Heating a ~18x20 to 220* - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2019, 11:28 AM   #1 (permalink)
nate379's Avatar
Member # 20099
Have a kiln that uses a Nyle dehumidifier style drier.
It's designed for low heat, slow curing, for lumber. Around 100-120*
I am trying to dry firewood. It works for that, but the load we tried took 3 weeks and $600 of electricity.
If I had a way to heat the kiln to around 200-220*, it'd take about 3 days to dry.
Electric heaters would work, but at .20 kw/hr it's expensive.
Thinking of a diesel fired heater, like a Frost Fighter or a house furnace.
Ideas?
nate379 is online now   Reply With Quote Quick reply to this message
Old 08-02-2019, 11:34 AM   #2 (permalink)
Member # 59610
use wood
Originally Posted by 45acp View Post
Titty bar with moms? Sure why not. Right after I masturbate in church.
jeeptj19992001 is online now   Reply With Quote Quick reply to this message
Old 08-02-2019, 11:36 AM   #3 (permalink)
Member # 7412
Damn that is expensive electricity, I second the wood.
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 12:07 PM   #4 (permalink)
nate379's Avatar
Member # 20099
A wood boiler system will be around 15k. Plus wont get that hot.
Old 08-02-2019, 12:31 PM   #5 (permalink)
Member # 161826
Some sort of a biomass furnace. (Burn wood)
https://2knowabout.blogspot.com/2017...eater.html?m=1
Or a solar kiln.
pdangerp is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 12:40 PM   #6 (permalink)
Member # 53453
Stove made from two propane tanks. The big ones. Put it in the kiln. Load it up for a burn, light, seal the kiln and come back when the fire goes out.
Hook your air compressor up to it for extra jam.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 12:43 PM   #7 (permalink)
Member # 226216
Or a solar kiln.
From my reading solar kilns only get up to 110-130deg depending on outside air temp, sun and design of kiln.
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 12:47 PM   #8 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
I assume you have a reason for trying to dry firewood in this manner.
But it seems to me it would make more sense to buy a year ahead and let the sun and breeze dry it out for free.
Clodhopper is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 12:48 PM   #9 (permalink)
nate379's Avatar
Member # 20099
It would need to be outside the kiln.
Had a setup like that on a smaller kiln for lumber. Worked ok, but it was pretty much a full time job keeping the stove full.
Old 08-02-2019, 12:52 PM   #10 (permalink)
nate379's Avatar
Member # 20099
Most folks buy ahead, but have plenty that wait to the last minute.
Trying to get it where I can have dry wood in a few days.
Don't have enough room to stockpile more than 15-20 cords processed wood for it to dry. Yard is pretty well full with several hundred cords of logs and equipment.
I can buy a commercial built firewood kiln, but want to wait a bit before investing that kind of $$.
Old 08-02-2019, 04:40 PM   #11 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
Or a solar kiln.
Yeah, solar, that's the ticket!
Member # 20099
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 08-02-2019, 04:43 PM   #12 (permalink)
Member # 53453
It will work really good for about 3 days of the year!
Old 08-02-2019, 05:19 PM   #13 (permalink)
Member # 66677
Solar works fine for lumber. I havenít tried firewood though. For lumber you want a slow drying process to keep it from splitting so much. If I want to though I can get the temperature up no problem mid spring. During the winter I was hitting temperatures around 135 when it was 0 degrees outside. I found that my cheapo outdoor temp reader from Walmart will max out at 151 degrees so I donít know how hot it gets in the summer. The only problem with solar is the heat and cool cycle having to bring the load up to temperature everyday.
If he keeps the load light in it it will likely work fine. Still will take a month though at least and wonít fit his timeline of wanting it done in a few days.
[QUOTE=Rooney77;14997648]We choose not to ignore you because we choose to "cleanse" our beloved PBB of as much ignorance as possible. I'm sure having klansmen in your heritage you can understand the mentality. You are the jew of the PBB. Look in you e-yard, that's our cross burning.[/QUOTE]
HUSSLR187 is online now   Reply With Quote Quick reply to this message
Old 08-02-2019, 06:37 PM   #14 (permalink)
Member # 192237
stop looking for a wood boiler
look for an old actual boiler, like old locomotive or sawmill boiler
then you can run it under pressure and get it to 250 degrees in there
Old 08-02-2019, 06:48 PM   #15 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
Really? I haven't seriously investigated. Due to the angle, we don't get much energy, even with the long days...
