Ground fault woes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-18-2019, 07:30 PM   #1 (permalink)
Member # 181868
Ground fault woes
When I run power somewhere outside for a pump, lights or whatever, I like to install weatherproof receptical so in the future I have a place plug something in. I always use a ground fault receptical. After I install it, I always test it. (Not just the test button, but I plug something in)
So, I bult three story watertower deck a few years ago. Since I have lights and ceiling fans, might as well put plugs on all three levels. Installed and tested. Of course I almost never use them.
Last year I decided to pressure wash the second level roof panels. Plug the electric pressure washer in and nothing. Check it out and the receptical is shot. Not just tripped, it won't reset. So I replaced it and washed the roof.
Last month I wanted to vacuum the water tank on the third level. Plug a small pump in and nothing. Check it out and again the recept is shot. Install a new one and vacuum the tank.
Since I had the vacuum pump right there, I decided to vacuum the water fountain right next to the tower. Of course I plug in to the recept on the bottom floor. You guessed it, no worky.
Ok, I don't know, maybe the tower got struck by lightning.
Today I wanted to run a concrete saw. I recently had a new well dug and put a recept next to it. Plug the saw in and shit. WTF
Am I the only one having this issue? All of these receps were bought from Lowes. I've done a lot of wiring, some fairly serious stuff. But I'm not above admitting a mistake. The problem is what exactly could I be doing wrong? It's not like they are complicated and they all worked when I first put them in.
Project : Amphibious HEMTT
Old 09-18-2019, 07:37 PM   #2 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
I just put in a couple GFCIs last week. The package said "Self-tests regularly, and auto-disables at the end of life for added safety."
Read to me as "shit's gonna break itself."
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 07:56 PM   #3 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Our company bought a refurbished steam cleaner like eight years ago and it started tripping the gfi plug. So one day it wouldn't stop tripping it and I thought nbd plugged it into a regular receptacle. I climbed under the truck and started cleaning when the heating coil got up to temperature I started getting electrocuted luckily I was able to crawl out from under the truck .moral of the story sometimes it is actually a ground fault no matter how many times the steam cleaner technician checked it out.
Charlie Daniels of the well rig
M92pv4u is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 08:01 PM   #4 (permalink)
Member # 181868
This wouldn't bother me. But these are not delivering power period. After replacement the plug in item works with out issue.
Old 09-18-2019, 08:20 PM   #5 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
Ive pulled gfi plugs apart and there were ants in the contacts.
Old 09-18-2019, 08:20 PM   #6 (permalink)
Member # 53528
are you installing them in a protective box like this?
https://www.amazon.com/gp/product/B00JU532B0
if not you should be
Old 09-18-2019, 08:43 PM   #7 (permalink)
88mitsu's Avatar
Member # 125523
this.
and weather resistant GFCIs?
But, even if you have the bubble covers and an outdoor box, gfcis will still fail often if they are out in the open with no eave or anything to hide under. Smear a bunch of duct seal over the top of the box to try and keep water from running in. Also, install drain holes in the boxes.
GFCIs have circuit boards inside them, if they get wet enough times they stop working. Depending on how it's wired, it might be better to use a GFCI circuit breaker and replace the GFCI outlets with regular weather resistant outlets.
The bLowes here sells Legrand, which IMO is garbage. Leviton FTW.
START UP THE ROTORS
88mitsu is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 09:07 PM   #8 (permalink)
bigun's Avatar
Member # 29037
If it is on it's own circuit replace it with a GFI breaker, they are more sensitive than the outlet, and are better protection
“Indeed the safest road to Hell is the gradual one..." C S Lewis
bigun is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 09:22 PM   #9 (permalink)
BossBuilt's Avatar
Member # 1760
This. You don't put GFCI's outside.
BossBuilt is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 09:28 PM   #10 (permalink)
Member # 53528
yes you do, in protective covers, along with the proper GFCI outlet
Old 09-18-2019, 09:34 PM   #11 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Those bubble covers are the gayest shit I've ever seen in my life. The few times we've hired an electrician to do work, as soon as the electrical inspector is gone I rip them off and put a normal outlet and a fucking regular outdoor cover on.
The one, the only, the Dane.
billybob_81067 is online now   Reply With Quote Quick reply to this message
Old 09-18-2019, 09:42 PM   #12 (permalink)
Member # 53528
if youre not a retard they work great mine snap shut with an extension cord plugged into them, a gay ass normal outdoor cover doesnt do that so when youre using it its not protected
Old 09-18-2019, 10:36 PM   #13 (permalink)
Rednek
Member # 52387
Like I give a fuck if it gets some rain on it... Ohh noes!
