valve Lifter(s)
1 - Spark Plug(s) and Vacuum Hose/Line(s)
1 - #2 Intake Valve and Rocker Arm(s)
1 - Engine Valve(s) and Induction Air System
1 - Fuel Injector(s) and Rocker Arm(s)
1 - Camshaft(s) and Powertrain Control Module (PCM) Adaptive Memory and Rocker Arm(s) and Valve Job
1 - Camshaft Follower(s) and Engine Carbon Cleaning Procedure and Valve Lifter(s)
1 - Cylinder Head Gasket(s) and Ignition Coil(s)
1 - Engine Valve Seat(s) and Engine Valve(s)
1 - Coil On Plug(s) (COP) and Spark Plug(s)
1 - Cylinder Head Gasket(s) and Cylinder Head(s)
1 - Oxygen (O2) Sensor(s) and Spark Plug(s)
1 - Ignition Coil(s) and Spark Plug Wire(s) and Spark Plug(s)
1 - Lifters
1 - Catalytic Converter(s) and Ignition Coil(s)
1 - Engine Carbon Cleaning Procedure and Throttle Body Cleaning
Wazzobie is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 04:17 AM   #11 (permalink)
Member # 101819
Only thing itís missing is the Hillary 2016 bumper sticker.
Thepanzerfuhrer is online now   Reply With Quote Quick reply to this message
Old 06-08-2019, 04:47 AM   #12 (permalink)
Random Dude
Member # 467273
Looks like a semi-float RockJock 60 for a TJ.
Surprised to see that and an Atlas TC in a Toaster. OP - make sure the parts aren't hot
Could be a former SEMA build? If so, maybe check for expedient-build fuckery
Old 06-08-2019, 05:45 AM   #13 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I remember this jeep. It belonged to a guy that was trying to create an SAS kit that used TJ axles back around 05-07'ish timeline. There use to be pictures floating around somewhere on this forum.
From the looks, it's got good parts, the fab work is decent. But I doubt it wheels all that well.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:12 AM   #14 (permalink)
45acp's Avatar
Member # 13671
Move the rear end back 2", get the ride height down, trim/cut whatever the tires rub on, get the spare inside rear compartment and I bet it'll wheel like a little beast.
45acp is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:17 AM   #15 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
Didn’t S&N fab build a straight axle Linked liberty with An atlas like 15 years ago
Kelly Kaiser
Vertical Limits Inc
913.731.3040
for the fastest quick release extinguisher mounts available and UTV parts
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:19 AM   #16 (permalink)
Member # 52361
Curious, why? Suspension travel? Seems well set up for weekend warrior stuff
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:24 AM   #17 (permalink)
Member # 162643
Finally something gheyer than a JK. You need to get it so all of us JK owners will look like manly men again.
shortbus4x4 is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:27 AM   #18 (permalink)
Member # 52361
OP, it's got 99,970 miles on it, go for a long test drive, then come back in a week when it's still there, past the magic 100k mark
Old 06-08-2019, 06:30 AM   #19 (permalink)
Member # 213125
You should get something less faggoty and buy a Subaru.
Aisin is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 06:44 AM   #20 (permalink)
Corey Young's Avatar
Member # 21622
Originally Posted by blacksheep10 View Post
Didnít S&N fab build a straight axle Linked liberty with An atlas like 15 years ago
It was red.
Rear axle in the orange one is a Currie Rock Jock 60.
Old 06-08-2019, 06:58 AM   #21 (permalink)
Member # 66684
I actually kinda like it for a wifeymobile that I could beat on. To bad it wasnt purple, that would sell her on it regardless of what car it was
Old 06-08-2019, 07:00 AM   #22 (permalink)
Elwenil's Avatar
Member # 41063
I would drive it first. The seating position in those is not "normal". Sort of the cross between and old van and sitting in a chair at the kitchen table. My '06 Renegade was a 6 speed and you couldn't push the clutch in without your shin rubbing the knee bolster.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
I put on my robe and wizard hat. - Bloodninja
Elwenil is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 07:14 AM   #23 (permalink)
Member # 94747
Are you blind, looking at this on potato? Or have you never actually seen an axle before? That doesn't even look like a bolt together Quick change. That's a High Pinion Currie RockJock with a "jock strap". And currie makes RockJock's in D44, D60 and D70.
OP I'm pretty sure I went on Hells Revenge in Moab with that thing over 10 years ago. Thought it was pretty well put together and it seemed to get along just fine. My wife at the time, (ex now) decided she wanted something like it for her DD and that's how I ended up building a suzuki Grand Vitara. That liberty looks like it's aged well and not been used at all since I last seen it.
[COLOR="Red"]MUDDNUTT racing #4531[/COLOR],[COLOR="Cyan"] Falken Tire[/COLOR], [COLOR="Yellow"]ADS[/COLOR], Jimmys4x4,[COLOR="Red"] RuffStuff Specialties[/COLOR], [COLOR="DarkOrange"]ARB usa[/COLOR], [COLOR="Wheat"]Savvy offroad[/COLOR], [COLOR="Silver"]Raceline wheels[/COLOR], John Rants
jr4x is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 07:26 AM   #24 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Nice Pathfinder!
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 06-08-2019, 07:50 AM   #25 (permalink)
YotaAtieToo's Avatar
Member # 25632
Way over priced imo
