Mint Linux issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-15-2019, 06:37 PM   #1 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Mint Linux issue
Picked up a beater Dell laptop at a pawn shop for cheap. Software was inop so in an abundance of thrift decided to make it a Linux machine.
Created a bootable USB stick with Ubuntu Mint, installed it, and followed all the various steps.
So far so good.
There is an icon to make the machine boot from the HDD. It never works - get a 'no boot media' (or somesuch) message when powering up. It will only boot and run if the stick is installed.
Hoping for good advice because each time I go through the 'make it boot from the HDD' process it clears installed programs and settings.
Always tip.
plym49 is offline   Reply With Quote Quick reply to this message
Old 11-15-2019, 07:32 PM   #2 (permalink)
arse_sidewards's Avatar
Member # 256962
Install OpenBSD on it like a real man.
arse_sidewards is online now   Reply With Quote Quick reply to this message
Old 11-15-2019, 07:36 PM   #3 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Fuck you. That's not an O/S, that's a career.
Always tip.
Old 11-15-2019, 08:37 PM   #4 (permalink)
Member # 153001
you likely need to edit the grub config, or whatever bootloader mint uses nowadays and set the proper boot partition
pistol-mcgee is offline   Reply With Quote Quick reply to this message
Old 11-15-2019, 10:06 PM   #5 (permalink)
Member # 42503
I think I had an issue with ubuntu that was similar, I'd go through the install to HD and do everything like normal it would reboot and it wouldn't boot. I ended up doing something like a grub-install /dev/sda or a grub2-mkconfig and then a grub2-set-default 0 to make it bootable.
it's been a few months so my memory of what I did isn't great. it was only on one machine that did it, I've loaded 2 other laptops with the same DVD and it worked great without having to mess with grub.
Spork is offline   Reply With Quote Quick reply to this message
Old 11-16-2019, 05:45 AM   #6 (permalink)
Member # 84339
Sounds like you didn't install to the internal hard drive.
Lugnut4x4.com
And i don't want to give Canadiens any more money, so my sig is broke.
Pt_Ranger_V8 is offline   Reply With Quote Quick reply to this message
Old 11-16-2019, 06:51 AM   #7 (permalink)
Realsquash's Avatar
Member # 2578
I think you need to get off the lappy and get a tablet. With iOS on it. Then call some Apple genius, which is an oxymoron if you ask me. You're welcome.
Realsquash is offline   Reply With Quote Quick reply to this message
Old 11-16-2019, 07:45 AM   #8 (permalink)
Member # 86724
this.
here's the easy button, uness you want to do it cli
https://linuxhint.com/linux_mint_boot_repair/
Old 11-16-2019, 07:50 AM   #9 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Thank you.
Pretty sure I did but will check.
Not ready to turn in my man card, sorry.
Originally Posted by 87manche View Post
this.
Thank youse.
EDIT:
With any of these solutions, will my settings and installed software remain the same and unaffected?
Always tip.
Old 11-16-2019, 08:08 AM   #10 (permalink)
Realsquash's Avatar
Member # 2578
In your quest to be cheap has anyone corrected this part of your query?
Old 11-16-2019, 08:16 AM   #11 (permalink)
Mopar Moe's Avatar
Member # 653210
Needs more triangulation.
Causing spontaneous disassembly in various motorsports for over 45 years
Mopar Moe is offline   Reply With Quote Quick reply to this message
Old 11-16-2019, 08:34 AM   #12 (permalink)
Member # 86724
it will all remain the same.
you're just fixing the bootloader on the hard drive so you don't need the USB drive for it's boot loader.
technically mint is built on ubuntu.
Old 11-16-2019, 09:23 AM   #13 (permalink)
Damn kids
plym49's Avatar
Member # 162771
What he said.
Fuck spending money on Windows and Office.
Libre Office, bunch of other freebies, will see how it fares.
Always tip.
