67 Mustang - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-18-2019, 01:08 PM   #26 (permalink)
trampas's Avatar
Member # 5433
67 < - - favorite year pony coupe
What are we supposed to do with nature, just stare at it? Is it like porn with leaves?
:Philipoff2:
trampas is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 03:05 PM   #27 (permalink)
3Cs
Member # 45122
Can't tell if good trade or not. Need more pics.
3Cs is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 05:19 AM   #28 (permalink)
today
fredycruger's Avatar
Member # 225557
i agree 67 is the best looking year
fredycruger is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 05:49 AM   #29 (permalink)
Member # 90667
I suggest finding a manual steering setup and swap the steering box and the tie links (tie links are different length). Parallel parking can be tight but it will steer straight regardless and never ever ever EVER leak.
Ford power assist leaked from the factory.
Gittinwidit is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 05:57 AM   #30 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I learned how to drive on a '67 Mustang coupe. Fun car.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 06:01 AM   #31 (permalink)
Circus Ring ******
Bubba the Red's Avatar
Member # 867108
1. I'm jealous.
2. I have a feeling you are at the beginning of a great adventure.
“If there are no dogs in Heaven, then when I die I want to go where they went.”
― Will Rogers
Bubba the Red is offline   Reply With Quote Quick reply to this message
Old 07-19-2019, 06:02 AM   #32 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Or he could go with the conversion kit from CJ Pony Parts. Not exactly cheap, but reliable.
https://www.cjponyparts.com/borgeson...-1967/p/PSK21/
Old 07-19-2019, 10:36 AM   #33 (permalink)
today
Member # 225557
to do that id have to lose power steering pump and swap the water pump to std rotation, or just get idler pulley, i hope it doesnt leak, i want to use the parts i got already
Originally Posted by Bubba the Red View Post
1. I'm jealous.
thank you, i think ill be finding lot of WTF and mismatched parts
I was thinking of that steering box, but its still too early to be buying parts
i started to hook up the pump to steering valve last night
thats the last thing to hook up before i can fire the engine
off course i got wrong hoses and pump missing fitting
hose i got is for 68 mustang it has 5/16 fitting, 67 head 1/4"fittings
i got some ghetto fitting put together to convert to 1/4" but ill get new correct hose.
in my parts bin i found water cooled fuel pump setup from my boat
and it had fitting i needed.
fitting at pump is M-16 o ring to 45 flare i believe.
wasted bunch of time to come up with way to run the engine with P/Spump hooked up and run out of time to fire the engine.
the engine crank over with starter so thats good.
and when i primed oil pump ,oil came right up trough the push rods.
i did took off the valve covers and made priming tool out of old distributor that was in the trunk with oil pump driveshaft.
the oil pump shaft supposed to be installed in the engine from bottom.
with star washer, so it doesnt come out with distributor or fall into pan.
will have to go trough the valve train and check the preload bc. i dont trust that mouthbreather, who put it together
and have to redo tranny cooler mounting
Old 07-19-2019, 10:39 AM   #34 (permalink)
trampas's Avatar
Member # 5433
I restored a 67 while in college. It was a learning experience I would not like to repeat. FoMoCo reamed my wallet until it was red and sore.
:Philipoff2:
Old 07-22-2019, 05:36 AM   #35 (permalink)
today
Member # 225557
got the engine fired up Sunday and broke the cam in
car sounds pretty good and engine is healthy
have header leak on pass side and need to weld the exhaust where it joins at headers
60# of oil pressure
first time around the valves were really tight and had to re-adjust them couple of time.
i think its because the lifters pumped up with oil and threw the settings off,
they were too tight that couple cylinders didn't even make combustion
also when i did adjustment i follower direction that came with lifters
took up the slack until you cant turn the pushrod with your fingers and tighten the rocker another 1/2 turn
this also made the preload too tight.
what worked in the end i loosened up the rockers and snug them down at 0 preload and left them
timing was also fun,( I've never mess with this stuff before)
when i read...point the distributor rotor to # 1 cylinder
it mean #1 on distributor cap
not actually point to #1 cylinder lol
it makes sense now idk what i was thinking
Old 07-31-2019, 12:17 PM   #36 (permalink)
today
Member # 225557
been chipping away on the car little bit .
