RSWORDS Paging RSWORDS... prop? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-12-2019, 11:01 AM   #1 (permalink)
Member # 20237
I have an aluminum 21x14 prop on my 19 ft. Tracker Targa,
I also have a Stainless 21x13 3/4 prop with it,
Which will gain more speed?
Currently runs about 42 mph with the 21x14 aluminum prop.
I just installed the stainless 21x13.75 prop, but haven't had time to take it out yet.
I know it's not going to be a huge difference
but what I have read is that stainless will flex less and should be faster if they're the same size but they're not exactly the same.
Usually I get about 5400 RPM's @WOT before it starts sucking air at the prop while trimming the motor up and then the RPM's go up even more while sucking air.
It might not make any difference in props if it's sucking air at 5400 RPM's
hellifiknow
TIA
jblack is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 11:21 AM   #2 (permalink)
Member # 133009
If you have both then put the other one on and see for yourself
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 11:26 AM   #3 (permalink)
Member # 20237
We have a few days scheduled off and we're going out of town in 2 weeks,
I'm curious which prop will get me mo faster,
I don't want to work on my boat while we're there
and take a chance of someone stealing my spare prop while we're out on the water or have it cluttering up the boat storage space.
Old 07-12-2019, 11:31 AM   #4 (permalink)
paragon's Avatar
Member # 40266
TIA
the uminum prolly flexes to match the pitch of the stainless
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 11:35 AM   #5 (permalink)
Member # 20237
Both are 21 pitch
aluminum is 14 inches and the stainless is 13.75 inches.
Old 07-12-2019, 11:57 AM   #6 (permalink)
lil,yota's Avatar
Member # 102395
Maybe the stainless stretches out to 14"
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 12:09 PM   #7 (permalink)
Random Dude
Member # 467273
Put them both on, one behind the other so it goes twice as fast. Use epoxy if necessary. Take video. Report back.
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is online now   Reply With Quote Quick reply to this message
Old 07-12-2019, 12:20 PM   #8 (permalink)
Elwenil's Avatar
Member # 41063
Offer both props outrageous amounts of money to go faster. Whichever one takes the most money will go the fastest.
Isn't that how boats work?
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
I put on my robe and wizard hat. - Bloodninja
Elwenil is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 12:24 PM   #9 (permalink)
Member # 55396
There's another piece or 2 of of prop performance you're missing- what are your revs at Wide Open Throttle (WOT). And another factor is the prop blade design/ manufacturer.
Ideally your prop would allow you to hit the rev limiter on flat water with a lightly loaded/ empty boat when trimmed out (optimal trim for speed/resistance).
Theoretically, the smaller diameter prop should allow the motor to spin faster since there is less blade surface area ( assuming like-kind prop design.) { there is less resistance due to smaller 'paddles' pushing less water}.
The smaller diameter may also make a difference in time to plane & speed of acceleration (due also to smaller blade surface area)
I have swapped diameters from 13.25 to 14" both stainless, same OEM manufacturer in the same pitch and knocked a couple hundred RPM's off the top end and improved holeshot/ torque down in the low rpm's.
An optimized prop setup will hit the motors wide open throttle spec or close to it light and return a ~12-15% slip ratio calculation. https://www.mercuryracing.com/prop-slip-calculator/
Collector of the LS powered Chebby soccer mom coach.
WTF? is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 12:38 PM   #10 (permalink)
Member # 3511
Huh? Your spare prop should be in the boat along with the tools needed to change it.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 12:46 PM   #11 (permalink)
Member # 20237
If the prop gets busted then my trolling motor will get us to our destination or nearest ramp and I'll call my brother and have him pick up my son who will bring the tow vehicle to the nearest ramp and there's plenty of those,
Lake Cumberland is a big lake with lots of ramps. We use the boat for mostly pleasure but it's pretty much a walleye boat with dual consoles and very deep sides.
Old 07-12-2019, 03:03 PM   #12 (permalink)
Member # 55396
none of these provides a rational reason not to carry the spare prop and wrench so that you could just swap props at the nearest ramp and continue your day on the water.
Old 07-13-2019, 04:25 AM   #13 (permalink)
Member # 20237
Probably not but if the prop gets broke then I'm ready for home anyway...
cuz I gots to get a new prop.
But seriously if my prop gets broke, my day on the water is over anyway...
My mood is not going to be for the water after that.
I'll want to get home and see what's the best deal I can get on a prop.
Old 07-13-2019, 05:20 AM   #14 (permalink)
Member # 3511
Meh, you can change a prop on the water easily enough unless it is an inboard. Then your day on the water can continue.
Chuck P
Old 07-13-2019, 10:09 AM   #15 (permalink)
gregj50's Avatar
Member # 151818
So if you get a flat tire out wheelin....
You wanna go home....
Go home....
