What's wore out? - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-18-2019, 04:38 PM   #126 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
Originally Posted by Rubirunner85 View Post
Well my fiancÚ has dissected a few cadaver hearts. Possibly they were hobos. I know she cut up other pig parts, can not confirm the heart of swine.
Taking things apart to see how they function is great. Challenge yourself and put them back together. Otherwise you are just an average tweaker
did she bring the hobo's back to life? I might need to make a couple wall clocks now
Old 11-18-2019, 04:44 PM   #127 (permalink)
Member # 53453
Out of hobo's hearts?
DirtyComanche is online now   Reply With Quote Quick reply to this message
Old 11-18-2019, 04:57 PM   #128 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
well, they need to be regulated somehow and we have plenty of hobos
Old 11-18-2019, 04:58 PM   #129 (permalink)
Member # 74407
Gonna chainsaw some timex watches apart to see how they work.
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 11-18-2019, 05:07 PM   #130 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
um, do you not know how many watches I've taken apart? hell there is even a thread about it
though, admittedly, I've gotten several of them to function again
https://www.pirate4x4.com/forum/gene...at-thread.html
you know that old joke about the guy who comes home and his little kid has taken his drill apart to see how it functioned, but gosh golly it was so cute he just couldn't be mad? well, these days it is just my own stuff
Old 11-18-2019, 06:09 PM   #131 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 11-18-2019, 06:53 PM   #132 (permalink)
Member # 192237
In diesel emgines that make their torque at lower rpms, a low stall speed means more power to the tires earlier in the rpm range. This is good for towing and moving heavy loads. A drag car that makes power much higher in the rpm range benefits from a higher stall speed at launch to get it moving as fast as possible. This builds heat much quicker and thus isnt great for every day driving.
then why is it that every post 2000ish diesel pickup I hop into won't move along at idle, when every gas counterpart does?
I'm more likely to believe the other guy itt that said they got higher stall converters than gas motors after they all got turbos and lockup
Old 11-18-2019, 06:56 PM   #133 (permalink)
Member # 192237
Originally Posted by Thatg9659 View Post
I already knew that, that's why I had 486 cut it open before he sent it to me he seems open to dildos to the face at least once
hey hey hey
I think you just outed yourself as an AE
Also, no idea if it was a toyota converter, it was just in the scrap bin at the junkyard
that waste oil fuge working yet? Mine still isn't.
Old 11-18-2019, 07:35 PM   #134 (permalink)
Member # 74407
Lets use GM as an example.
A Dmax/Allison (Ive personality owned 2) combo has a stock stall speed of roughly 1800-1900rpm iirc. A Camaro w/ an LS1/4L60E combo has a stock stall speed of 2400-2500 iirc. If you buy an aftermarket unit for a Dmax, the popular option is to reduce stall speed a few hundred rpm. Yet for the Camaro jumping the stall speed upto 3000-3500 is a popular upgrade because it moves the rpm range up to where the car is making more power. No one cares about off idle power in a sports car.
Old 11-18-2019, 07:43 PM   #135 (permalink)
Member # 192237
I'm talking similar year f250, 6.0 vs 5.4
stick it in drive and let go of the brake pedal, diesel sits there, gas truck starts rolling
3.55 vs 4.10, so no significant gearing difference
Old 11-18-2019, 07:48 PM   #136 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
something interesting
TH400 "low stall converter"
https://www.monstertransmission.com/...l#.XdNV225FyM8
$160, claims heavy duty 13" diameter for towing, hauling and truck stuff. approx. 1350 stall
https://revmaxconverters.com/product...que-converter/
stage 4 full race high stall speed TH400 converter
~$700 for a custom build racing converter, 3200 rpm listed as an example and 9" diameter
they aren't listed as dependent on the engine, well the full custom can be, so it doesn't seem as dependent on input torque.
i'm curious how much they are playing with vane angle/pitch internally
high stall being high slip and low stall being low slip, whereas something with an electric lockup could simply be hotwired to lock whenever you want it to
Old 11-18-2019, 07:57 PM   #137 (permalink)
Member # 53453
Electric lockup doesn't work below a certain RPM normally, as there isn't enough line pressure to hold the clutch and it will chatter... And then kill itself.