Old 09-18-2019, 10:39 PM   #14 (permalink)
Member # 181868
I'm useing the kind where it's sealed if there are no plugs in them. It's a spring loaded cover with a rubber seal. The wires are in conduit and there's no sign of water when I take them apart. Two of them were under a roof, so no direct water. (Unless some sideways rain. I don't use the outlets but once an awhile. And I'm not useing them while it's raining. The fact is, I didn't use any of them at all except for the initial test.
Old 09-18-2019, 11:23 PM   #15 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
All the outdoor outlets on my porch are standard receptacles. The circuit that runs them goes through a GFCI outlet located in the basement next to the electrical panel, before it heads outside. You only need one GFCI at the beginning of the circuit and it covers the rest of them.
Likewise the ones in my kitchen are the same way...there's a single GFCI at either side of the stove, and then all the ones along the counter are protected by that. Might be something to consider, especially on something like your tower where it's probably all on one breaker anyway.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 06:33 AM   #16 (permalink)
abrzrkr's Avatar
Member # 29912
Send a message via AIM to abrzrkr
I am having trouble picturing this thing. You got a build thread?
If everyone was just like you then what would we need you for?
abrzrkr is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 07:36 AM   #17 (permalink)
Member # 54455
This. It's got circuit in the name. One protects the entire run. I would swap the breaker in the panel and use water resistant outlets and covers.
Boats n Does
Deuce 40s is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 08:21 AM   #18 (permalink)
Member # 7412
double check your neutral..
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 08:37 AM   #19 (permalink)
BossBuilt's Avatar
Member # 1760
Let me rephrase that. I don't. Bugs don't care about your stinking covers. I've been running my exterior receptacles off indoor GFCI's for 10-15 years now, no issues tests perfect every time. Bugs nest and goo up the receptacles outside. I have a total of 8 all under covers.
Old 09-19-2019, 08:44 AM   #20 (permalink)
Member # 181868
So that ruins them or can you wash them out with electric-clean? I do have lots of ants.
I never knew this. Thankyou! I have two dedicated lines to the tower. Can't remember how they are arranged. There's no inside outlet, but I might be able to have just the bottom outlet a GFCI. (It's the most protected)
No build thread.
Check them for what? If I install a new recept and it works, how could the neutral be bad?
Old 09-19-2019, 09:18 AM   #21 (permalink)
Member # 7412
My neutral bar was not bonded correctly, I had to add a ground wire. I burnt up two gfi plugs. So I put a regular plug in it’s place. Then I started hearing a buzzing sound. It was a voltage feed back arcing from my disconnect box to my offset adapter. Ran another bare wire to the ground rod and stopped all the weird shit. But what I did was not code approved. But I live out of town so fuckem.
Old 09-19-2019, 09:44 AM   #22 (permalink)
Member # 181868
I'm not an electrician, so I may not know all the terms. I assume the disconnect box is the main panel? When you say neutral bar not bonded, you mean the bar in the main panel where the newtrals go? I don't know what a offset adapter is.
One thing, all my grounds go all the way back to my house. (With the hots and neutrals) Do you think I should have a ground rod at the tower? Would I tie the neutral in there? I was thinking of installing a lightning rod. Would I use this same rod?
This is something I've never quite understood. I've been told to never ground the neutral at the receptical. Both the ground and neutral must go all the way back to the panel seperatly. Obviously, on a 240 V this makes sense, but on a 115 V, I don't get it.
Old 09-19-2019, 10:54 AM   #23 (permalink)
fullsize80cherokee's Avatar
Member # 20331
I’ve had weird shit happen with Eaton GFCI receptacles that I recently got from Lowes. They wouldn’t reset with the ground hooked up, Problem was solved after I installed a pass and Seymour device.
fullsize80cherokee is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 11:00 AM   #24 (permalink)
Member # 67681
Throw some borax in the outlet box - no more insect problems.
rugger is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 11:09 AM   #25 (permalink)
Member # 68938
Originally Posted by 88mitsu View Post
this.
The weather resistant ones are no different inside, The only difference is stainless screws and a UV resistant plastc body. They are no better at resisting water intrusion than a standard GFCI.
I would be willing to bet it is just cheap GFCIs, I prefer to get them from an actual electrical parts house, I have had great luck with Hubbell.
https://www.ebay.com/i/333282411247?...AaAhdGEALw_wcB
72 k5 400/350/205 8" lift 4.56s 38" Toyo M/Ts
87 k5 383/400/203/205, 52s 5.13 60/14bff 39.5 rockers
bigbadchev84 is offline   Reply With Quote Quick reply to this message