wheel offset been fixed by 1/4" spacers that were on sale for 7$
didn't noticed they were 4 lug 4.5" lol
used jeep wheel spacer as template and re-drilled the holes
got all power steering hoses changed and hooked up.
installed new boot on the assist cylinder.
in spare part box i had new mounting hardware
new CCW fan showed up and got mounted
and have brake booster sorted out
had to enlarge firewall hole for booster to fit trough
and once that was done i had to lengthen the push rod and might as well make it adjustable
took 2$ threaded coupler and 3/8" SS bolt and had the adapter made on the lunch brake,
the coupler got plug welded to the push rod and bolt slotted and eyelet tig welded together
onto the brake lines next, and tidy up the wiring
Old 07-31-2019, 12:35 PM   #37 (permalink)
bigun's Avatar
Member # 29037
Sounds like you are getting it sorted out
“Indeed the safest road to Hell is the gradual one..." C S Lewis
bigun is offline   Reply With Quote Quick reply to this message
Old 07-31-2019, 01:02 PM   #38 (permalink)
JunkyTJ's Avatar
Member # 64554
I hate a motherfucker that can't write a sentence on directions. I've spent days re-doing procedures that were only wrong by a word missing or added.
Point at #1 cylinder. Point at #1 spark position. Makes you want to beat them until they can admit there is a difference. In your case, I can forgive them because well context. Directions are supposed to be written so anyone can understand what to do even if they don't know why they are doing it.
Tellico rally post 441
JunkyTJ is offline   Reply With Quote Quick reply to this message
Old 07-31-2019, 01:55 PM   #39 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Tell us about the Jeep Truck video that comes up after the Mustang startup one.
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 07-31-2019, 02:19 PM   #40 (permalink)
Member # 38200
I learned this one the hard way myself. The point where you can't easily rotate the pushrod is when the valve starts to open. Just take out any wiggle room (zero preload), then another 1/2 turn.
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 08-01-2019, 06:47 AM   #41 (permalink)
today
Member # 225557
one wheel wonderpeel
thats my project truck i been working on for about 6 years on & off
Started as 84 CJ7
i got the diesel engine out of UD dump truck, that frame rotted out.
the engine is pretty popular in australia in nissan patrolls.
its the best engine they say lol
Old 08-01-2019, 06:57 AM   #42 (permalink)
today
Member # 225557
Yeah getting there..
it made pretty good bang at 10PM like a gun went off
i went back and forth so many times checking timing, TDC
took the valve covers off few times. it really took 3 nights getting it sorted out . almost pulled timing cover off
good times..
yeah i adjusted them 3 times wrong lol
Old 08-01-2019, 07:19 AM   #43 (permalink)
flecker's Avatar
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
Oh hell yah! Your getting it man.
Engine sounds healthy.
I R A REVOLUTION LEADER!
flecker is offline   Reply With Quote Quick reply to this message
Old 08-01-2019, 07:48 AM   #44 (permalink)
Member # 131502
I've ran into this problem with higher lift cams also. I just got to the point where it gets 1/8th turn and then I go back in if there is any lifter tick and they get a little more until the tick goes away. Have had them where 1/4" turn was too much.
Frozen ZJ is offline   Reply With Quote Quick reply to this message
Old 08-01-2019, 08:43 AM   #45 (permalink)
No
Member # 106663
Started as 84 CJ7
Nice work on both.
Durrhh.
Old 08-01-2019, 08:50 AM   #46 (permalink)
flecker's Avatar
Member # 23744
Started as 84 CJ7
That thing is bad ass... like a CJ8 on roids.
Old 08-14-2019, 08:19 AM   #47 (permalink)
today
Member # 225557
thanks guys
no time for update just started to frame my house
anyway car is running. and just finished up header gaskets and will upload video later.
going to DMV to get plates
Old 08-14-2019, 04:47 PM   #48 (permalink)
Member # 40417
nice work great to see it coming along.
Better to be a racer for a moment, than a spectator for a lifetime.
FlexyTJ is offline   Reply With Quote Quick reply to this message
Old 08-31-2019, 05:31 AM   #49 (permalink)
today
Member # 225557
car running nice finally
had to get new rocker arms, push rods and guide plates
[/url]
Old 08-31-2019, 06:10 AM   #50 (permalink)
No
Member # 106663
had to get new rocker arms push rods and guide plates
Did you throw on umbrella seals for the hell of it or would they not fit?
Durrhh.
