Alternator whine through speakers. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-13-2019, 10:05 PM   #1 (permalink)
Member # 774777
Alright so my burb has developed a whine through the speakers. Im pretty sure its the alternator but what has me questioning my diagnosis is that its intermittent and it usually goes away after about 10 minutes of driving or so.
Anyone have any similar issues and did you fix it? Will a noise reducer on the alt to bat wire help?
Stuckntx is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 10:10 PM   #2 (permalink)
Member # 113619
Send a message via Yahoo to stjames151
In my experience, that’s caused by a ground short near the head unit.
[QUOTE=Roc Doc;11597106]This is so weak it makes Richard Simmons look like he's UFC ready.[/QUOTE]
[QUOTE=ironpig70;13786791]But it renforces the point to kids guns are toys.[/QUOTE]
stjames151 is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 10:11 PM   #3 (permalink)
Member # 377
Before you do anything else, check and make sure your ground is secure.
east_beast is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 10:20 PM   #4 (permalink)
Member # 161331
Check all your grounds. Motor to chassis and body to chassis.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 10:23 PM   #5 (permalink)
Aggie06's Avatar
Member # 123554
Aftermarket head unit? My 2010 did that. I found a slightly loose ground causing it. Drove me nuts for months until I found it.
Aggie06 is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 10:25 PM   #6 (permalink)
Baconologyst
smurfblue40's Avatar
Member # 32029
This
US Army Infantry 1983-1992
Imjin Scout DMZ
smurfblue40 is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 11:47 PM   #7 (permalink)
Member # 106178
If the alternator is charging properly and just making some noise then I would just turn the radio up and ignore it.
takotruckin is offline   Reply With Quote Quick reply to this message
Old 10-13-2019, 11:52 PM   #8 (permalink)
Baconologyst
Member # 32029
Turn it up to 11
Imjin Scout DMZ
Old 10-14-2019, 12:02 AM   #9 (permalink)
ArTi54N's Avatar
Member # 104539
did you install it yourself? do you know what your doing?
did a MECP certified installer do it for you?
there used to be at least a dozen things that could cause that whine.. back in the day..
stuff like not running speaker wires next to power wires.. making sure all your grounds are within 2 feet of the amps.. twisting/winding/twirling your RCAs the length of the setup.. just odd stuff.. I could leave a list of a dozen or so things..
ArTi54N is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 01:15 AM   #10 (permalink)
Member # 777769
My speakers I installed for a small amp to plug into my phone had interference with my cb. I fixed it by unplugging the speakers.
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 08:07 AM   #11 (permalink)
Member # 774777
Aftermarket Sony XAV head unit, amp, and component speaker system. Was in the vehicle when I bought it. Was told and looks like a professional install. The guy was a maintenance freak and it shows throughout the truck so I dont doubt him.
The whine just started recently so Im inclined to think alt or ground. The whine does change in pitch with rpm change. Will that happen with a bad ground?
Old 10-14-2019, 08:15 AM   #12 (permalink)
Member # 213125
Amateur shop. Retards probably ran the RCAs for the amp with the power wire for said amp. This is stereo install 101 yet shops still do it. If this is the case your entire system is probably fucking hack work. Seen it a lot when I dabbled in stereos. They only look nice if you don’t know what to look for.
Aisin is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 12:48 PM   #13 (permalink)
paragon's Avatar
Member # 40266
do y'all try to come across as compete idiots or does it just come naturally?
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 01:48 PM   #14 (permalink)
Member # 688970
I think you are right, they are battling for the title
santa V2.0 is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 02:10 PM   #15 (permalink)
Member # 67681
Thread needs a poll.
rugger is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 02:13 PM   #16 (permalink)
Random Dude
Member # 467273
Yes. I'd look at all the ground straps engine-to-frame and body-to-frame before fucking around under the dash. Decent chance it's a braided ground strap that fatigued and gave up. If it's not that, it's probably another ground.
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 02:40 PM   #17 (permalink)
Member # 213125
Shut the fuck up. Just because I know what causes alternator whine doesn’t give you a pass to be a cunt. I offered constructive input. You ran your fucking mouth.
Old 10-14-2019, 04:10 PM   #18 (permalink)
paragon's Avatar
Member # 40266
You offered up dick.... and you know dick.
you made a conclusion with absolutely zero information and told the OP he was wrong in what he was told.
You helped someone wire speakers one time, so now you can claim a business is an "amateur shop."
[COLOR="Black"].
[/COLOR]
Old 10-14-2019, 04:17 PM   #19 (permalink)
paragon's Avatar
Member # 40266
OP
quick and easy would be to try to tie the ground from the amp and head to the same ground.
actually, quick and easy would be a ground loop isolator but you do some fidelity, although that might not matter for your application.
[COLOR="Black"].
[/COLOR]
Old 10-14-2019, 05:13 PM   #20 (permalink)
Member # 161331
This^^^^ if it just started, it's a ground going south. If it was a shit install, it would have been there all along. About a 15% chance your Alt is shiting the bed.
Old 10-14-2019, 05:37 PM   #21 (permalink)
DMG
Member # 8145
I would check the grounds but also consider that when the rectifier goes bad in an alternator it can bleed AC into the electrical system and cause strange stuff like noise. It would happen in the first 10 min of driving because that is when the alter is working hard to bring the charge up.
DMG is online now   Reply With Quote Quick reply to this message
Old 10-14-2019, 05:44 PM   #22 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
Ding. It didn't used ta whine, now it does whine.
Originally Posted by Mustard Dog
Me and my co driver were running across the Lakebed on our way to pre run when we saw :gary: walking his dog.
We didn't stop to say hi cause he's a fucking douchebag.
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 05:57 PM   #23 (permalink)
Random Dude
Member # 467273
X whatever that the alternator could be going (I was hyper-focused on the ground question ).
If it was the stereo cable routing, it would've always been there.
Recently popped up = 95+% chance ground or alternator needs a-fixin'.
Old 10-14-2019, 06:04 PM   #24 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
poll.......... positive or negative?.......
carslut is offline   Reply With Quote Quick reply to this message
Old 10-14-2019, 06:27 PM   #25 (permalink)
Member # 43727
Did you replace the alternator? My truck had zero whine before the alternator went out. The new alternator induced whine in the stereo from the minute I started it up. I will be getting a different one when I get time.
If you didn't, then start checking grounds as said above. Don't just look at them, take them off and clean under all of them you can.
whistle pig is offline   Reply With Quote Quick reply to this message