Also, it's great when you leave it locked and come to halt and the engine stalls before the pressure drops enough to release the clutch.
Old 11-18-2019, 08:04 PM   #138 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
well if you want to be a damn safety nerd, you could keep it hooked up with the brake circuit so that it automagically unlocks whenever you apply the brakes
I mean, I like to live dangerously though
https://www.dieselpowerproducts.com/...n-1030227.aspx
look at this nerd ass TC, with it's clutch and pressure plate inside there
https://www.diyford.com/ultimate-for...verters-guide/
well shit, this was difficult to find and interesting
Torque converter manufacturers like B&M, TCI Automotive, and Performance Automatic employ techniques that make torque converters more efficient with less slippage. Much of the general technology is rooted in fluid dynamics and how fluid behaves under given conditions. The greatest factor in converter construction is stator design, meaning blade/fin shape and angle, which determines stall speed and slippage. And this fact alone helps determine your quarter-mile times and the way your Ford behaves on the open road.
quote from that last link, I guess that is the easier part to mess with
Old 11-19-2019, 04:47 AM   #139 (permalink)
arse_sidewards's Avatar
Member # 256962
You need to go watch some youtube videos on torque converters.
Also FYI larger OD = lower stall all else being equal. With a larger OD a given RPM difference translates into a larger speed difference between the impeller and the turbine.
IIRC stator pitch is usually what is varied in order to change the effective torque multiplication of the torque converter and with that gear reduction necessarily comes a higher stall.
Old 11-19-2019, 05:03 AM   #140 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
We put an electric lockup trans in my buddy's '82 El Camino, forget which trans it was...but we wired the lockup to the floor-mounted high-beam switch (it had already gotten a more modern column with the high beams on the stalk).
Definitely could create some interesting circumstances engaging or disengaging it at certain speeds or gears it's still moving ~8 years later so we haven't killed it yet, but one of the more interesting automatics I've ever driven.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 11-19-2019, 06:37 AM   #141 (permalink)
Member # 852732
hey hey hey
No ae just lost pw
No more diesels in the fleet so no fuge. You ever finish the gun that brass was for?
Thatg9659 is offline   Reply With Quote Quick reply to this message
Old 11-19-2019, 07:59 AM   #142 (permalink)
Member # 192237
No ae just lost pw
Oh yeah, it's shot a few times. Need to put a compensator on it before it eats itself.
9x25 dillon is too much poop for a light-ass tokarev slide
Old 11-19-2019, 11:52 AM   #143 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
yeah I don't have the patience for youtube generally
so higher pitch and more vanes in the stator would get you more grab then, I guess if you really want to take a cheapie stocker and make it full drag, just open it up and cut every other stator vane in half
Old 11-19-2019, 12:08 PM   #144 (permalink)
Member # 256962
Wouldn't work. You'd just have a stator that doesn't fling fluid around as efficiently. You might gain a little go from the increased engine RPM but that would very much be the wrong way to do it.
Old 11-19-2019, 04:26 PM   #145 (permalink)
Member # 866526
Cat Clean will fix that plugged cat. it worked on my car.
Augustine Traxler is offline   Reply With Quote Quick reply to this message
Old 11-19-2019, 04:57 PM   #146 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
non emissions county, a saw will fix a clogged cat.
what is cat clean anyways? just something that burns the exhaust hotter?
or a turbo
Old 11-19-2019, 06:41 PM   #147 (permalink)
Member # 192237
typical hack way of raising stall is to move the turbine further from the stator
Old 11-19-2019, 07:25 PM   #148 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
interesting.
it seems like there are more hack options for raising stall i.e. breaking the thing, than there are for lowering stall
Old 11-19-2019, 07:27 PM   #149 (permalink)
Member # 40417
Do you sell flex-seal as well?
Better to be a racer for a moment, than a spectator for a lifetime.
FlexyTJ is offline   Reply With Quote Quick reply to this message
Old 11-19-2019, 07:29 PM   #150 (permalink)
Member # 192237
interesting.
weld turbine to pump
throw away stator
0 stall cornverdurr
use the EPC solenoid to feather your neutral drops