Old 08-02-2019, 06:50 PM   #16 (permalink)
nate379's Avatar
Member # 20099
Neither of those is something that exists around here, at least not in any form that I would trust using now.
Plus putting in a steam plant would be a headache with insurance I think. Vs a std home heat wood boiler.
this is the type of heater I was thinking of:
https://www.constructioncomplete.com...IDH500QR-B.pdf
Dunno how well it'd work though.
Old 08-02-2019, 06:51 PM   #17 (permalink)
2big bronco's Avatar
Member # 66684
How many chords do you sell in a year? I cant imagine the extra work of loading into and out of a kiln plus the cost of drying is worth it... what about the obvious answer of paying for a little more help up front to get a year or 2 ahead of the orders?
2big bronco is online now   Reply With Quote Quick reply to this message
Old 08-02-2019, 06:52 PM   #18 (permalink)
nate379's Avatar
Member # 20099
I have 18 solar panels on my roof at the house.
They don't make much power from Nov-March.
Old 08-02-2019, 06:53 PM   #19 (permalink)
nate379's Avatar
Member # 20099
In the area of about 400 cords a year.
This is the first year doing seasoned wood. Before that, it has just been that the customer deals with drying it... usually by buying in advance.
I kept rough track last year of all the inquires for dry wood (typically fall and winter) and decided to try it out. I have about 18 cords I have drying from this spring and that took up all the room I had.
The space that even 50 cords would take up just isn't going to work out, plus it'd need to be under a roof. We have about 3 acres and it's pretty well taken up by equipment, buildings and log piles.
And it's tough to predict how much would be needed.
If it works out well, probably will setup with a commercial firewood kiln, but at this point not going to shell out 20k just yet.
Originally Posted by 2big bronco View Post
How many cords do you sell in a year? I cant imagine the extra work of loading into and out of a kiln plus the cost of drying is worth it... what about the obvious answer of paying for a little more help up front to get a year or 2 ahead of the orders?
Old 08-02-2019, 07:56 PM   #20 (permalink)
Member # 226216
I did not realize it got that hot. What are your thoughts on drying it in a shipping container? My containers during the summer are right around 120-130 during the day, over a 100 by 9am itís currently about 7 and they are still well over 110. Would they cool off to much at night? Cold mornings are in the upper 50ís. I guess I should just go take a temp reading first thing in the morning. I should just start a thread for this...
Old 08-03-2019, 12:26 AM   #21 (permalink)
Random Dude
Member # 467273
What's your cost per gallon of diesel or fuel oil?
3 GPH x 24 hours = 72 gallons per day x 3 days = 216 gallons of fuel per load.
Looks like marine diesel's $3/gallon there - that'd be ~$650 per load for energy.
1/7th the lead time may justify the expense, but include your energy costs & machine amortization into your cost per load.
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is online now   Reply With Quote Quick reply to this message
Old 08-03-2019, 12:38 AM   #22 (permalink)
Member # 52361
Waste oil?
Shipping container painted flat black, north south oriented?
Edit
I don't know anything about biomass, but if I was cutting down trees, and paying to heat 75% of it, and possibly disposing of 25% of it, i think I'd find a way to burn it
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 05:09 AM   #23 (permalink)
Mopar Moe's Avatar
Member # 653210
I was thinking waste oil as well, or maybe build a small biomass boiler that burns waste oil and waste wood (soft wood), Ive seen a few simple systems that utilize gravity fed waste oil into a large heavy plate steel wood stove with a blower...
Causing spontaneous disassembly in various motorsports for over 45 years
Mopar Moe is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 06:29 AM   #24 (permalink)
Member # 66677
Well shit I wasnít paying attention to location. A light load may take a few months and not be much better than air drying.
If youíre wanting to dry lumber You may have trouble controlling temperature with a container. Painted black, you should have no problem getting the temperature up. Itís when you want to keep it around 125-130 with the vents closed in the middle of summer since you just put in a fresh load and donít want it to let a lot of moisture out.
As far as cooling off, it all really depends on how much is in there to hold the heat. Empty space cools faster than the same space loaded with wood. On the other hand it may take a while to get all wood up to temperature if thereís a lot of it. The heat/cool cycle didnít bother the lumber as much as letting out too much humidity too fast.
Old 08-03-2019, 07:31 AM   #25 (permalink)
BossBuilt's Avatar
Member # 1760
Electricity to dry fire wood? You're doing it wrong.
BossBuilt is offline   Reply With Quote Quick reply to this message
