Drainage pipe. Why do they use corrugated? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2019, 05:55 AM   #26 (permalink)
Member # 54455
Originally Posted by _Stucky View Post
Pro tip: start at the outlet. Work your way up hill. That way you can always make sure you have enough grade. How you ask? Because water always runs downhill. Every time.
Advanced pro tip: start at the inlet, roll a ball down after each section is layed. If it stops, add slope.
Boats n Does
Deuce 40s is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 06:42 AM   #27 (permalink)
_Stucky's Avatar
Member # 182743
No. If you are putting tile where itís needed, there will be water. Also itís pretty hard to put dirt under a tile that is already laid in the ground. But if you really want to lose your ball, go ahead.
_Stucky is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 06:46 AM   #28 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Originally Posted by Rubirunner85 View Post
I sure I will need to know this later on.
Pro tip: holes in the back, slits in the front.
You're welcome..
I'd call you a cunt but you don't have the depth or the warmth.
Fuck em' and feed them fish heads-
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 06:52 AM   #29 (permalink)
Member # 54455
We're talking yard drainage. If there's too much slope, lift up the pipe and kick some dirt in. How is that hard? If your ball is lost in the pipe, you don't have enough slope to carry the detritus.
Boats n Does
Old 12-03-2019, 07:06 AM   #30 (permalink)
Member # 51250
Originally Posted by Snowbird13 View Post
Plastic joints have no strength ? Ever try to pull apart a properly seated joint in 8 inch or plastic joint?
What do you mean no angles for plastic pipe? Use them all the time
Been more of a hassle to try to get them to hold together when you backfill. If you're not bedded perfectly or even push dirt from one side instead of directly on top, the joints bend and separate way more easily than a stout steel coupler
Never used anything smaller than 18" so I don't know about 8". I'f I'm going to invest the thousands of dollars required to transport equipment and dig up a road. spending a little more for a larger diameter pipe that's less likely to clog with debris is a good investment
What do you mean no angles for plastic pipe? Use them all the time.
I see the link for 12" 45's someone put up from Tractor supply, but it looks like the type you just hold together with zip ties: not something I'd trust for a down drain assembly. Do you have a vendor for belled angle fittings, say 24" or larger? If I could get belled fitting and hold them in place with cable anchors or something, might be worthwhile but no way I'd mess with zip tie couplers. I'm still avoiding them because of the fire thing, mostly just curious.
rtrsam is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 07:07 AM   #31 (permalink)
_Stucky's Avatar
Member # 182743
Sure do whatever you want, itís not my yard.
Old 12-03-2019, 07:27 AM   #32 (permalink)
roundhouse's Avatar
Member # 16751
Dunno why everyone used the corrugated
If you use pvc you can at least run a snake through it later to clear the roots
Canít do that with corrugated pipe
Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?[Alan Keyes]
For some, Freedom matters, for most, prosperity suffices.[Fred Reed]
74Bronco EFI 5spd
roundhouse is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 08:37 AM   #33 (permalink)
_Stucky's Avatar
Member # 182743
Can too....
Thereís a lot of ďtheoriesĒ going on in this thread...
Drainage is simple. Number 1 rule, water goes downhill.
Old 12-03-2019, 08:50 AM   #34 (permalink)
Member # 90667
Can too....
The first failure of a proper yard drainage system is to design it by accepting the lie that there will only be water running through the pipe.
You don't want the water screaming through but you don't want it slugging with leaves and debris either.
Gittinwidit is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 09:11 AM   #35 (permalink)
2big bronco's Avatar
Member # 66684
After reading this thread I think I'm just coing to make a 40' long concrete gutter 8-10" deep and 18" wide with some galvanized grating on top. Easy to clean out and I'll always be able to see what's going on.
Old 12-03-2019, 09:17 AM   #36 (permalink)
Member # 29527
It's for her pleasure.
CrustyJeep is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 09:57 AM   #37 (permalink)
Member # 154867
I had to put in a massive surface drain this year. We did the double-wall corrugated, in a 10" (!) diameter. So it's smooth on the inside, and giant. That sucker moves some water. When I was testing it with a garden hose, the water moved much more quickly through the double-walled pipe, since it didn't have to fill up all the ridges. Obviously, that's not really a rate measurement, since it's just having to fill up the resident volume. But it took me maybe 10 min to get water through 40' of dry 4" corrugated. Then like 5 min to get it through 150' of 10" double-wall. Since we put this in, our pre-existing drains don't seem to move any volume at all--everything appears to go out the giant double-walled one. Kinda excited for flood season in the spring...
OHV Wildcat is online now   Reply With Quote Quick reply to this message
