need some ideas - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2020, 07:50 PM   #1 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
need some ideas
got a weld position at work that was overloaded and best i can tell sheared the key way. i am having a hard time coming up with a way to get the gear out, to inspect and repair. the machine is old, lots of stuff is welded together and i dont have time to disassemble the entire thing to address this issue. i have zero access to the back, what you see is what i can get to. maybe possibly could get a gear puller in there but doubt it. current idea is drill and tap either side of the gear face and build a gear puller of sorts. any ideas?
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 07:54 PM   #2 (permalink)
dethmachinefab's Avatar
Member # 101113
Send a message via AIM to dethmachinefab
Yea that would be my choice, but first I'd run it and see if the gear slipping on the shaft would walk itself off if ran in the proper direction.
Building high performance turbo diesel motorcycles.
dethmachinefab is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 08:04 PM   #3 (permalink)
Ebs
Member # 20043
Slide hammer with pulling hook attachment (or just hook a bolt head between the teeth and welderfabricate it to the slide hammer).
Ebs is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 09:24 PM   #4 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
Is that bronze or brass? Anyways, like said above I'd definately drill and tap and use a puller
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 09:24 PM   #5 (permalink)
billdacat's Avatar
Member # 72617
Why can't you hit that shaft with a brass hammer to drive that fucker out? Didn't you remove a nut from that gear?
I am sort of laughing at this; GF has a big fucking gearbox laying on the bench of her late Dad's shop.
Сделайте Америку отличной снова
billdacat is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 09:29 PM   #6 (permalink)
BamaJeeper's Avatar
Member # 14620
Turn it on. It should work itself off.
Priest "The time has come to liberate the potential of the coming porkappocalypse."
BamaJeeper is online now   Reply With Quote Quick reply to this message
Old 01-28-2020, 09:51 PM   #7 (permalink)
Member # 88698
Drill and tap 2 holes and use a harmonic balancer puller.
LBHSBZ is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 10:12 PM   #8 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Depending on the worm envelope, that may have gone together with the bronze gear on first and the worm gear inserted second. Meaning you might have to pull the worm gear out from the side before the bronze gear comes out in the direction you're looking at it.
Depending on the bearings you might be able to flex it enough to force it out...also with some creative grinding, it looks like you could get a 2-jaw puller under that.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 10:24 PM   #9 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
This ^^
Is that a cover plate on the right end of the worm gear?
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 10:59 PM   #10 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
You could weld two nuts to the gear face and mount a slotted hole plate or hub pulled plate on it then install a slide hammer on that.
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
Old 01-28-2020, 11:02 PM   #11 (permalink)
Member # 18369
Put a nut inside a socket weld the socket to the gear and extract with a bolt.
Wazzobie is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 03:58 AM   #12 (permalink)
Member # 82607
If you can't take it apart to fix it just weld the fucking thing to the shaft
dave_dj1 is online now   Reply With Quote Quick reply to this message
Old 01-29-2020, 05:37 AM   #13 (permalink)
daddytall's Avatar
Member # 74936
Damn Macgyver, thats a good idea.
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 05:41 AM   #14 (permalink)
Member # 67681
how did I never think of this?
rugger is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 05:44 AM   #15 (permalink)
Johann's Avatar
Member # 4251
Yep, then it is the next guys problem!
Need reloading dies, brass and such for .351 WSL- PM me with what you have.
Johann is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 06:04 AM   #16 (permalink)
Member # 4375
If the gear will move past the worm gear, get a nut that is the same as the threads on the shaft thread it on all the way to the gear. Weld it to the gear if the direction of the worm gear spinning will let it unthread and take the gear with it. If it is a reversible positioner, even better.
Still not sure how the nut in the socket is any different than just a nut??
Stupidity abhors a vacuum
mrblaine is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 07:10 AM   #17 (permalink)
rockbuggy84's Avatar
Member # 45202
I’d weld two long bolts at their heads to the gear face.
Slide on a puller and add washers and nuts.
"Whiskey is cheap, Talk cost money"
rockbuggy84 is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 07:34 AM   #18 (permalink)
mobil1syn's Avatar
Member # 9795
that was step one, no dice.
do tell more about the envelope, i forgot this is your field of expertise. that thought crossed my mind. the big box on the right houses the chain drive to run the worm gear via the jack shaft. tried taking it apart so i could get the worm gear box off but its permanently attached best i can tell. im just a controls guys who isnt an idiot who fixed something once and apparently that has made me the maintenance guy. i dont have the desire or time to dive into this, so if the gear wont come out quickly im going to let management know they need to call someone else.
thats a 4x4 for reference
-George Whitefield
Old 01-29-2020, 07:42 AM   #19 (permalink)
mjlogan88's Avatar
Member # 23553
the bronze gear may have a concave face to allow for a tighter mesh with the worm. you might have to pull the worm first since the gear wont just slide out. or knock the output shaft out the back side worst case.
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 07:55 AM   #20 (permalink)
Member # 688970
Whatever you figure out, please post the solution. I would drill/tap and use some kind of puller. I've never worked on that kind of machinery, but have had to core bore a wall to remove a 4" shaft from an air handler
santa V2.0 is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 08:17 AM   #21 (permalink)
Member # 59610
weld the gear on to the shaft, put cover on and walk away.
hope it lasts till you retire or get another job
Originally Posted by 45acp View Post
Titty bar with moms? Sure why not. Right after I masturbate in church.
jeeptj19992001 is online now   Reply With Quote Quick reply to this message
Old 01-29-2020, 08:31 AM   #22 (permalink)
mobil1syn's Avatar
Member # 9795
nope. half the crap i deal with in this place is because of that mentality or because it was repaired by someone with a third world attitude (use whatever is there to accomplish the task, even if you could purchase the proper part for a few dollars)
-George Whitefield
Old 01-29-2020, 09:01 AM   #23 (permalink)
angryblack's Avatar
Member # 142394
If you are going to fix it right then cut or damage the part that you know you are going to replace. If you are going to repair whats there then heat up the gear to help you drag it off. Drilling and tapping the gear will make future rebuild easier so that id say is a no brainier.
I need a used Winters shift for a standard pattern TH400, its for the wifes drag week effort.
angryblack is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 09:34 AM   #24 (permalink)
Oh Jesus Tits....
Member # 17554
Similar to waht I'd advise...or just weld to the face of the gear and use a slide hammer
1977 Ford F150 4x4 Shorty 351M/NP435
2007 Ram 2500 Quad Cab 4x4 5.9 Cummins
D-RAT is offline   Reply With Quote Quick reply to this message
Old 01-29-2020, 10:57 AM   #25 (permalink)
RDR800's Avatar
Member # 30673
Short fix, hold jack screw, heat gear, see if you can rotate shaft inside gear, install new key. Like others have suggested, drill and tap, use flange puller. Is the area behind the gear hollow? If not. Could use jack screws. If gear is readily replaceable, zip wheel and chisel. If not, hole saw around shaft, remove gear, make sleeve...
"Never underestimate predictability of stupidity"
RDR800 is offline   Reply With Quote Quick reply to this message
