Tuning a propane forklift? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-19-2019, 10:30 AM   #1 (permalink)
nate379's Avatar
Member # 20099
I have a 60s Yale 5k forklift. 6 cylinder Chrysler industrial flathead engine.
Was gasoline, but at some point many years ago, it was converted to propane.
It runs, but wont stay running at idle, have to keep it rev'd up a bit.
Seems way rich, like get black smoke, chugging and propane smell out the exhaust.
Im not too familiar with all the components. Is this something that is adjustable, or something beeds replacing perhaps?
nate379 is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 10:32 AM   #2 (permalink)
Member # 62659
Check the air filter. Had one do the same thing, and if the filter is getting questionable, it would act like a choke and the engine wouldn't idle.
YOOPER111 is online now   Reply With Quote Quick reply to this message
Old 10-19-2019, 10:33 AM   #3 (permalink)
Member # 777769
Is this condition new? I would check the mixer diaphragm first
Assuming you checked all the easy things first.
https://
My dog will eat you
Rubirunner85 is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 10:36 AM   #4 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
If it's an impco mixer, there is good troubleshooting documentation out there.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 10:44 AM   #5 (permalink)
nate379's Avatar
Member # 20099
It has a new filter, though the whole setup is sort of fab'd up. When i bought it, there was no filter or even pipe connecting the filter can to the carb (or whatever the carb thing is called)
I used dust collector hose to attach it as the factory hose has been NLA 30+ years.
Old 10-19-2019, 10:47 AM   #6 (permalink)
nate379's Avatar
Member # 20099
I bought it about 2 years ago, was running ok then, but was really hacked up.
It spent well over a year in the shop and i fixed the coolant lines to the propane system, hydraulic issues, wiring, rebuilt the kinpins, new exhaust, tore out the rotting gas tank, new tires, etc.
Old 10-19-2019, 10:51 AM   #7 (permalink)
Member # 55560
Call gotpropane and make it a screamer.
A bunch of old crap
Mattafact is online now   Reply With Quote Quick reply to this message
Old 10-19-2019, 11:03 AM   #8 (permalink)
Member # 777769
There is plenty of info online. Do a quick search to find the components and likely causes. Propane is very simple.
I would conform you donít have a obstruction in the intake.
https://
My dog will eat you
Old 10-19-2019, 01:00 PM   #9 (permalink)
2big bronco's Avatar
Member # 66684
Tune it by adjusting the timing.
Old 10-19-2019, 04:02 PM   #10 (permalink)
Member # 685554
Check the ign points
Newb007 is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 04:34 PM   #11 (permalink)
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
Check all ign components. Good spark is key, a weak spark won't fire with propane. If you do need to replace any fuel parts all the impco stuff is fairly cheap. I replaced my whole fuel lock that had a bad diaphragm for abit more than a rebuild kit.
Recently i had a weak coil on mine that caused it to run poorly and eventually die completely.
Building high performance turbo diesel motorcycles.
dethmachinefab is offline   Reply With Quote Quick reply to this message
