Home wiring / transfer switch panel issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-19-2019, 06:11 PM   #1 (permalink)
Chopperman's Avatar
Member # 2634
OK so I'm a total fawking idiot when it come to home wiring, for some reason my mind just can't grasp it.
Anyway, the PO installed a 30 amp transfer switch panel for a genset. I've got a 10K generator to power the switch using a L14 plug. When I power up the genset, flip the transfer switches all is good EXCEPT I'm getting voltage in circuits not even wired into the transfer switch panel WTF.
Example - The electric water heater isn't even part of the transfer switch panel, but with my 200 main shut off, and all transfer switches flipped to "GEN", I get 80 volts at my hot water heater. How is this even possible. The only way to eliminate it is by turning off my main breakers.
Any ideas?
Chopperman is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 06:38 PM   #2 (permalink)
Rusted.
Tin Roof's Avatar
Member # 132785
Do you have a picture of the setup? You are getting 80 volts to what? Phase to phase or phase to ground?
Tin Roof is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 06:48 PM   #3 (permalink)
Window Licker
bgaidan's Avatar
Member # 34948
Touch your tongue to it and see if it's got any oopf behind it.
Either your transfer switch is somehow not fully disconnecting from the main feed or you're just seeing bleed over voltage that doesn't have much current behind it.
I love Dicks and will continue to shop there.
bgaidan is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 06:51 PM   #4 (permalink)
Member # 619097
Most transfer switches don't switch the neutral, so you're probably reading the potential voltage of an unbalanced load across the neutral.
#1SomeGuy is online now   Reply With Quote Quick reply to this message
Old 10-19-2019, 07:04 PM   #5 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Most water heaters don't have a neutral...
I agree though that there's probably no amps behind those volts. Easy way to tell is to intentionally short the 80 volts to ground. If there's no spark then it's just induced voltage.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 10-19-2019, 07:33 PM   #6 (permalink)
Member # 619097
Well...depends if it's electric or not. Most gas fired ones run on 120v.
Old 10-19-2019, 08:02 PM   #7 (permalink)
Chopperman's Avatar
Member # 2634
Water heater is electric.
I have no idea what the hell is wrong with it, everything on the main is getting "some" power, but only the transfer switch circuits have full juice ie 120V or 240V.
The non transfer switch circuits read much lower volts, but have enough behind it to make whatever is on the circuit do some funky shit, like flicker lights.
This house is jacked. 1976 with like 3 remodels on it - wires going everywhere.
Time to call a pro.
Old 10-19-2019, 08:06 PM   #8 (permalink)
Member # 225201
At Nationals and too drunk to care.
What did I win?
erictylers1 is online now   Reply With Quote Quick reply to this message
