Tuesday ? on a Friday, Floor peeps step on in. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-12-2019, 10:30 AM   #1 (permalink)
Member # 692185
I have been out of the construction game for many years but am now remodeling our break room at work. Which is a GM Dealership, the old floor was just press type board that was painted. The room is upstairs, my first thoughts are put down a substrate floor then VCT.
What would P.B.B do?
Gearhead001 is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 10:32 AM   #2 (permalink)
Member # 48233
tile..
[quote=texasblake;11194923]
they may be waving like mccain for the rest of their life, but you taught them an important life lesson and they had fun doing it.[/quote]
[QUOTE=xyjbeaker;9759686]"mexican food reminds you of my face?"[/QUOTE]
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 10:33 AM   #3 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
is the current painted board peeling or lifting anywhere?
for a work break room, glue down vinyl sheet wins every time.
cheap, durable, easy enough, highly subfloor tolerant
Old 07-12-2019, 10:34 AM   #4 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
bonus points if it is an obnoxious pattern so that folks are discouraged from hanging out there
Old 07-12-2019, 10:37 AM   #5 (permalink)
Member # 548137
Yes on some crazy shit
Sent from my SM-G975U using Tapatalk
denverd1 is online now   Reply With Quote Quick reply to this message
Old 07-12-2019, 10:39 AM   #6 (permalink)
Member # 692185
Half the paint has been worn off and other parts have been worn down some. I feel like to use the existing floor it would need to be sanded and floated. which would be more work and expense then just putting down a new 1/4 layer.
Doc, what kind of tile? Could I not float the floor and level the tile with the adhesive mortar?
Old 07-12-2019, 10:50 AM   #7 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
if the floor is stable and sound, yeah you could float it and level it with mortar or an overlay, but sheet vinyl will go right over that shit with nothing more than a decent sweeping and mopping and last long enough until somebody decides to remodel
Old 07-12-2019, 10:56 AM   #8 (permalink)
Member # 692185
For the type of wear and abuse the area gets I feel sheet vinyl will end up getting tears. that has been my past experience. That certainly would make install easy though, are there tougher versions of sheet vinyl these days?
Old 07-12-2019, 11:06 AM   #9 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
you should be able to find sheet vinyl with a 20mil wear layer pretty easily. I've personally found that VCT, for the price, doesn't seem to look or hold up any better than a sheet vinyl in service. Yeah, the cheapest thin sheet stuff is still out there, but going up in cost a level or two is a pretty decent product and still cheaper than VCT.
instead of popping up and replacing a tile section if something heavy is dragged across it, you get the pain in the ass of trying to cut out and match a pattern, but typical foot traffic, boots, scratches won't be any different.
click together floating laminates are also much better today than they were 20 years ago and similarly require very little sub prep.
Old 07-12-2019, 11:33 AM   #10 (permalink)
Member # 692185
I really like the click together flooring idea, any particular brands that we know can take the most punishment?
Old 07-12-2019, 11:42 AM   #11 (permalink)
Weasel's Avatar
Member # 5639
or when someone decides to move a fridge and leaves a gouge through the floor. I hate sheet Vinyl. It should be the perfect material but between not being able to get anyone to heat weld the seams or someone moving a heavy whatever right after it's installed and ripping a hole in it, it sucks.
I vote floating floor in the wood look variety. Easy to install and change later.
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