You wanna go home??????
gregj50 is offline   Reply With Quote Quick reply to this message
Old 07-13-2019, 11:58 AM   #16 (permalink)
RSWORDS's Avatar
Member # 49595
What props are they? Different designs of the same pitch run completely different.
I have 3 different props of the same pitch for my boat and depending on what I am doing I'll put the appropriate one on.
Try em and see. Usually the stainless will have all around better performance then aluminum
Thank you to the companies that have helped me out
RSWORDS is offline   Reply With Quote Quick reply to this message
Old 07-13-2019, 12:07 PM   #17 (permalink)
jeepyj's Avatar
Member # 17637
Good luck with that!
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAHAHAHAHA!!!!!
Treason is about betraying your fellow citizens to an enemy. Not about betraying your government to your fellow citizens.
jeepyj is online now   Reply With Quote Quick reply to this message
Old 07-13-2019, 12:18 PM   #18 (permalink)
RSWORDS's Avatar
Member # 49595
If swapping a prop ruins you day you need a new hobby. Lol
Old 07-13-2019, 06:44 PM   #19 (permalink)
Member # 20237
Go home....
STFUG
hell if you were somewhat funny you'd be bearable,
but you are teh unfunnay
If I break a prop and need to change it,
"meaning I need to buy a new one"...
That will ruin my day.
Plan on trying out the stainless tomorrow...
and taking the aluminum prop as well...
Whether 1 person or 4 people it runs 42/43 mph
Old 07-13-2019, 07:34 PM   #20 (permalink)
Member # 55396
That sounds suspicious.
1) What motor is on your boat and 2) what revs are you turning at Wide open throttle?
This is a similar boat to yours topping out at 47mph with a 16 pitch prop, so you've got something funky going on if you're topping out at 43 both loaded down or light with a 21 pitch.
The similar size & dry weight of this boat would highly suggest you're over propped at 21pitch.
https://yamahaoutboards.com/en-us/ho...xb_5-31-19_wal
Old 07-13-2019, 08:08 PM   #21 (permalink)
Member # 20237
Damn, Can't believe I hadn't posted that
Mercury 150 Optimax
Runs about 42/43 mph at 5400 RPM and while trimming it up then it raises RPM's and starts sucking air at the prop. so I trim it back down until it quits sucking air at the prop.
I plan on hitting the lake tomorrow and see what the SS prop does for it.
When I bought the boat the PO said he used SS prop for pulling tubes and skiers. He bought the boat new...
If I give it almost full throttle from idle, it will damn near jump straight out of the water, like a leap frog.
I've owned the boat for just over 2 years and never tried the SS prop that came with it.
The boat get used just about 2 times per month and sometimes every weekend if the weather allows.
Old 07-13-2019, 08:21 PM   #22 (permalink)
RSWORDS's Avatar
Member # 49595
Mercury 150 Optimax
Hows the engine height? If tour numbers are correct you have stupid ass high calculated slip. Like mid 20s high. You may have a setup issue
You could also gain some wot RPM. I'm curious to see what the stainless does. And what brand/model stainless is it?
Old 07-14-2019, 06:30 AM   #23 (permalink)
Member # 20237
The engine looks like it has been raised one set of holes,
it has 5 sets of height adjustment holes and it looks like that it has been raised to the second hole down,
instead of the top hole which would be as far down as possible.
SS Prop was in the box and this is what's on the box
The SS prop is a Mercury Vengeance Part #48-16318A46
(Diameter-13 3/4)
(Pitch-21)
(Blades-rotation 3RH)
(Material SS)
I honestly think the engine is too high and needs to be lowered to what looks like the original position of bottomed out.
The reason I think it's been raised is that looks like scuff marks from where bolts were previously on the engine mount, where it bolts through the transom.
The Al prop looks to be OEM with "832832A45 21P" stamped on it.
It's in the back storage compartment along with a ratchet/socket to switch it out.
Hitting the lake in about 30 minutes to see how the SS prop does.
Old 07-14-2019, 07:50 AM   #24 (permalink)
Member # 55396
Mercury 150 Optimax
43 mph with a 21 pitch prop is 25% slip, which is pretty bad/ inefficient.
The WOT spec range of that is 5250-5750 so you're in it but have room to go up.
I would think the ss prop should improve the performance with its smaller diameter.
But if not, a step down to a 19 pitch prop may improve performance as well.
Edit:
The al prop appears to be a Mercury black max 14.25x21 pitch
The Mercury prop selector seems to point to a ~15" x 16 pitch prop.
https://www.mercurymarine.com/en/us/...or/#!/step-one
Old 07-14-2019, 08:27 AM   #25 (permalink)
2big bronco's Avatar
Member # 66684
So I've never touched a prop but part of the reason I read all these threads is to learn about random shit I'll never need to know.
Is slip basically traction loss? So a 25% loss would be a prop/rpm spinning 100mph of thrust and only pushing a boat 75mph? If that's the case 25% loss pushing a giant boat with a tiny prop sounde pretty good.
