RSWORDS Paging RSWORDS... prop? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-14-2019, 08:28 AM   #26 (permalink)
RSWORDS's Avatar
Member # 49595
Originally Posted by jblack View Post
The engine looks like it has been raised one set of holes,
it has 5 sets of height adjustment holes and it looks like that it has been raised to the second hole down,
instead of the top hole which would be as far down as possible.
SS Prop was in the box and this is what's on the box
The SS prop is a Mercury Vengeance Part #48-16318A46
(Diameter-13 3/4)
(Pitch-21)
(Blades-rotation 3RH)
(Material SS)
I honestly think the engine is too high and needs to be lowered to what looks like the original position of bottomed out.
The reason I think it's been raised is that looks like scuff marks from where bolts were previously on the engine mount, where it bolts through the transom.
The Al prop looks to be OEM with "832832A45 21P" stamped on it.
It's in the back storage compartment along with a ratchet/socket to switch it out.
Hitting the lake in about 30 minutes to see how the SS prop does.
The vengeance is barely a step above aluminum
You need to level the cavity plate to the bottom of the boat and check height. For you style boat, use, and speed 1" above the bottom. You should just be able to see the cavity plate when running hard
Thank you to the companies that have helped me out
RSWORDS is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 08:42 AM   #27 (permalink)
Fueler's Avatar
Member # 13071
like this...lol
As long as there is still Beefaroni and Budweiser everything will be just fine.
Fueler is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 08:45 AM   #28 (permalink)
Member # 55396
Originally Posted by 2big bronco View Post
So I've never touched a prop but part of the reason I read all these threads is to learn about random shit I'll never need to know.
Is slip basically traction loss? So a 25% loss would be a prop/rpm spinning 100mph of thrust and only pushing a boat 75mph? If that's the case 25% loss pushing a giant boat with a tiny prop sounde pretty good.
Yes on your grasp,of the basic concept, and 15% is the general par target for prop slip in most applications.
The more slip, the more the water aereates from the propeller whipping it into a bubbly froth, thereby making it more difficult for the blades to get firm traction. Could be a contributing factor to the op's cavitation issues on trimming the motor up out while running.
a custom prop shop can fine tune the shit out of a propeller, but It's sort of a dark art that I certainly don't fully understand.
Collector of the LS powered Chebby soccer mom coach.
WTF? is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 10:56 AM   #29 (permalink)
Member # 20237
Trimmed down WOT 4800 RPM, I didn't check speed while trimmed down.
Trimming up at WOT 5250 and 49 MPH with 2 or 4 people,
it doesn't matter whether 2 or 4 people it's 49 MPH at about 5250 and then it starts sucking air.
I suspect cavity height is the issue,
Knock on wood, It's been the most reliable boat that I've ever owned.
Just turn the key and go.
I think the PO had raised the engine to stop the china walk...
Sometimes he let his kids under 18 drive the boat and figured it would be safer if it didn't china walk and get a little sketchy. Just a guess though...
My 16 YO drove it last weekend and basically WOT at all times, and if it were possible for it to china walk then he could've let it get away from him IMO.
I'll have to check the cavity plate for levelness on the bottom of the boat,
just from my memory, I think it's about 3 inches above the bottom of the boat.
jblack is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 10:58 AM   #30 (permalink)
Member # 20237
Originally Posted by Fueler View Post
like this...lol
That would be a hell no for me
My wife would freak the hell out if we were scooting like that.
I also know that the less boat in the water that the sketchier it gets.
Old 07-14-2019, 11:26 AM   #31 (permalink)
paragon's Avatar
Member # 40266
chine
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 02:38 PM   #32 (permalink)
Member # 55396
That speed & rev equates to 12% slip which is very good, but the revs are low indicative that you're over propped; effectively lugging the engine throughout the range.
If your slip numbers are accurate and no current or tailwind is in play in that speed, then you definitely don't need to move the motor down any- that would increase drag and further slow down revs and reduce fuel efficiency.
If you had issues with the prop blowing out under way when you cross wake/ waves then you would lower it
If it were me, I'd try a 17 pitch prop out to correctly load the motor and potentially improve fuel efficiency, although it might cost you a couple mph off the top end.
And it's chine-walk, which is typically a condition driven by hull design characteristics moreso than motor placement.
Old 07-14-2019, 02:47 PM   #33 (permalink)
Member # 20237
Originally Posted by paragon View Post
chine
Originally Posted by WTF? View Post
And it's chine-walk
I'm satisfied with the performance of the SS prop over the aluminum,
I don't feel like making the engine turn more RPMs would benefit the life of the engine,
but hell what do I know, it might actually be better for a 2 stroke to scream,
I really don't know much about 2 strokes.
Old 07-14-2019, 02:52 PM   #34 (permalink)
Member # 20237
I ran the boat upstream and downstream the water, and either way it ran 49 MPH no matter which way I was going.
I'm using a gps for speed verification.
Old 07-14-2019, 03:32 PM   #35 (permalink)
Green bastard
cslimfu's Avatar
Member # 123458
I have a old retro jet boat with a 455 olds in it I'll make you a deal on and you won't have to worry about props anymore.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 07-14-2019, 03:46 PM   #36 (permalink)
RSWORDS's Avatar
Member # 49595
Run with that and be happy. How much trim you can put in the boat depends on so many factors. You numbers are great for the boat you have.
Old 07-14-2019, 04:08 PM   #37 (permalink)
Member # 20237
10-4 on that.
I'm satisfied at this point.
Heavy ass boat running 49 mph, I'm satisfied.
So far (knock on wood) I've never turned a wrench on it other than trading props and installing a new trolling motor.
Now do you have any suggestion for a similar bigger boat?
I really like deep aluminum boats over fiberglass, but that's just my preference.
But I'd like to have a DEEP 21-24 foot aluminum welded boat.
I do like the thoughts of a center console, but I do not know of any such beast in aluminum, I will never own another riveted boat EVER.
Old 07-15-2019, 07:09 AM   #38 (permalink)
RSWORDS's Avatar
Member # 49595
10-4 on that.
We have a 30ish foot aluminum cabin boat for sale here at the shop.
Honestly you are just in the WOT range. You should go down a size in the prop to free it up a bit and not load the motor so much. You wont give up any speed but it will be easier on parts. I'd want to see 5600 if I was propping the boat
Old 07-15-2019, 01:15 PM   #39 (permalink)
Member # 20237
Thanks for your information,
I've owned a boat for many years but never had this issue, everything was already set up and ready to go.
