REGULATOOOOOORS, Mount UP! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2019, 05:04 AM   #1 (permalink)
Member # 85771
I have a pop with a propane tank on the front. Regulator is mounted on the front also. Line goes to the back and the connection comes out on the side of the trailer where I can hook the grill up to it.
I got a propane griddle for fatherís day. 1lb tanks arenít an issue to deal with but I see I can get an adaptor to hook them up but will it work?
High pressure, low pressure, too many regulators. These are my concerns.
Make Forums Great Again!
Old 06-19-2019, 05:10 AM   #2 (permalink)
DMG
Member # 8145
Get an adapter hose, about $20 at Walmart and it will work great. Maybe get the inline filter made for the Big Buddy heater too. Bulk propane is dirty.
DMG is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 05:26 AM   #3 (permalink)
Member # 86724
you can only use t on a clear black night with a clear white moon.
https://www.amazon.com/Coleman-High-.../dp/B01M5AOUWD
Old 06-19-2019, 05:55 AM   #4 (permalink)
mechanicalmongoose20's Avatar
Member # 120626
Coke or Dr Pepper
mechanicalmongoose20 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 06:23 AM   #5 (permalink)
Member # 85771
So no concerns about two regulators?
I found this but would rather not take pieces off of the grill to use it.
https://www.amazon.com/Sturgi-Safe-B...a-726789260542
Old 06-19-2019, 06:25 AM   #6 (permalink)
paragon's Avatar
Member # 40266
wait... wait. . . wait.
first things first.
why does your dad have a propane tank attached to the front of him? is this some mad max shit? why not oxygen?
does it fuel a portable personal cooling device?
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 06:29 AM   #7 (permalink)
Member # 85771
first things first.
My Dad is Hank Hill. Yes, its cool. Yes, he loves propane. No, you cant have an autograph.
pop-UP
Old 06-19-2019, 06:37 AM   #8 (permalink)
2big bronco's Avatar
Member # 66684
It was a clear black night, a clear white moon
Warren G was on the streets, trying to consume
Some skirts for the eve, so I can get some funk
Just rollin' in my ride, chillin' all alone
Old 06-19-2019, 06:55 AM   #9 (permalink)
wheelerfreak's Avatar
Member # 4135
I added a tee from the propane line to my house so I could use that instead of the small bottles. I was told two regulators like that wouldnít work. Itís somewhat true. My smoker works fine like that but the burner for my disc cooker wonít really burn well with that setup.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfitsóa false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 06:58 AM   #10 (permalink)
paragon's Avatar
Member # 40266
pop-UP
well fuck, then. he should have all the propane and propane accessories you need
[COLOR="Black"].
[/COLOR]
Old 06-19-2019, 07:20 AM   #11 (permalink)
Member # 85771
Appreciate the feedback. Ill just deal with the baby bottles for now.
Im normally a charcoal guy. He knows that and has essentially disowned me.
Old 06-19-2019, 07:32 AM   #12 (permalink)
CJeep77's Avatar
Member # 25458
You would not want a second regulator.
I believe you are asking for a connection into the low pressure system of the pop? If so, is the below link an option? I would personally also add a gas shutoff valve in front of the coupler.....
Linky: Hose w coupler
CJeep77 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 07:45 AM   #13 (permalink)
Member # 51775
Yes, concern. Two won't work. Had to take the regulator off of the WeberQ to use the regulated outlet on our travel trailer. I patched together a bunch of fittings before the linked adapter was available.
wireman is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 09:11 AM   #14 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
It's pretty easy to refill the small bottles from a 20+ pounder when you get the adapter for it which is readily available I do run coleman stuff straight off 20+ pound bottles with no issues also. I have a adapter pipe that hooks to a big bottle that I run a lantern, grill and stove all straight off the bottle. Been doing it for years with no issues other than minor leakage occasionally.
I have a camping box that I have full of every possible type propane adapter and hose. Pretty handy.
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 11:21 AM   #15 (permalink)
Member # 225201
Everything after the reg at the cylinder should be 11-13” of Water Column (.5 PSI basically) and you need to remove the regulator on any “appliance” you run or the reg at the appliance won’t open. You need to add a quick release and have a hose built. If you want to send me pics I’ll check it out. [email protected].
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 12:22 PM   #16 (permalink)
Mr.RatBastard's Avatar
Member # 9307
It's not your gang Dave.
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 05:12 PM   #17 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Fuck the "readily available" adapter.
That thing attaches the green bottle sideways to the white bottle, so you've only got a 50/50 chance of the schraeder valve pointing up. More importantly, there's no ball valve. (Nice visual showing OPEN or CLOSED).
I was filling some of those up when I unscrewed the green bottle and started spouting liquid cold-as-fuck propane out of the white bottle. It was real fun closing that sucker up without getting frostbite.
Better setup has the white bottle upside down on a table with a pipe coming out and a 90 degree elbow straight down, ball valve then BOM adapter.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 06:25 PM   #18 (permalink)
Member # 161331
If you buy the high pressure hose linked above, it won't have 2 regulators. I run that same hose on mine with zero issues.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 08:14 PM   #19 (permalink)
No
Member # 106663
I made my own with a hose in the middle and put the small bottle on its side on a scale so I nail the weight. I've just seen the readymade ones.
Durrhh.
Old 06-20-2019, 02:27 AM   #20 (permalink)
gumboot cloggeroo
Member # 467233
Do you usethe schaeder valve to vent gas?
I was doing that but about half would leak at the schraeder valve. I've since bought 5lbs bottles that work good. Rarely use the 1 lbs now.
Old 06-20-2019, 02:35 AM   #21 (permalink)
Member # 225201
The Schrader valve on 1lb. throwaway cyls is also a fixed liquid level gauge.
Just need to make an extended tool to crack it while filling and stop the flow of liquid immediately when it spits. Made a couple by hand but without hardening it, the long ears break off. I need one machined.
I run either 1- or 2- gallon cyls any more with a hose, it’s way cheaper. I carry a pigtail and an adapter just in case somebody else needs a top off on the trail on longer trips.
Old 06-20-2019, 03:41 AM   #22 (permalink)
Soulless ginger
landscraper's Avatar
Member # 124369
I took this pic last week...
landscraper is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 04:41 AM   #23 (permalink)
Member # 82607
My understanding is OP wants to attach a griddle (which has a regulator) to his quick connect for the outside burner at the rear of the camper which that line is already regulated. If he were coming straight off the bottle your statement would be true.
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 04:46 AM   #24 (permalink)
Member # 85771
You are correct.
Regulator on griddle and regulator on pop-up. It sounds like if this was going to be a permanent fixture I could take the regulator off the griddle with much success.
Id like to use it elsewhere so for now Ill just deal with the mean green baby bottles.
Old 06-20-2019, 04:56 AM   #25 (permalink)
No
Member # 106663
I haven't had issues with that, maybe because I live at 10,000 feet elevation?
Durrhh.
