camping stove help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-16-2019, 01:46 PM   #1 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
camping stove help
over the weekend loaded up the family for a camping trip. first one out with all of us (thewife, 4,3,1 and i). we were camping about about ~7800' and the temps were probably in the mid 40s when i was trying to make breakfast. i had the moral dilemma of make coffee or feed my kids. i would like to avoid this in the future, so was it too cold for the propane to evaporate fast enough?
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
Last edited by mobil1syn; 09-16-2019 at 02:19 PM. Reason: updated to actual elevation
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 01:54 PM   #2 (permalink)
Member # 152683
Nope, propane boils at -44ish degrees
Sent from my Pixel 3 XL using Tapatalk
Mrmikeypoo is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 01:57 PM   #3 (permalink)
TatonkaII's Avatar
Member # 12454
Send a message via AIM to TatonkaII
What problems were you having? Sounds like a regulator issue, but I don't think I've been at 8500' either. However, I have cooked in much colder temps with no problem.
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..
TatonkaII is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 01:58 PM   #4 (permalink)
Member # 312354
Nope, you were at 8500' which is going to hurt output of the stove. You could also have a gas flow issue, should have plenty of bottle pressure but if the internal filter on the stove is crusty it's not gonna run right. Could also be a bad valve on the bottle.
Was this a 1lb cylinder stove or were you using a 20lb tank?
ironmangq is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 02:19 PM   #5 (permalink)
mobil1syn's Avatar
Member # 9795
this but not as nice from being bounced around the dezert for years. 1lb bottle
ive cooked with it at KOH in cold temps, but it was always just for myself. so i would make coffee, then breakfast. essentially single burner use. one burner functioned normal, but soon as i turned the second one on it would fall on its face. tried a half full tank, full tank, almost empty tank. if i shook the bottle both burners would run well, but then fall on their face when i stopped shaking. also i just checked, i was probably closer to the 7800'
-George Whitefield
Old 09-16-2019, 02:25 PM   #6 (permalink)
Member # 4387
You need a liquid gas stove, I have a multi fuel that runs regular gas or coleman fuel. They are a few more $$ than propane but work way better in the cold. Propane canister stoves don't work for shit in colder temps.
Norm is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 02:44 PM   #7 (permalink)
mobil1syn's Avatar
Member # 9795
will a 5 gallon fair better?
-George Whitefield
Old 09-16-2019, 03:42 PM   #8 (permalink)
BDK
BDK's Avatar
Member # 295498
I have had that same stove for 20 years. I have been all over, up to 10,500', cold, hot, snow camping, and it has always worked very well. Higher altitudes effect efficiency, but not flow. Cold should not effect anything. Maybe your lines are clogged and freezing up? I think you have a bad regulator or clogged lines and/or filter.
In politics, stupidity is not a handicap.-- Napoleon Bonaparte
BDK is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 03:55 PM   #9 (permalink)
Member # 45049
All else being equal, YES! You were burning the vapor off faster than the liquid in the bottle could boil to vapor. The more surface area there is, the faster the propane can boil. That's why shaking it up made it work better. You were artificially increasing the surface area in the bottle. Bigger bottle = more surface area...
R.I.P 80 F150 roller cam 5.0 with GT-40 heads
You break it then I fix it... Professional Mechanic
4x4mechanic is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 04:04 PM   #10 (permalink)
Member # 4387
Propane looses pressure as it gets colder, those little canisters can't hold enough pressure long enough even mostly full. It's a combination of the small canister and low pressure with the lower temps. A large propane tank would probably help, but coleman fuel( or white gas) or regular gasoline stoves work fine in the cold. I have a small single burner multi fuel I carry in the winter in Montana.
Old 09-16-2019, 05:35 PM   #11 (permalink)
Member # 235556
I got tired of the Coleman two burner and buying the 1 lb canisters so I picked up one of those dual fuel Coleman's. Lasted 2 trips before something went wrong with it and I ended up with a 6 foot tall flame. Also wasn't a fan of not enough surface area. Ended up buying one of those 2 burner camp chef ones with legs. Thing is amazing. Hi heat is almost worthless because of how much heat it puts out. Maybe 5 minutes to boil 3 gallons of water, and I end up using it at home for homebrewing and canning and stuff. Been going strong for probably 4 or 5 years now and when I'm not camping it's set up on the deck for when I don't want to heat up the house cooking inside.
