Electricians - a little help please - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-26-2019, 04:55 PM   #1 (permalink)
Abby...someone
edglock21's Avatar
Member # 48547
My wife and I are having a new home built.
The builder has an option to install a 220V outlet, but won't do more then 30 Amp install.
My dilemma is that I need a 50 Amp install for my hot tub.
If I have them do the run with the 30 Amp breakers (I assume 2 - 15 Amps), can I simply swap out the breakers out for 25s to get to 50?
Is the wiring enough to handle the increase in load?
Is it a dumb idea altogether and I should have it run properly from the get-go?
Or should I fuck a blender full of rusty razor blades while gargling bleach and GTFO?
Originally Posted by Frederick Douglass
The limits of tyrants are prescribed by the endurance of those whom they oppress.
edglock21 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 04:58 PM   #2 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
The wire has to be sized to handle the current of the load. Buck up and spend the money for a proper 50.
Originally Posted by Mustard Dog
Me and my co driver were running across the Lakebed on our way to pre run when we saw :gary: walking his dog.
We didn't stop to say hi cause he's a fucking douchebag.
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:05 PM   #3 (permalink)
BIGSTIC's Avatar
Member # 5538
Send a message via AIM to BIGSTIC Send a message via Yahoo to BIGSTIC
Pay the builder the extra for the Hot Tub outlet. Or go talk to the electrician wiring the house for the builder and pay them to do it. You need more than just an outlet for the hot tub and it is cheaper to do it now compared to after the house is built.
Click Above ^^^^^^
"In America, we like everyone to know what we are doing anonymously" Jay Leno
BIGSTIC is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:16 PM   #4 (permalink)
Abby...someone
edglock21's Avatar
Member # 48547
I may not have been clear - the builder won't do a 50.
If I want a 50 I have to have it done after the house is built and this seems to be the route I'll have to go.
Don't know if the builder's electrician would do it for cash, but it won't hurt to ask.
Luckily, it's on a crawl space so that should make it easier, if I have to have it done after construction.
Thanks guys
Old 06-26-2019, 05:17 PM   #5 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
......and put in a 60 amp feed (#6 copper wire minimum). Not all hot tubs can run on 50.
Also, make damn sure you've got three wires in your feed (not counting the bare ground), some hot tubs require a neutral. Should be Black, Red, White and Bare.
Also, the "spa package" mini breaker panel that you'll need outside near the tub must be a GFCI, make sure it's a GFCI with a neutral as well.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:19 PM   #6 (permalink)
gumboot cloggeroo
Member # 467233
Thanks guys
So, you're paying some dude to build something for you, yet he won't build exactly what you want, even for added pay?
I'd tell him to fuck a blender full of rusty razor blades while gargling bleach and GTFO?
Old 06-26-2019, 05:21 PM   #7 (permalink)
flecker's Avatar
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
You need 6/3 for your hot tub... and it runs to a GFI spa box. It'll be supplied from a 2 pole 50A breaker.
He's willing to run a 10/2 for your 220V plug, It'll be a 2 pole 30A breaker.
You will have to pony up the dough for a proper install here. Because of what you said, and I mean this in the nicest way, your gonna fawk it up.
I R A REVOLUTION LEADER!
flecker is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:22 PM   #8 (permalink)
flecker's Avatar
Member # 23744
Thanks guys
Da fawk??? Talk to the Electrician DIRECTLY when he shows up... and fawk that builder.
Old 06-26-2019, 05:24 PM   #9 (permalink)
flecker's Avatar
Member # 23744
All that ^^^^^
This guy ^^^ is either a sparky or at least qualified enough in building trades to "get it".
Old 06-26-2019, 05:37 PM   #10 (permalink)
bigun's Avatar
Member # 29037
Why won't he run a 50 amp?
Have electrician run a 1 inch or larger conduit into the the attic or crawl space and another into the space where you think the hot tub will go and pull it after you move in
“Indeed the safest road to Hell is the gradual one..." C S Lewis
bigun is online now   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:42 PM   #11 (permalink)
Member # 59610
you need a new builder...
Originally Posted by 45acp View Post
Titty bar with moms? Sure why not. Right after I masturbate in church.
jeeptj19992001 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:43 PM   #12 (permalink)
Member # 152638
Circuit amps describes amps per phase. A 2 pole 25a breaker is not a 50a circuit, it’s a 25a circuit. For a 50a, you’re gonna need a 2 pole 50a and 6/3 or 6/4 wire. Builder probably doesn’t want to run an extra 50a for you because it might push the load calculations on the panel to the point of needing a bigger service.
chevydan3 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 05:55 PM   #13 (permalink)
nate379's Avatar
Member # 20099
240v, not "220"
nate379 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 06:07 PM   #14 (permalink)
Member # 53453
Tell him he's fucking fired.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 06:22 PM   #15 (permalink)
Member # 34865
Yup, builder doesn’t want to have to put a bigger service in. Your fifty amp puts him over what he intends to install. If you do it after the house is done. You are gonna have to put a sub panel in probably. If the builder isn’t willing to upgrade the main and put the proper wiring in for more cash. I’d tell him to pound sand and walk away!
Lindon, Utah
rockdog57 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 06:35 PM   #16 (permalink)
Member # 82607
How big is the house? I think what you are being told above is probably accurate. Builder would have to upgrade the service, tell him to do it for cost. I tell customers all the time "there is nothing worse than six months from thinking you should have done something else, it's your money, do it the way you want it and don't look back". If you can swing it of course.
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 06:39 PM   #17 (permalink)
Member # 226216
Tell you builder he works for you! If it means a bigger service fine. But it shouldn’t unless your home has a huge electrical load. It not like the tub runs 24/7. Seriously tell your builder he is your employee and to listen to his boss or pound sand.
Maybe something like this if he says no
Do you know were you parked your truck? Good get in it and GTFO. Your fired!
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 09:17 PM   #18 (permalink)
2big bronco's Avatar
Member # 66684
I'd have a talk with the builder and remind him who si writing the checks.
Old 06-26-2019, 09:27 PM   #19 (permalink)
Member # 104517
This.
Zero fucking excuses when you're getting the bill.
As much as I hate wiring new houses and doing changes (but in my case it's usually stupid expensive as I couldn't tell you the last house I did under $1 mil), I will do any damn thing possible if you want to pay for it.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 10:34 PM   #20 (permalink)
Member # 13786
Werd..
OR just pull 6ga wire through the conduit and swap breaker and plug after
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 10:44 PM   #21 (permalink)
daddytall's Avatar
Member # 74936
Originally Posted by KWTMECH View Post
Werd..
Do this. Tell the builder you just want #6 wire upgrade on the 30 amp circuit.
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 05:22 AM   #22 (permalink)
Member # 104517
Werd..
Most likely no conduit. Typical house gets Romex. Unless you're in Chicago.
R.I.P. Jason Payne
Old 06-27-2019, 05:49 AM   #23 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
This.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 07:11 AM   #24 (permalink)
Member # 225201
It’s your house, fuck the builder or tell him you’ll find a real builder. It’s the whole point of building your own house.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 07:36 AM   #25 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Mine is like this, but it was existing structure.
Easy conversation.
X2
I'd call you a cunt but you don't have the depth or the warmth.
Fuck em' and feed them fish heads-
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
