Frost Free Water Tap/Valve - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-20-2019, 08:51 AM   #1 (permalink)
[Memphis]'s Avatar
Member # 49281
Can't believe there isn't a huge thread on this, found one about a cottage valve failing in 2017.
What doesn't suck out there? Will be checking a local plumbing supply house tomorrow. HD and Lowes seem to get shitty reviews and I've had a cheap tap fail in our old rental.
Driving a 5.3L 4x4 el camino wrapped in tupperware :homer:
[Memphis] is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 09:04 AM   #2 (permalink)
dantheman27's Avatar
Member # 105852
Woodford frost-free faucets. Definitely get one from a plumbing supply. The only time I have ever seen one go bad was when a hose was left attached with the faucet on over the winter.
dantheman27 is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 09:15 AM   #3 (permalink)
Member # 124264
google frost free hydrant.. you should get more results.
exmod110 is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 01:11 PM   #4 (permalink)
Member # 193950
This^
We have one of their hydrants in the shop and its amazing the difference between that and the "cheaper" ones.
It will drain the hose attached to the hydrant in ~30 seconds after its shut off.
I will not buy another Chinese junk one for any hydrant that we put in.
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 01:28 PM   #5 (permalink)
Member # 3511
Why - just put a valve in the house to shut off the outside water in the winter.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 01:39 PM   #6 (permalink)
wheelerfreak's Avatar
Member # 4135
I got a Woodford from Lowe's, I don't imagine there's a difference between it and one from a specialty store. I just installed it this summer, so this will be the first winter with it. So far with the limited use I haven't had any issues with it so far and it seems solid.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfits—a false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 02:38 PM   #7 (permalink)
[Memphis]'s Avatar
Member # 49281
I like having both just in case. The current valve inside our new house is damaged and allows water to the outside tap. I’m switching it to a ball valve and hopefully a 1/4 turn frost free if I can find one. I’ve had previous failed frost valves and having the interior shut off was a huge plus. Not uncommon here to have -20F or colder weather
Old 10-20-2019, 02:46 PM   #8 (permalink)
Member # 82607
I've got a cheap one on each end of my house and have never had a problem. One has been there for about 15 years and the other has been there for 4 years.
dave_dj1 is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 03:11 PM   #9 (permalink)
Member # 3511
It gets that cold here too. That is why I have shutoffs and drain the lines.
Chuck P
Old 10-20-2019, 04:06 PM   #10 (permalink)
Member # 69633
Location: I live in my body: On the land near Paradise Township, Jefferson State, not by choice.
Try Tractor Supply.
https://www.tractorsupply.com/tsc/product/hydrant-4-ft
This 4 ft. Hydrant provides easy access to water for all your lawnscaping projects.
6 ft. total length
4 ft. bury depth
Corrosion-resistant standpipe
Leakproof seal can be easily replaced
Easily replaced rod, plunger, seat and linkage without digging
Lockable cast iron head
90 day limited warranty
This space for rent, cheap!
ParadiseAutoElectric is online now   Reply With Quote Quick reply to this message
Old 10-20-2019, 04:10 PM   #11 (permalink)
Member # 226216
Originally Posted by ParadiseAutoElectric View Post
Try Tractor Supply.
6 ft. total length
4 ft. bury depth
The only thing that looks good about them from the ratings is the repair kits...
thefishguy77 is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 04:33 PM   #12 (permalink)
Member # 214044
Not sure if you need one from the wall or stand alone. How about this, Zurn Z1321-CXL-6:
https://www.amazon.com/Zurn-Wall-Hyd...52133759&psc=1
909kenu is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 04:35 PM   #13 (permalink)
BossBuilt's Avatar
Member # 1760
Don't buy the cheap ones. God they suck. A good one is going to cost you around $40 I got the woodford at Home depot. Great product.
BossBuilt is offline   Reply With Quote Quick reply to this message
Old 10-20-2019, 04:37 PM   #14 (permalink)
Member # 193950
Try Tractor Supply.
6 ft. total length
4 ft. bury depth
I am willing to pay $100 more to NOT have to dig it up in 5 years because the valve has corroded shut (been there, done that) and to avoid having to haul water out to the cows in buckets because the hydrant froze up in the middle of winter (got the t-shirt): https://www.lowes.com/pd/Woodford-Y3...ydrant/3572498
Aaron Z
Old 10-20-2019, 04:43 PM   #15 (permalink)
Member # 4135
This, I was thinking this was what you were asking about. Or are you thinking of the frost free spigot that goes through the wall of your house to the outside?
Old 10-20-2019, 04:48 PM   #16 (permalink)
Member # 214044
Zurn Yard Hydrant Z1396XL. 2 to 8' bury depth. Not sure how much but order through your local plumbing supply.
https://www.zurn.com/media-library/w...ts/z1396xl-pdf
Old 10-20-2019, 04:50 PM   #17 (permalink)
[Memphis]'s Avatar
Member # 49281
Through the wall spigot
Or “silcock” I guess it’s called
Old 10-20-2019, 05:12 PM   #18 (permalink)
Member # 4135
Then Woodford would still be my go to. I replaced two of my spigots with Woodford frost frees that I bought at Lowes. Also made in U.S.A. if that matters to you. They had more clearance from the house to make attaching the hose easier since I was always scraping my knuckles on the stucco with the other style that was there.
Old 10-20-2019, 06:14 PM   #19 (permalink)
Member # 59610
frost free hose bibb
Originally Posted by 45acp View Post
Titty bar with moms? Sure why not. Right after I masturbate in church.
jeeptj19992001 is online now   Reply With Quote Quick reply to this message
Old 10-20-2019, 08:03 PM   #20 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
I put in a couple 2 years ago. Working fine. Hot water outside is fantastic. Baloons by my daughter.
I spent some time looking for a 1/4 turn ball valve sillcock, and couldn't find much. One company made them, but didn't have much of any distribution. I decided I'd rather use something I can get find anywhere, Woodford from HD/Lowes.
Best plumbing forum evar!
https://terrylove.com/forums/index.php
We had part of a slinky. But I straightened it.
Subybaja is online now   Reply With Quote Quick reply to this message
