Grout pump, build ? Or buy? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-08-2019, 08:40 AM   #1 (permalink)
roundhouse's Avatar
Member # 16751
At work . We will have a job site coming up in a few weeks or months where we have about 90 wells that are about 40 feet deep .
About half are 4” diameter and and the other half are 2”
These have to be filled with bentonite and grout mixture
Anybody ever built a grout pump ?
Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?[Alan Keyes]
For some, Freedom matters, for most, prosperity suffices.[Fred Reed]
74Bronco EFI 5spd
roundhouse is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 08:45 AM   #2 (permalink)
Member # 178200
No, but my company rents them if your intrested.
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 08:56 AM   #3 (permalink)
Lil Uzi's Avatar
Member # 6359
Our fleet at work uses Moyno pumps, bumper mounted on 3-axle work trucks. Building one, I don't think that's productive or cost effective. Probably buy a new pump for about 2X the cost of trying to build your own, and avoid the risk of having it not perform or fail. But, yeah, you could save a lot of money by DIY and not having the well driller destroy or "abandon" the wells. Your not in CA, fortunately, as a discrete well grout here requires a permit, a licensed well drilling contractor and of course, the County or agency $inspection$.
not surprized yer confused yer face was burried in the pillow pretty deep as gizim drunk as you were
Lil Uzi is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 08:57 AM   #4 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Will they allow the use of ⅜ bentonite chips? That will be faster than pumping grout down the wells.
M92pv4u is online now   Reply With Quote Quick reply to this message
Old 09-08-2019, 10:17 AM   #5 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
What type of pump are grout pumps generally
Kelly Kaiser
Vertical Limits Inc
913.731.3040
for the fastest quick release extinguisher mounts available and UTV parts
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 10:38 AM   #6 (permalink)
abrzrkr's Avatar
Member # 29912
Send a message via AIM to abrzrkr
I would assume diaphragm on any kind of slurry.
If everyone was just like you then what would we need you for?
abrzrkr is online now   Reply With Quote Quick reply to this message
Old 09-08-2019, 10:44 AM   #7 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Ours is a progressive cavity pump it can build 300 psi deadhead but stops moving bentonite around 150 psi.
Old 09-08-2019, 11:36 AM   #8 (permalink)
Vertical Limits
Member # 26443
Knew a guy that drilled and I would swear he said theirs was a piston pump of some type, but wasn't sure how that would work
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Old 09-08-2019, 11:41 AM   #9 (permalink)
Member # 178200
You are correct.
The grout pumps used with our drill rigs are all piston pumps. Never seen a diaphragm pump being used, anywhere. All the concrete pump trucks use piston driven pumps as well.
Top picture they are using a trailer mounted piston pump, Putzmeister brand, to move grout. Second picture the company was using a Schwing brand concrete pump truck, with piston pump to move grout.
Old 09-08-2019, 11:45 AM   #10 (permalink)
roundhouse's Avatar
Member # 16751
Originally Posted by SLOWPOKE693 View Post
You are correct.
Yeah
All I’ve seen the drillers use are hydraulic cylinder
74Bronco EFI 5spd
Old 09-08-2019, 11:47 AM   #11 (permalink)
roundhouse's Avatar
Member # 16751
Not in Cali
We can just pour bentonite chips
That’s how we usually do it
Got a client that I think will want grout
But if not we will just dump the chips from a 50 lb bag
One site we used three pallets of bentonite bags
74Bronco EFI 5spd
Old 09-08-2019, 12:40 PM   #12 (permalink)
Member # 106837
Single or double acting piston pumps for tieback grout. Similar to the chemgrout cg500 series.
chzbrgr is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 12:41 PM   #13 (permalink)
roundhouse's Avatar
Member # 16751
I also have a project at my house where I need to fill some metal support posts with grout to add some strength because the poles are rusty in a couple spots
Thought about drilling a 3/4 or one inch hole at the top and pumping in grout
74Bronco EFI 5spd
Old 09-08-2019, 12:54 PM   #14 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Back in the day my dad used the 5x6 gardener denver mud pump on the rig to pump grout and neat cement. We have a smaller 3x4 gd pump the plan is to add a 200 gallon hopper to it for deep seals well abandonment or mixing thick quick gel to get gravel to wash out of the borehole.
Old 09-08-2019, 01:35 PM   #15 (permalink)
Lil Uzi's Avatar
Member # 6359
None of the pumps described here in any fashion lend themselves to being built by the user. Sounds like you are closing off construction de-watering wells. I guess it's a secret. Doesn't say if there is any water in the "wells" or how deep it is...... At any rate I don't think you will build your pump. FWIW the Moyno pumps are a screw inside a cylinder run by a hydraulic PTO. Not sure what "type" of pump that is but they are reliable and ideally suited to pumping heavy vis fluids and slurries. You don't need a piston pump for that. But whatever works Remember 2 and 4-inch holes guys. Chips in a 2-inch hole = bridging. If he does grout, it will be a 1-inch or .75-inch diameter PVC inside a 4-inch or 2-inch hole.
Old 09-08-2019, 01:45 PM   #16 (permalink)
roundhouse's Avatar
Member # 16751
We use moyno pumps to pump water out of the air water separator tanks from the subterranean vapor extraction
A regular centrifugal pump won’t pull water from a tank under vacuum
74Bronco EFI 5spd
Old 09-08-2019, 01:48 PM   #17 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
I believe that the bentonite chips can be treated with ez mud to prevent bridging.
Old 09-08-2019, 02:01 PM   #18 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
The one that we use is this design with the positive displacement moyno screw rotor pump.
Charlie Daniels of the well rig
Old 09-08-2019, 03:23 PM   #19 (permalink)
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
A tow behind concrete pump would be what I'd try and get.
Could pump slurry with a peristaltic pump. That's easy to build.
Building high performance turbo diesel motorcycles.
dethmachinefab is online now   Reply With Quote Quick reply to this message
Old 09-08-2019, 03:39 PM   #20 (permalink)
Member # 2710
Lol. Bridging seems to be what some geotech drillers want. Uses less chips and pays the same. No one will ever check anyhow.
Bentonite grout mix trimied to the bottom of the hole with a poly pipe is the way to be sure the hole is completely filled.
Just had a job that a contractor tried to abandon some horizontal drains using neat grout pumped from the collar. 1.5 inch pvc drains about 400 feet long and 100 ft of elevation head with 0.020 inch transverse slots. Guess what we found when we later cut the slope. “Seeps” that happen to have a half grout filled drain that didn’t even have grout get through the majority of the slots. Guess we know what won’t work for that any how.
1986 Toyota PU 4x4
2008 Toyota Crew Max PU 4x4
ToyFord is offline   Reply With Quote Quick reply to this message