90 Bronco, 351w, np435, 205 doubler, 4 inch long arm lift and 33x12.5 MTR's
72 Bronco
Tell_Sackett is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 05:40 PM   #12 (permalink)
Circus Ring ******
Bubba the Red's Avatar
Member # 867108
Norm's got this.
ďIf there are no dogs in Heaven, then when I die I want to go where they went.Ē
― Will Rogers
Bubba the Red is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 05:42 PM   #13 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
I have given up on anything made by Coleman. It's all junk these days.
Every day is better than the next.
Benny is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 05:44 PM   #14 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Place the 1 lb bottle atop one of the burners. Will help it vaporize.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 06:34 PM   #15 (permalink)
Member # 226216
Buddy I camp with has one. Same opinion.
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 06:35 PM   #16 (permalink)
Member # 226216
Originally Posted by Bubba the Red View Post
Norm's got this.
Find them at garage sales in elderly neighborhoods. Loots of deals to be had on well cared for 50ís-70ís Coleman stuff.
Old 09-16-2019, 06:41 PM   #17 (permalink)
emiller22207's Avatar
Member # 116537
Norm's got this.
Yep, fuel is the way to go. I still use a four burner Coleman dual fuel cook stove and a couple of lanterns easily 50 years old my dad used camping when I was a kid. They still work like champs.
I still have a couple Coleman fuel catalytic tent heaters that seem to work fine, but Iím not willing to use them in a tent anymore. I use a Mr. Heater Buddy with a 5 gallon tank adapter and rigged a grommet in the tent, so the tank stays outside.
I have a little one burner fuel stove, 30 years old I used for backpacking thatís still put to regular use.
May those that love us, love us; and for those that don't love us, may God turn their hearts; and if he can't turn their hearts, may he turn their ankles; so we may know them by their limping
emiller22207 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 06:58 PM   #18 (permalink)
Baconologyst
smurfblue40's Avatar
Member # 32029
Thatís why you hit Craigslist and buy the ďvintageĒ old school stuff
I had a wild hair a couple years ago and bought up a few older two burners, and a couple lanterns. All of my outdoor cooking and illumination needs have been met
US Army Infantry 1983-1992
Imjin Scout DMZ
smurfblue40 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 07:28 PM   #19 (permalink)
Member # 852732
Nice.
My Coleman stove instructions came at 11 with one that took fuel or gas ďI only use one burner because the second takes from the firstĒ
Thatg9659 is online now   Reply With Quote Quick reply to this message
Old 09-16-2019, 07:39 PM   #20 (permalink)
BDK
BDK's Avatar
Member # 295498
I found 4 of those old Coleman liquid fuel stoves up in the loft of my parents garage. 2 look brand new.
Old 09-16-2019, 08:18 PM   #21 (permalink)
Baconologyst
Member # 32029
When we went through my grandparents place, I found a old stove in the crawl space above the garage. Iíd have to do a little research, but I think it may date back to the Oklahoma dust bowl days (thatís when they came out west). After a little cleaning it fired right up
Imjin Scout DMZ
Old 09-16-2019, 08:33 PM   #22 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
I live at higher altitude than that and use all kinds of stoves and if they don't work right it's not because its a propane bottle fueling it. I fill those little bottles off a bigger bottle too. I like the 2 burner propane stoves that have a 3 ft or so hose between the stove and the propane bottle the best. I can cook on 1 side and brew coffee with my Coleman drip campstove coffee maker on the other burner with no issues. I've done it at treeline which is usually around 11,000 feet here so the altitude theory is wrong.
Durrhh.
Filthy McChevy is online now   Reply With Quote Quick reply to this message
Old 09-16-2019, 08:56 PM   #23 (permalink)
Member # 53528
just separate them and run two tanks
https://www.amazon.com/Coleman-QuikP.../dp/B004E4IAEQ
Old 09-16-2019, 09:03 PM   #24 (permalink)
Member # 777769
https://www.llbean.com/llb/shop/1196...ner-camp-stove
Undefined taco got this camp chef stove last year and I won’t look at Colman anymore. I think he got it cheeper on amazon. It will way outperform the Colman. Also use 2x the propane.
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 09:08 PM   #25 (permalink)
Member # 226216
I have one of those catalytic heaters as well. I have used it in a tent with a vestibule by keeping it in the vestibule and leaving the very top of the tent door unzipped and screen kept closed. We then put a battery powered carbon monoxide detector inside the tent. Never gone off but has kept us warm when the weather took a shit and dropped almost 30 degrees in the forecast for a hunting week.
