Lean to help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-11-2019, 08:14 PM   #1 (permalink)
Member # 37016
Lean to help
Ok here's the run down. 50x80 steel building. Want to put a lean to on the 50ft end from the second girt above the door and have the other end on a 40ft high cube shipping container, roughly 23ft away.
So building end will be 12'6" up and the other end will be ontop of shipping co trainer at 8'6". So here is my questions. I originally was planning on running some 2x12s and attaching them to the girt at building and then attach to top of shipping container. No snow load in Phoenix so only thing it will have to support is the steel sheeting for the roof.
Do I need to add supports to the girt that has a 22ft span to keep them from bowing or will they be able to support the structure. Also how would you guys suggest attaching this to the girt. Through bolt a ledger board through wall into girt that rafters will sit ontop of? Or?
Thanks.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 09:24 PM   #2 (permalink)
Member # 52361
You coulda just titled the thread
"suck it bitches "
Posting from my 2 car garage with 7' door
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 09:33 PM   #3 (permalink)
Member # 18282
Gonna need pics of the gal by the scissor lift first.
I'm what you call your basic famous.
Stix is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 01:18 AM   #4 (permalink)
Member # 101819
After rereading the question no that end is not strong enough for roof. It will sag. Build it like it’s own pole shed. Sink 4 poles right next to building. Use that to hold roof up vs the steel. Good luck
With this cheap of structure could you just order another bay?
I’m not used to seeing such a wimpy structure. Those roof beams would be 24” wide in these parts.
Thepanzerfuhrer is online now   Reply With Quote Quick reply to this message
Old 06-12-2019, 02:28 AM   #5 (permalink)
Member # 82607
Indeed
To answer the OP's question, it all depends on what you use for a ledger. I'm sure the right piece can be spec'd by an engineer. I take it you don't have to consider snow loads?
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 04:00 AM   #6 (permalink)
Member # 85771
"suck it bitches "
This was a wonderful 1-2 punch gentleman.
Make Forums Great Again!
Old 06-12-2019, 04:54 AM   #7 (permalink)
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
No, put in a few footings and columns to support it. It would need a beam or channel attached directly to your buildings columns. I don't think the building columns are designed to support the additional loading. Sure it would probably work but it's not right.
Building high performance turbo diesel motorcycles.
dethmachinefab is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 07:09 AM   #8 (permalink)
Member # 37016
What size and spacing columns do you guys suggest?
Old 06-12-2019, 07:13 AM   #9 (permalink)
Member # 101819
Around here that would get a 6x6 on 10 centers. Just on building side.
Old 06-12-2019, 09:38 AM   #10 (permalink)
arickvan's Avatar
Member # 188882
x3 on scissor lift chick
ps sorry in advance if thats your daughter
arickvan is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 10:24 AM   #11 (permalink)
Oh Jesus Tits....
Member # 17554
eh....she looks legalish.
1977 Ford F150 4x4 Shorty 351M/NP435
2007 Ram 2500 Quad Cab 4x4 5.9 Cummins
D-RAT is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 11:18 AM   #12 (permalink)
Member # 37016
That's my wife. You want to see her you guys get to check out my sexy self too.
Old 06-12-2019, 11:27 AM   #13 (permalink)
mjlogan88's Avatar
Member # 23553
Pics of bitchin shop followed by
That's my wife.
"suck it bitches "
I have nothing else to add
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 11:27 AM   #14 (permalink)
Member # 7412
you could just add a couple 4"x4" 3/16ths posts to stiffen up between the main frame. panz is in big snow country.
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 12:46 PM   #15 (permalink)
Member # 37016
I'm going to be sheeting the inside of the shop so every 4 ft I will have a vertical support between the girt and the ground. Was thinking if I upped it to a 4x4 every 4 ft that the girt would support the roof end easily. Wouldn't be any different than putting a 4x4 post outside of the shop every 4ft in my mind.
Old 06-12-2019, 01:53 PM   #16 (permalink)
Blame Canada's Avatar
Member # 5176
You sir, are a lucky man. Your wife is quite beautiful.
I keep my post count low by posting in chit-chat.
STOLEN!!! -->'80 CJ-7 w/ 258 I-6,T-176,D300, '94 YJ tub, '83 toy axles front & rear, Smirffield front axles, w/3.90's, 'YJ rears up front, and a bunch of home-grown patches, all sitting on BFG 35" MTs.
Post #411
Blame Canada is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 02:24 PM   #17 (permalink)
Member # 37016
Definitely out of my league, I am a lucky man. And she works with me in the shop everyday. Found a winner.
