Car Air Conditioning Tech In GCC........ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2019, 02:34 PM   #1 (permalink)
xr-nut's Avatar
Member # 175047
2004 Grand Prix. On snappy ac machine low pressure is 25, high pressure is 75-100. Obviously won't blow cold. With pressures so low we put a compressor on it. Used from LKQ.(ya ya ya I know, but its a cheap car). That first compressor did nothing, so I had lkq send me another one. Same pressures, not cold. We put an expansion valve in it, no change. I took it to a buddies shop and he said "put a new compressor on it". So I did, brand new. No change. Read online maybe the condenser is slightly plugged, so I ordered a new one. While it was out we flushed the lines, both ways. Put an hour of vacuum on the system, refilled and no change. What am I missing here?
cliffs:
3 compressors
1 expansion valve
1 condenser
system flush
still not cold.
“Those who make peaceful revolution impossible, make violent revolution inevitable.” JFK
xr-nut is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 02:40 PM   #2 (permalink)
BIG-O's Avatar
Member # 109702
Not sure if it will help your situation or not, but everytime you open up a system you should change the filter drier. Especially after a compressor change.
Why did god invent whiskey? So the Irish wouldn't rule the world!
BIG-O is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 02:41 PM   #3 (permalink)
Member # 229499
Sounds under charged with those pressure's.... With the AC off, depending on temperature, should have both at 75-100. Running, high side should be up closer to 200, and low side around 30-40.... You sure you're not mixing "kg and lbs" when you're charging it?
Sent from my SM-G950U using Tapatalk
foxmxrcer is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 02:46 PM   #4 (permalink)
Member # 229499
2.2lbs, or .997kg of r134a according to alldata. Sound right?
Old 07-26-2019, 02:54 PM   #5 (permalink)
Member # 1956
Undercharged. At about 90 degree ambient temp, 45 to 55 PSI on the low side, around 250 or little more high side. Just did a 2002 Blazer compressor last weekend. Charge it and then let it sit for about 15 minutes and recheck..
http://rechargeac.com/how-to/ac-system-pressure-chart
Jerry Brown: If Trump is elected, we'll build a wall around California! MAGA!
Shadow man is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 02:58 PM   #6 (permalink)
xr-nut's Avatar
Member # 175047
No, not mixing up the freedom units vs communist units! I just checked our napa resource and it shows 2.4#. I could swear my mechanic just told me 2#. That could be the problem. F me running.
Old 07-26-2019, 03:14 PM   #7 (permalink)
xr-nut's Avatar
Member # 175047
Could .2 to .4 deficit be enough to make these numbers? I texted by tech and he said he's been putting in 2#. The sticker on the car shows 2.3#. ugh
Old 07-26-2019, 04:48 PM   #8 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Charge until the return line into the compressor is cold. When that line is so cold that when you grab and squeeze it the cold hurts, the system is properly filled.
Pressures vary with ambient temperature. The system needs cold return to cool the compressor and it also shows that there is no liquid in the evaporator, because some is expanding after it.
This is the plain and simple way to do it and it works.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 06:15 PM   #9 (permalink)
Member # 192237
no, grandpa
thanks to the magic of the CPEV and TXV you'll blow the fuck outta the burst disc before you get anywhere near painful cold on the low side
Old 07-26-2019, 06:17 PM   #10 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Originally Posted by [486] View Post
no, grandpa
Get off my lawn.
Always tip.
Old 07-26-2019, 09:23 PM   #11 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
Typically no, but I would evac and pull a deep vacuum on it then refill by weight and make sure you are putting liquid in and not gas.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 07-27-2019, 06:03 AM   #12 (permalink)
xr-nut's Avatar
Member # 175047
What do you consider a deep vacuum?(we pulled on it for an hour before we left last night, it had -30 on it when I came this morning, I pulled another 30 minutes then I plan to charge it)
And, wouldn't my ac machine put the freon in the car how it needs to be done?(not trying to be a smartass, Im dumb to ac and trying to learn here)
Old 07-27-2019, 06:47 AM   #13 (permalink)
xr-nut's Avatar
Member # 175047
I put 2lb 7oz in. Blowing ice cold. Low side is really high. According to the link above, maybe I f'd up the expansion valve flushing it ?? one pic is system cycling, the other is system off(lower value).
Edit: I was told to close my valves and that made the numbers better.
Old 07-27-2019, 06:51 AM   #14 (permalink)
Crisbee1's Avatar
Member # 133544
Blend doors are fucked.
Crisbee1 is offline   Reply With Quote Quick reply to this message
Old 07-27-2019, 06:51 AM   #15 (permalink)
xr-nut's Avatar
Member # 175047
so, here it is, the answer. Only posting our dumbass trial and error so maybe someone else can benefit from us being stupid.
Old 07-27-2019, 07:33 AM   #16 (permalink)
Member # 229499
That looks much better.
Old 07-27-2019, 07:55 AM   #17 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
high side seems low? I always heard double outside temp +50
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is offline   Reply With Quote Quick reply to this message
Old 07-27-2019, 08:06 AM   #18 (permalink)
yozsi's Avatar
Member # 91857
That's deeper than deep so you are good there. I like to pull vacuum for 15-20 mins. Then let sit for 15-20 mins to check for leaks and let moisture boil out of the oil/etc, then pull vac for another 15-20. Yea the machine should be pulling liquid unless someone put the bottles in wrong.
I'm Old school as fuck and use no machine. I just do gauges, scale, vacuum pump and occasionally psychrometer and thermocouple to do superheat or subcool.
Foreign Car Center
Vallejo, CA
Old 07-27-2019, 08:28 AM   #19 (permalink)
Member # 1956
I made it dirt simple. Look at my post and attached chart.
Old 07-27-2019, 08:48 AM   #20 (permalink)
xr-nut's Avatar
Member # 175047
If anything, the low side looks a little low, according to the chart. But it is blowing cold now, so Im going to leave it alone. Thanks for posting that chart, I printed it off for future reference!
Old 07-27-2019, 09:30 AM   #21 (permalink)
Member # 181868
I don't know how you post a meme, but I would put that black guy on that says "He's right, you know"
On the "deep vacuum", I've said this before, you don't know what you got if your using AC gauges for vacuum. You have to use a micron gauge.
Here you can see an AC gauge reading full vacuum. Note the micron gauge reading 4450 microns.
Here you see the AC gauge still at full vacuum, but the micron gauge is at 1640 microns.
There is a world of differnce between 4450 and 1640 microns, but you wouldn't know it by the AC gauge. A "deep vacuum" would be about 400 microns. Lots of vacuum pumps won't even go that low.
Every time I bring this up, someone says they've been doing this for 30 years and it works. That's great. I'm not saying it won't. I've seen people charge a system with no vacuum and it worked. Just saying, don't fool yourself. If you don't have a micron gauge, you don't know what kind of vacuum you're pulling. AC gauges are not designed to measure vacuum accurately.
Project : Amphibious HEMTT
