Ford 460 guys, help me be a cheapass... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-15-2019, 08:17 PM   #1 (permalink)
Juztyn00's Avatar
Member # 52569
Send a message via MSN to Juztyn00
95 Ford F250, No compression on one cyl, Torn down, find broken rings and a broken piston, cyl will be fine with light hone, Issue being I can only find a sealed power piston ($17) which has the "shallow" oil grove which requires I buy a full set of premium rings for $123. I rather buy the set of standard rings for $22 that could be used on the rest of the pistons to freshen it up. Anyone have a std stock piston sitting on shelf by chance?
Juztyn00 is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 09:20 PM   #2 (permalink)
2big bronco's Avatar
Member # 66684
If you want to be really cheap just drop the piston out of the oil pan, run a quick drill powered hone and shove a junkyard piston back in. It's a 460, it will be fine.
2big bronco is online now   Reply With Quote Quick reply to this message
Old 08-15-2019, 09:29 PM   #3 (permalink)
Juztyn00's Avatar
Member # 52569
That's what I'm shooting for, only hoping I don't have to waste a day at the Picknpull pulling another engine out just for a piston. Hoping someone had one or a source for one.
Old 08-16-2019, 05:52 AM   #4 (permalink)
LeviGarrett76's Avatar
Member # 13654
tech in here might help you with what you need and the different pistons in the efi years.
i couldnt find anything in the classifieds
https://www.460ford.com/forum/37-eng...fi-piston.html
1968-1972 460 pistons stock dish, -12 cc, 1.76 compression height
1973-1986 460 pistons stock dish, -22cc, 1.75 compression height
1987-1992 460 EFI pistons stock dish, -7 cc 1.76 compression height
1993-1997 460 EFI pistons stock dish, -15cc, 1.77 compression height
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency.
LeviGarrett76 is offline   Reply With Quote Quick reply to this message
Old 08-16-2019, 07:02 AM   #5 (permalink)
Member # 192237
ebay is usually loaded up with used pistons and rods, always someone looking for just one to get by
Old 08-16-2019, 07:52 AM   #6 (permalink)
Juztyn00's Avatar
Member # 52569
Perfect, found what I needed and got it ordered... thank you..
Old 08-16-2019, 09:21 AM   #7 (permalink)
Member # 13654
no problem, anything to keep me from working
Old 08-16-2019, 11:25 AM   #8 (permalink)
Member # 94747
Keep me informed on how this pans out. I've got a 70K mile 460 from a 97 that did the same thing. Had a wrecked 90 with 286K, swapped the old engine into the newer truck and its still running. I'd like to fix the broke piston one the same way, on the cheap re-ring re-bearing and stuff it an older pickup.
[COLOR="Red"]MUDDNUTT racing #4531[/COLOR],[COLOR="Cyan"] Falken Tire[/COLOR], [COLOR="Yellow"]ADS[/COLOR], Jimmys4x4,[COLOR="Red"] RuffStuff Specialties[/COLOR], [COLOR="DarkOrange"]ARB usa[/COLOR], [COLOR="Wheat"]Savvy offroad[/COLOR], [COLOR="Silver"]Raceline wheels[/COLOR], John Rants
jr4x is offline   Reply With Quote Quick reply to this message
Old 08-16-2019, 11:30 AM   #9 (permalink)
Member # 141094
OP is so tight he probably squeaks when he walks.
Speed costs money, how fast do you wanna go?!
crazydave is offline   Reply With Quote Quick reply to this message
Old 08-16-2019, 01:28 PM   #10 (permalink)
Juztyn00's Avatar
Member # 52569
Ferd parts aren't cheap, about $300 worth of parts ordered from Rockauto to freshen up the engine, Going to go ahead and re-ringing all all the pistons and slap in a new set of bearings. only has 110k on it but looks like the previous owner was lax on oil changes. I couldn't even tell it was missing when I was driving it, just was pushing oil up into the air box.
Got the caliper out and checked the piston I pulled and it has the shallow metric rings already so the only choice was the expensive ring set.
