Farm Tractor tech in GCC - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-03-2019, 08:20 PM   #1 (permalink)
paragon's Avatar
Member # 40266
this is pretty cool and am thinking of buy a set
Simply attach the male plate of the PTO Linkô to your PTO drive-line then attach the female plate to the tractorís PTO spline. Disconnecting your PTO shaft is now as simple as pulling the release on the spring-loaded shear pin. Now there is no more hassle or headache connecting or disconnecting to your power take off. Once the PTO Linkô system is installed to each tractor and to each implement, the PTO Linkô system permanently changes your PTOís interface and never needs to be removed. The PTO linkô system will work with any implement and tractor rated under 100 HP.
https://tractorptolink.com/
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 08:30 PM   #2 (permalink)
Member # 67907
Is pulling a collar back on a PTO shaft that much of a hassle? I think it probably takes me 5 seconds to do that and slide it on or off.
Solution to a non-existent problem
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 08:31 PM   #3 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
Nice. I like it.
'80 CJ7- soon to start project "always changing directions"
'84 CJ7- all stock farm rig, except a bunch of gun racks
'79 CJ5- not stock- way too much to list
Rttoys is online now   Reply With Quote Quick reply to this message
Old 08-03-2019, 08:32 PM   #4 (permalink)
TR
TR's Avatar
Member # 2877
They should work fine for 3 point implements but draw bar implements will vibrate when turning due to the universal pivot plane being pushed rearward. Deere's design gets away with a quick coupler setup due to the yoke being replaced by a dedicated coupler system
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 08:34 PM   #5 (permalink)
Rooster831's Avatar
Member # 361841
just another part to fail
but aleast if it breaks you can just hook your pto up like every other person in the world
Spending thousands of dollars on a vehicle for the sole purpose of driving over shit in the woods.
Rooster831 is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 08:34 PM   #6 (permalink)
Green bastard
cslimfu's Avatar
Member # 123458
Turn a collar, wiggle, pull and it's unhooked. That's how they all should be.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 09:18 PM   #7 (permalink)
paragon's Avatar
Member # 40266
Pulling back a collar? Itís not for a riding lawnmowe
[COLOR="Black"].
[/COLOR]
Old 08-03-2019, 09:21 PM   #8 (permalink)
Member # 18282
We have collars on our 21’ rice choppers behind 300hp tractors.......
I'm what you call your basic famous.
Stix is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 09:21 PM   #9 (permalink)
BossBuilt's Avatar
Member # 1760
This^ . Now lining the splines is my only issue. But it's not much of an issue.
BossBuilt is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 09:26 PM   #10 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Yeah fuck that nonsense... Either push the button or slide the collar back and hook/unhook the pto. What is so hard about that?
The one, the only, the Dane.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 09:31 PM   #11 (permalink)
paragon's Avatar
Member # 40266
Originally Posted by Stix View Post
We have collars on our 21í rice choppers behind 300hp tractors.......
I donít own a piece of equipment that came with a collar. All push-pin
Bush hogs, rake, bailers, kuhn cutter, tiller, etc
I donít have to explain the why. If you donít understand the need, you donítunderstand
[COLOR="Black"].
[/COLOR]
Old 08-03-2019, 09:35 PM   #12 (permalink)
BossBuilt's Avatar
Member # 1760
Then I'll just say keep looking because there is a shit ton better out there.. That shit looks wimpy as hell.
Old 08-03-2019, 09:39 PM   #13 (permalink)
Rednek
Member # 52387
You ever try cleaning and/or oiling your pto splines? Kinda like a hi-lift jack. Hit that shit with some wd-40 or other cheap as shit aerosol lubricant every time before you use it and life will not suck so much.
Old 08-03-2019, 09:49 PM   #14 (permalink)
bigun's Avatar
Member # 29037
I need a PTO shaft first anybody know where to get a close to 73 inch one JD on one side and IHC on the other
ďIndeed the safest road to Hell is the gradual one..." C S Lewis
bigun is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 10:09 PM   #15 (permalink)
Rednek
Member # 52387
What do you mean JD on one side and IHC on the other?
Is it a 540 or 1000 pto shaft?
Do you need a 6 spline 540 on one end and a 21 tooth spline 1000 rpm on the other?
These are links to pics of each type...
540 rpm:
https://www.surpluscenter.com/Power-...t-1-2935-6.axd
1000 rpm:
https://www.surpluscenter.com/Power-...t-1-2936-6.axd
Old 08-03-2019, 10:51 PM   #16 (permalink)
bigun's Avatar
Member # 29037
JD mower and IHC 884 I bought them separately from the town and they started stripping the mower I don't know why nothing from a 34 year old mower is going to fit their new shiny one so now I need the shaft that runs between them. As close as I can measure there is 73 inches from the notch on the splines of the mower to the one on tractor. I believe it to be 1000 rpm
Old 08-04-2019, 04:49 AM   #17 (permalink)
Member # 67907
6 spline is 540, 20 spline is 1000rpm.
Nothing specific about a JD vs IH, the PTO shafts follow an SAE standard so it should be universal.
The Beepster
Old 08-04-2019, 05:40 AM   #18 (permalink)
bigun's Avatar
Member # 29037
Figured the ends were standard it's the 73 inch part I have trouble finding
Old 08-04-2019, 06:03 AM   #19 (permalink)
Member # 198851
Your know it all attitude should know it not really needed....
I'm not all that smart...but smart enough to realize it...
ADChevy4x4 is offline   Reply With Quote Quick reply to this message
Old 08-04-2019, 06:58 AM   #20 (permalink)
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
Just make one. They sell all the parts for it in my local tsc. I'm sure you can find them easy online as well.
Building high performance turbo diesel motorcycles.
dethmachinefab is offline   Reply With Quote Quick reply to this message
Old 08-04-2019, 07:29 AM   #21 (permalink)
Rednek
Member # 52387
No local farm equipment "junkyards" around? There's a local place here that has a shit load of PTO shafts from old junked equipment you can sort through looking for the one that'll work just right, or that you can modify to work...
Old 08-04-2019, 07:46 AM   #22 (permalink)
Member # 192237
they're like square tube driveshafts
the slip is like 2/3 the compressed length of the shaft, you don't need anything exact, just close
Old 08-04-2019, 07:52 AM   #23 (permalink)
bigun's Avatar
Member # 29037
Mostly ranching not much farming here since the 50s drought started. I haven't found any kind of tractor junkyard. Hmm now that I think about it Sceep might
Old 08-04-2019, 08:03 AM   #24 (permalink)
Member # 86724
this
https://www.tractorsupply.com/tsc/ca...tor-pto-parts#
if I can make this ancient non standard tiller fit a cat 1 three point, you can do anything.
many adapters, much welding.
Old 08-04-2019, 08:09 AM   #25 (permalink)
Member # 5371
Send a message via MSN to rockota
Interesting concept, and I can definitely understand the benefits. Sometimes, depending on the implement, it can be had to get the splines to align or have enough movement to decouple...
But.... while I genuinely like the concept, the videos imply that it has a good amount of slack when connected. That part bugs me.
rockota is offline   Reply With Quote Quick reply to this message