Old 11-16-2019, 09:53 AM   #14 (permalink)
Member # 86724
I've been using mint since it was still just a fork and didn't have it's own shell or anything. switched from ubuntu when they went ubuntu one and it sucked.
it's easy
it works
which are two things I value in my home internet machine.
I fuck with servers and shit at work, ain't nobody got time fo dat at home.
and fuck windows. You know how many times my wife would have fucked a windows machine? lots.
I'm not paying apple's absurd pricing and pay for everything integration either, so here be linux, on "refurbished" laptops I buy for $200 on ebay and use until I break them.
this Hp is currently on like 5 years. Still surfing pirate on it. I mean really. What do you need a home PC to do these days?
surf the internet, and maybe type something to be saved as a PDF and emailed. That's about it.
Old 11-16-2019, 10:02 AM   #15 (permalink)
Damn kids
plym49's Avatar
Member # 162771
this.
OK, ran the tool which is very cool for a non-techie like myself as you get to type 'sudo'.
Ran it as recommended and all seemed ok.
But the problem persists. Here is what pops up:
Always tip.
Old 11-16-2019, 10:05 AM   #16 (permalink)
Member # 86724
have you been into the bios setup yet and looked at your boot device chain?
HDD/SSD/SATA needs to be first.
USB second.
optical drive third.
network last, or disabled if you'll never boot from a network which you never will.
edit:
this makes the assumption that you were actually using the USB device to boot an install on a local disk.
perhaps you've just been running the temp install from the USB drive the whole time?
what did your partition tables look like?
goto "system info" in the mint menu and see what it says for your hard drive size.
Old 11-16-2019, 11:25 AM   #17 (permalink)
Member # 200478
Attachment 2951806
That reflection makes it look like jabba the hut is using your computer.
isbj60 is online now   Reply With Quote Quick reply to this message
Old 11-16-2019, 11:57 AM   #18 (permalink)
Damn kids
plym49's Avatar
Member # 162771
It sure do, boy.
Always tip.
Old 11-16-2019, 12:02 PM   #19 (permalink)
Damn kids
plym49's Avatar
Member # 162771
USB second.
edit:
Yes, it's gotta be something along those lines. Stick is 8 gig and system is showing 512 gig, but it looks like the internal drive is being taken as a dismountable external drive.
In the BIOS boot menu it was UEV or AEF or somesuch; said that does not support boot from internal disk drive. I attempted to change it to the other setting but almost seems locked down. Maybe this machine was set up to boot from a network? Maybe I need to update the BIOS?
Always tip.
Old 11-16-2019, 12:33 PM   #20 (permalink)
Damn kids
plym49's Avatar
Member # 162771
it's easy
it works
^ This x1024.
Used Ubunto in the past, tried the new one on this laptop but it sucked big time. Tried Mint and happy with it. (Tried another in between that sounded good but was buggy as shit - do na remember the name.)
I loaded Libre with this and eschewed the marketing-gimmick alternative that is now bundled with Mint.
In addition to surfing, I need to be able to work with Word, Excel and PowerPoint docs. Libre office is 'ok' as it is not completely compatible, with Office but usually good enough.
Do you have a trick to opening a .pst file? Do not want to spend money and need to do it past a 10 day trial.
Always tip.
Old 11-16-2019, 01:45 PM   #21 (permalink)
Member # 86724
yeah, that looks like you're running just from the usb stick.
option for the bios is likely UEFI
you want to set that to legacy.
then choose a boot device.
pst is a PITA.
do you just need access to the emails in an archive capacity?
libpst can read the messages and convert them into mbox files and then you can just import them into thunderbird.
Old 11-16-2019, 03:13 PM   #22 (permalink)
Damn kids
plym49's Avatar
Member # 162771
pst is a PITA.
I have tried doing that and the BIOS menus are not giving me the selections I need to change it, so I suspect some slim shady prior config. If I just have to keep the stick, I will.
I really only want contacts and calendar. Emails would be a bonus.
Always tip.
