turbo cold side piping - 2" outlet upsize to 2.5"or 3" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2019, 09:49 AM   #1 (permalink)
today
fredycruger's Avatar
Member # 225557
i have new turbo to put on my truck
engine is Nissan straight 6, 4.2L turbodiesel
i was running hx35 but was too big
new turbo have 2" outlet
should i get coupler that goes from 2" to 2.5"/ 3"and run bigger pipe than turbo outlet ?
im not running intercooler at this moment if it matter
new turbo is china TD05 16/6cm
fredycruger is offline   Reply With Quote Quick reply to this message
Old 12-30-2019, 10:25 AM   #2 (permalink)
Member # 229476
I don't think it does any harm to have the outlet piping larger diameter. On my little 2.2L Kubota I'm running about 2 feet of 2.5" exhaust, which I'm quite sure is way larger than needed.
www.33Chevy.net
danielbuck is offline   Reply With Quote Quick reply to this message
Old 12-30-2019, 10:30 AM   #3 (permalink)
Member # 214685
I know there is quite a bit of science behind the whole deal. Larger piping can cause more lag/pressure drop. Probably really only matters on race car applications where every HP matters.
Byro is offline   Reply With Quote Quick reply to this message
Old 12-30-2019, 10:39 AM   #4 (permalink)
today
Member # 225557
just measured the stock outlet and its about 1.5"
so im thinking ill be fine with 2" intake
this turd only have about 120 HP. and i got all the pieces here to finish the cold side.
ill run it
Old 12-30-2019, 10:40 AM   #5 (permalink)
today
Member # 225557
sorry. i was talking about intake piping
Old 12-30-2019, 10:48 AM   #6 (permalink)
Member # 133009
Like pre compressor? You could cut up a plastic garbage can and use it as piping and that turbocharger wouldn't know the difference.
Post compressor/pre cylinder head you will still be fine with .5-1" larger if that's what you want to do.
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
Old 12-30-2019, 01:12 PM   #7 (permalink)
today
Member # 225557
yeah post compressor
turbo to intake manifold
Old 12-30-2019, 01:44 PM   #8 (permalink)
Member # 133009
Run it
Old 12-30-2019, 01:50 PM   #9 (permalink)
today
Member # 225557
Run it
stay with 2" cold side from turbo to intake manifold ?
Old 12-30-2019, 05:08 PM   #10 (permalink)
Member # 133009
If that's what you've got. You could step it up if necessary or run 2", I don't think you will see a difference between the two. Just go with what's easiest IMO
Old 12-30-2019, 05:14 PM   #11 (permalink)
Member # 86724
yes.
it's not worth the hassle unless you're adapting it to an intercooler or something.
Old 12-31-2019, 04:09 AM   #12 (permalink)
arse_sidewards's Avatar
Member # 256962
Might be cheaper to swap in a smog era slant 6 if you're looking for an upgrade.
Old 12-31-2019, 07:07 AM   #13 (permalink)
today
Member # 225557
meh. slant 6 its not much of an upgrade
145 PS (107 kW; 143 bhp) @ 4000 RPM
33.7 kg⋅m (330 N⋅m; 244 lb⋅ft) @ 2000 RPM
s-l1600 by fredycruger, on Flickr
Old 01-09-2020, 09:40 AM   #14 (permalink)
today
Member # 225557
ended up going with 2"pipe
welded M 10x1 nut to the pipe for boost gauge,and got coat of paint
Old 01-09-2020, 09:45 AM   #15 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
There needs to be one of those family guy tophats vs. meg memes for people who don't intercool.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 01-09-2020, 10:45 AM   #16 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
intercooling is over rated. my 1st gen dodge made 360hp and close to 1000lbft tq with only a crossover pipe. egt's while towing were perfectly controllable.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is online now   Reply With Quote Quick reply to this message
Old 01-09-2020, 10:50 AM   #17 (permalink)
Member # 34724
So you actually were talking about the pressure side of piping and not the cold side of the turbo (intake) by looking at the pictures.
I have made cold side intakes out of PVC piping, it works. Not the greatest, but works.
I get nervous in social situations motherfucker!
EHeye is offline   Reply With Quote Quick reply to this message
Old 01-09-2020, 10:51 AM   #18 (permalink)
Member # 70148
What was your boost pressure at 1000 torques?
Old 01-09-2020, 10:54 AM   #19 (permalink)
yozsi's Avatar
Member # 91857
45-48 psi.
Edit. Only hit 42ish on the Dyno but on a long 4th gear run I'd see 48psi.
Foreign Car Center
Vallejo, CA
Old 01-09-2020, 11:18 AM   #20 (permalink)
Member # 70148
45-48 psi.
That's over 300F air going into the engine.
You're having to make an extra ~14psi of boost due to not being intercooled. That's extra pumping and compression work with no benefit.
(STP conditions, napkin math.)
I'm not saying it's CRITICAL, I'm just saying it's 90's Busch league to omit inter-cooling, especially over a bar of boost.
Old 01-09-2020, 11:33 AM   #21 (permalink)
today
Member # 225557
i had intercooler before this set up . im planing on upgrade later but i cant run front mount and top mount would need hood cut out to be efficient.
new set up making 20 psi with 900 pre turbo EGT's when i beat on it
im sure there i room for improvement
Old 01-09-2020, 11:39 AM   #22 (permalink)
yozsi's Avatar
Member # 91857
oh i believe you. but im also the dude that says 1350 deg egt, pre turbo, sustained, going 80mph uphill while towing is okay.
Foreign Car Center
Vallejo, CA
Old 01-09-2020, 11:47 AM   #23 (permalink)
Member # 17632
My intercooled first gen with stock cooler pulled really well at 25 psi of boost even though it would make about 32 psi floored. I would use the throttle to control boost on climbs and keep it around 25 when towing. Worked great. I think anything over 25 psi was making too much heat for the stock IC to handle so I was burning fuel and getting no real return beyond that. I am talking towing up long grades here, banging around town empty saw plenty of foot through the radiator action
Travis..
18 Ram 2500 4x4 Big C and a 6 speed
73 Dodge W100, 400 4spd, stepside project
crashnzuk is offline   Reply With Quote Quick reply to this message
