skool me on automatic battery disconnects - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-01-2019, 12:11 PM   #1 (permalink)
roundhouse's Avatar
Member # 16751
who has em on their vehicle, and which ones do you like/not like?
looking for something that will automatically disconnect the battery when it gets low.
Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?[Alan Keyes]
For some, Freedom matters, for most, prosperity suffices.[Fred Reed]
74Bronco EFI 5spd
roundhouse is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 12:14 PM   #2 (permalink)
Member # 106178
Why?
takotruckin is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 12:27 PM   #3 (permalink)
roundhouse's Avatar
Member # 16751
Originally Posted by takotruckin View Post
Why?
got a daily driver , either a 77 K10 or a 65 Falcon that sits at a truck terminal for 4 to 10 days at a time
74Bronco EFI 5spd
Old 09-01-2019, 12:27 PM   #4 (permalink)
Member # 79509
you'lll have to school me. whats the point of disconnecting it if its already low?
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 12:33 PM   #5 (permalink)
roundhouse's Avatar
Member # 16751
one place i worked at had em on their bus, if it dropped below 11 volts it disconnected the battery so it couldnt get too drained to crank the engine
74Bronco EFI 5spd
Old 09-01-2019, 12:39 PM   #6 (permalink)
Member # 106178
If you have a battery that is going dead in 4 or 10 days adding a device like this is going to add more load to it. A properly functioning vehicle should be able to sit 30+ days without any problems starting.
Old 09-01-2019, 12:44 PM   #7 (permalink)
RSWORDS's Avatar
Member # 49595
I've installed a handful of these for people on boats. Work well and adjustable from 11.3 to 12.1 for cut off.
https://www.bluesea.com/products/763...age_Disconnect
Thank you to the companies that have helped me out
RSWORDS is online now   Reply With Quote Quick reply to this message
Old 09-01-2019, 12:59 PM   #8 (permalink)
roundhouse's Avatar
Member # 16751
https://www.summitracing.com/parts/rfw-ms11/overview/
https://www.summitracing.com/parts/sms-t3-12v/overview/
something like this is what im looking for real world users.
74Bronco EFI 5spd
Old 09-01-2019, 01:03 PM   #9 (permalink)
Member # 775873
Get a battery tender, had one on a car that I mostly kept in the garage , worked every time.
FJC11 is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 01:31 PM   #10 (permalink)
Member # 229476
I like the idea of the automatic battery cutoff. Never heard of that before.
But if you know the vehicle is going to be sitting for long enough to possibly drain it, why not just disconnect one cable? Or if the battery is difficult to get to, install a cutoff switch. I've got a big cutoff switch on a few of my vehicles for this reason, they don't get driven all the time.
If it ain't a flat-fender, it ain't much.
Crimson White and Indigo
danielbuck is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 01:50 PM   #11 (permalink)
Member # 213125
Yes. I had a shit box that got started every 5 or 6 months. Never had any problems.
Aisin is online now   Reply With Quote Quick reply to this message
Old 09-01-2019, 02:02 PM   #12 (permalink)
Circus Ring ******
Bubba the Red's Avatar
Member # 867108
I would think that a set of Anderson connectors, disconnected when you leave the vehicle, reconnected when you come back to it would be a hell of a lot cheaper. Failsafe and damn near unfuckupable. Just my .02
"If ever I meet one of you Texas waddies who ain't drunk water from a hoofprint, I think I'll... I'll shake their hand or buy 'em a Daniel Webster cigar."
John Wayne
True Grit
Bubba the Red is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 02:24 PM   #13 (permalink)
Member # 192237
put a toggle switch on the radio's power
ain't anything else on them that'll kill the battery
unless you've got some EFI stuff going on, in that case make sure you're putting switched power to the right inputs
Old 09-01-2019, 04:14 PM   #14 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
11 volt battery is already fucked, and beyond "cranking ability"
12.5 is "dead" and 12.0 is nearly fucked. 11 is really fucked.
+whatever on maintainers (I like NOCO)
and
+whatever on a disconnecting means.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 04:22 PM   #15 (permalink)
Elwenil's Avatar
Member # 41063
Put one of the little solar maintainers on it and not worry about killing the battery all the time.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
Odin Owns Ye All
Elwenil is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 04:29 PM   #16 (permalink)
Member # 44136
I would say just get a manual one. Simple and nothing to fail
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 08:18 PM   #17 (permalink)
xjtony's Avatar
Member # 50866
Originally Posted by [486
;44586300]
Radio power draining battery? My 85 K10 will kill a battery if it sits for any length of time. I just unhook the negative batt cable every time I park it. And I literally drive it like 10 times a year maybe. I figured the damn clock in the dash drains the battery because it makes all kinds of noise running/ticking away.
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 08:23 PM   #18 (permalink)
daddytall's Avatar
Member # 74936
Pics of the Falcon? It was my first car
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is offline   Reply With Quote Quick reply to this message
Old 09-01-2019, 08:30 PM   #19 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
A 1 wire alternator can also drain the battery if it is fucked up, or that's been my experience. I've started wiring them into a big constant duty solenoid, so that when the key is off it kills power going to the alternator as well...
The one, the only, the Dane.
billybob_81067 is offline   Reply With Quote Quick reply to this message
Old 09-02-2019, 06:08 AM   #20 (permalink)
Member # 82607
My 2000 Dodge pickup had one, had to get under the hood to re set the red button. I was always leaving my headlights on
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 09-02-2019, 06:29 AM   #21 (permalink)
45acp's Avatar
Member # 13671
I had one 100 years ago on a full size blazer, back when us youngins would hang around outdoors with kegs listening to tunes. Worked awesome, would shut down with just enough juice to crank engine.
In your situation, I think I would be more interested in figuring out what's draining my juice in such a short period of time.
45acp is offline   Reply With Quote Quick reply to this message
Old 09-02-2019, 08:50 AM   #22 (permalink)
Member # 192237
ehhh just take the time to wire up the extra two wires
Old 09-02-2019, 09:08 AM   #23 (permalink)
roundhouse's Avatar
Member # 16751
That works if you park it in a garage
I have six cars and one carport
74Bronco EFI 5spd
Old 09-02-2019, 09:09 AM   #24 (permalink)
roundhouse's Avatar
Member # 16751
I have a solar maintainer on my lawnmower
I use the mower two or three times a summer and before I put the solar panel on it , the battery was always dead
74Bronco EFI 5spd
Old 09-02-2019, 09:10 AM   #25 (permalink)
roundhouse's Avatar
Member # 16751
74Bronco EFI 5spd
