3 piece wheel peeps... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-29-2019, 05:56 PM   #1 (permalink)
Member # 67907
Ive dissembled quite a few 3 piece wheels before, and never had an issue getting the tire to separate from the outer flange. They usually just slide right off, or come apart after some gentle prying.
This tire is probably 20 years old and will not separate from the outer flange.
Ive tried pry bars, setting the inside of the flange on a block of wood and hitting it with a bead breaker, hosed it with penetrating oil and let it sit all weekend, and finally tried to use the excavator to pry it off while holding it with the skid steer.
Nothing seems to be working.
Any tips before I try to find a way to cut it off the flange without messing the flange up?
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 07-29-2019, 06:00 PM   #2 (permalink)
Member # 60661
Put it on a tripod then press on it.
Ditchdigger is offline   Reply With Quote Quick reply to this message
Old 07-29-2019, 06:02 PM   #3 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Heat it with a rosebud.
Charlie Daniels of the well rig
M92pv4u is online now   Reply With Quote Quick reply to this message
Old 07-29-2019, 06:03 PM   #4 (permalink)
Member # 183520
Try brake fluid. It will break down the tire.
I never get stuck, only temporarily delayed!
OutlawRider is offline   Reply With Quote Quick reply to this message
Old 07-29-2019, 06:09 PM   #5 (permalink)
Member # 101819
Put it back on rim put lock ring on and use one of these. Squirt the bead between ring and tire with areokroil.
https://www.ebay.com/i/201929992660?...AaAm5qEALw_wcB
I have one of these and it works good. I think I got mine from northern tool.
Thepanzerfuhrer is online now   Reply With Quote Quick reply to this message
Old 07-29-2019, 06:23 PM   #6 (permalink)
Member # 67907
The ring just slides all the way to the inner bead, so the inner and outer beads hit each other on the wheel.
I have another 24" wheel that I might try to dig up and try sliding it on to see if it does the same thing.
Stupid rim design, however the other 5 from this thing all came apart without issue, so who knows.
The Beepster
Old 07-29-2019, 06:27 PM   #7 (permalink)
Member # 101819
That press grabs a hold of the ring and won’t let it slide back and rim. It then pushes the bead away from ring. I had it were I had to do it in 5-6 places squirting pb blaster type oil in the gap the press makes before it breaks loose.
Old 07-29-2019, 06:29 PM   #8 (permalink)
Member # 67907
Ah, I see now. Ill order one to have it for the next time, I need to get this POS back up and running to go grade some roads this week.
The Beepster
Old 07-29-2019, 06:33 PM   #9 (permalink)
Member # 101819
Put tire back and pay the $50 and watch the tire shop do it.
When you use that press you need to have locking ring on or it pulls off the rim. That was random link do your research before buying.
I hate 3 piece rims. They suck compared to the 5 piece rims. My grader had super old tires on it also so I said fuck it and had the tire shop change them.
Old 07-29-2019, 06:39 PM   #10 (permalink)
Member # 67907
The other 5 went without issue, I used the blade to pop the inner beads off that were stuck. This last one is fighting me hard. Ive destroyed the tire sidewall so I'm committed now.
Ill give it 1 more shot then take it to the tire shop tomorrow.
The Beepster
Old 07-29-2019, 07:29 PM   #11 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
1/8th lb of tannerite aughtta do it
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
Old 07-29-2019, 08:09 PM   #12 (permalink)
Member # 95763
More lube?
I've had good success using an engine hoist and a dead blow hammer. Put the tire under the hoist legs and pull using the hoist arm.
It looks like you have equipment and way more force applied.
KarlVP is offline   Reply With Quote Quick reply to this message
Old 07-29-2019, 08:20 PM   #13 (permalink)
Member # 192237
the whole reason we're stuck with glycol ether brake fluid now is that it was once chosen because it was gentler to rubber brake hoses than normal petroleum oils
so, nope, BS bud
use fire, enough to get it smoking and the ring'll fall right off
Old 07-29-2019, 08:51 PM   #14 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Yup. Hell I don't think you'd even have to put it back on the rim. Wouldn't it clamp onto just the bead ring and push the tire off? Looks to me like it has enough depth to the ring that it'd have enough to clamp onto.
EDIT. Those hydraulic bead breakers are worth their weight in gold when you start doing equipment tires...
The one, the only, the Dane.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 07-30-2019, 03:57 AM   #15 (permalink)
Member # 101819
You need to put it back on rim. It needs something to grab onto. Just not enough meat there with the ring by it self.
Old 07-30-2019, 08:18 AM   #16 (permalink)
arse_sidewards's Avatar
Member # 256962
I would stick the mini-ex bucket on it like pictured then I would get an 8" scrap of 2x4, stick that under the rim (to protect it) right by the bucket then I'd stick a bottle jack under that and start pumping.
Even if it doesn't come off all the way around you can still take an angle grinder to the bead in the one place it does come off.
arse_sidewards is online now   Reply With Quote Quick reply to this message
Old 07-30-2019, 08:31 AM   #17 (permalink)
welndmn's Avatar
Member # 398
Needs more fire.
Mark
Old 07-30-2019, 08:37 AM   #18 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
What was wrong with that tire?
For stubborn beads I've got a section of railroad rain I cut at an angle at one end to go between the bead and the rim. Then I carefully drive whatever I have that's heavy up the rail. Never failed me yet. You just need more force than the mini-ex and bobcat can provide. A dump truck with 10 yards of sand works well. If I had a locomotive laying around, that would work even better.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 07-30-2019, 08:40 AM   #19 (permalink)
Member # 70148
So will sunlight, but I doubt he has 250 years to wait.
I've had tires covered in brake fluid from leaks that never had so much as a check to show for it.
Old 07-30-2019, 06:19 PM   #20 (permalink)
Member # 67907
Originally Posted by welndmn View Post
Needs more fire.
This did the trick. Weed burning torch for the win.
The Beepster
Old 07-30-2019, 06:21 PM   #21 (permalink)
Member # 67907
Tire was shot 10 years ago. It sucked as a steer tire on my grader even.
For normal rims your method would work, for a 3 piece that wont work, the bead is about the same thickness as the flange so you would just press the bead against the ground.
The Beepster
Old 07-30-2019, 06:40 PM   #22 (permalink)
supersize75k5's Avatar
Member # 29341
tire shop.
Uless you have endless time to fuck around with problems that are cheap to solve.
supersize75k5 is offline   Reply With Quote Quick reply to this message
Old 07-30-2019, 08:19 PM   #23 (permalink)
Member # 104517
I've had WD-40 lubed tires melt to the rim. Had a flat and ran it flat and the bead wouldn't let loose until I soaked it in more WD-40.
I'd guess it's still petroleum enough to melt rubber if you can wait a day.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Old 07-31-2019, 12:37 AM   #24 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
ZAG built a sweet one of those tire clamp bead pusher thingys.
It was fully mechanical and used bolts to clamp and push. Had ball bearings turned into the ends of the bolts like a snap-on BJP1 press.
I say build one like his for next time.
Muckin_Slusher is online now   Reply With Quote Quick reply to this message
